bonjour a tous
Besoin d'aide
IF Len ne fonctionne pas je ne sais pas pourquoi SVP help
Private Sub BtWorker_Click()
If Len(Me.CBCompany) = "" Then
Me.LblError = "Choice Company"
Me.CBCompany.SetFocus
ElseIf Len(Me.Txt_Nom) = "" Then
Me.LblError = "Enter a last name"
Me.Txt_Nom.SetFocus
ElseIf Len(Me.Txt_Prenom) = "" Then
Me.LblError = "Enter a Name"
Me.Txt_Prenom.SetFocus
ElseIf Len(Me.TXT_NID) = "" Then
Me.LblError = "Enter ID number"
Dim a As Range
Set a = Comp.Range("ListComp").Find(CBCompany.Value)
Sheets("Comp").Activate
Select Case a
Case "ATALIAN"
Range("B10").Select
Case "VEOLIA"
Range("H10").Select
Case "BRUNONIELS"
Range("N10").Select
Case "SIPWELL"
Range("T10").Select
Case "OTHERS"
Range("Z10").Select
End Select
Selection.End(xlDown).Select
Selection.Offset(1, 0).Select
ActiveCell = ActiveCell.Offset(-1, 0).Value + 1
ActiveCell.Offset(0, 1).Value = Txt_Nom & " " & Txt_Prenom
ActiveCell.Offset(0, 2).Value = Txt_Nom
ActiveCell.Offset(0, 3).Value = Txt_Prenom
ActiveCell.Offset(0, 4).Value = TXT_NID
If CBCompany = "OTHERS" Then
ActiveCell.Offset(0, 5).Value = TxtNameOTher
Range("AG10").Select
ActiveCell.Offset(0, 2).Value = TXT_NID
Sheets("Report").Activate
Unload Me
