Re
j'ai copié dans la macro le complément mais j'ai comme message "Erreur de compilation Next sans For
Pouvez vous m'intégrer votre complément directement dans la macro car je n'y comprend rien en macro ?
Sub miseenforme()
Dim i As Long, a, j As Byte, mavar As String
For i = 1 To [T_data].Rows.Count
[T_data].Item(i, 2) = UCase([T_data].Item(i, 2)) 'NOM
If [T_data].Item(i, 3) <> "" Then
a = Split([T_data].Item(i, 3), " ") 'Prénom
mavar = ""
For j = LBound(a) To UBound(a)
mavar = mavar & UCase(Left(a(j), 1)) & LCase(Mid(a(j), 2)) & " "
[T_data].Item(i, 3) = Trim(mavar)
[T_data].Item(i, 4) = UCase([T_data].Item(i, 4)) 'Sexe
[T_data].Item(i, 8) = UCase([T_data].Item(i, 8)) 'Nom PÈRE
If [T_data].Item(i, 9) <> "" Then
a = Split([T_data].Item(i, 9), " ") 'Prénom PÈRE
mavar = ""
[T_data].Item(i, 9) = Trim(mavar)
[T_data].Item(i, 11) = UCase([T_data].Item(i, 11)) 'Nom MÈRE
If [T_data].Item(i, 12) <> "" Then
a = Split([T_data].Item(i, 12), " ") 'Prénom MÈRE
mavar = ""
[T_data].Item(i, 12) = Trim(mavar)
[T_data].Item(i, 13) = UCase([T_data].Item(i, 13)) 'Type acte
[T_data].Item(i, 14) = UCase([T_data].Item(i, 14)) 'Type précis
' Sexe féminin
If [T_data].Item(i, 4) = "F" Then
Select Case [T_data].Item(i, 10)
Case "hier": [T_data].Item(i, 15) = "Née Hier"
Case "ce jour": [T_data].Item(i, 15) = "Née ce jour"
Case Else
If IsDate([T_data].Item(i, 10)) Then
[T_data].Item(i, 15) = "Née le " & Format([T_data].Item(i, 10), "dd/mm/yyyy")
End Select
' Sexe masculin
ElseIf [T_data].Item(i, 4) = "M" Then
Case "hier": [T_data].Item(i, 15) = "Né Hier"
Case "ce jour": [T_data].Item(i, 15) = "Né ce jour"
Case Else
[T_data].Item(i, 15) = "Né le " & Format([T_data].Item(i, 10), "dd/mm/yyyy")
End Select
' Ajout du suffixe " - Jumeau" si présent
If Len(Trim(UCase([T_data].Item(i, 16)))) > 0 Then
[T_data].Item(i, 15) = [T_data].Item(i, 15) & "-" & [T_data].Item(i, 16)
