moins simple, essayez ceci. cela suppose que la liste de validation ne contient que des valeurs "texte"
Dim dercol As Integer, derlig As Integer
Dim plage As Range, cel As Range
If TextBox1 = "" Then MsgBox "Veuillez renseigner un nom de projet !": Exit Sub
If TextBox2 = "" Then MsgBox "Veuillez renseigner un nom d'architecte !": Exit Sub
With Worksheets("Feuil1")
dercol = .Cells(7, Columns.Count).End(xlToLeft).Column + 1
Set plage = .Range("E7:E" & Range("B" & Rows.Count).End(xlUp).Row)
plage.Copy .Cells(7, dercol)
.Range(.Cells(7, dercol), .Cells(15, dercol)).ClearContents
.Cells(7, dercol) = TextBox1.Value
.Cells(8, dercol) = TextBox2.Value
derlig = .Cells(Rows.Count, dercol).End(xlUp).Row
For Each cel In .Range(.Cells(17, dercol), .Cells(derlig, dercol))
If cel.HasFormula = False And IsNumeric(cel) Then cel.ClearContents
Next cel
With .Cells(7, dercol)
.ColumnWidth = 40 'largeur colonne
Unload Me
Crdlt
