dans le code userform4
Private Sub UserForm_initialize()
Dim MEC As Byte
Dim ML As Byte
Dim LI As Integer
Dim N As Integer
MEC = CByte(Month(Date))
'STATUT COMMANDE
Set OCOM = Sheets("BDD COMMANDES")
Set OSAV = Sheets("BDD SAV")
Set OCLI = Sheets("BDD CLIENT")
Set ORET = Sheets("BDD RETARD")
Set COM = OCOM.ListObjects(1)
Set SAV = OSAV.ListObjects(1)
Set CLI = OCLI.ListObjects(1)
Set RET = ORET.ListObjects(1)
Set PCOM = COM.DataBodyRange
Set PSAV = SAV.DataBodyRange
Set PCLI = CLI.DataBodyRange
Set PRET = RET.DataBodyRange
txt_cmd_statut.AddItem "WIN" 'alimentation combobox
txt_cmd_statut.AddItem "WIN+CMD" 'alimentation combobox
txt_cmd_statut.AddItem "WIN+CMD+CONFIRME" 'alimentation combobox
'ETAT SAV
txt_sav_etat.AddItem "EN COUR" 'alimentation combobox
txt_sav_etat.AddItem "REMISE EN PRODUCTION" 'alimentation combobox
txt_sav_etat.AddItem "TERMINER" 'alimentation combobox
'ALERTE SAV
txt_sav_alerte.AddItem "NORMALE" 'alimentation combobox
txt_sav_alerte.AddItem "URGENT" 'alimentation combobox
txt_sav_alerte.AddItem "EXTREME" 'alimentation combobox
For I = 1 To PCOM.Rows.Count
ML = CByte(Month(PCOM(I, 8)))
If ML = MEC Then
LI = PCLI.Columns(1).Find(PCOM(I, 1), , xlValues, xlWhole).Row - 1
Me.lst_recep_mois.ColumnWidths = "30;50;50;70;45"
Me.lst_recep_mois.AddItem
Me.lst_recep_mois.Column(0, N) = PCOM(I, 1)
Me.lst_recep_mois.Column(1, N) = PCLI(LI, 2) '& " " & PCLI(LI, 2)
Me.lst_recep_mois.Column(2, N) = PCOM(I, 3)
Me.lst_recep_mois.Column(3, N) = PCOM(I, 8)
Me.lst_recep_mois.Column(4, N) = PCOM(I, 12)
'sur le même principe tu rajouteras les deux dernières colonnes
N = N + 1
Next I
For I = 2 To OCLI.Range("A" & Rows.Count).End(xlUp).Row
i2 = OCOM.Range("A:A").Find(OCLI.Range("A" & I), lookat:=xlWhole).Row
lst_rechercher.AddItem
lst_rechercher.Column(0, lst_rechercher.ListCount - 1) = OCLI.Range("A" & I)
lst_rechercher.Column(1, lst_rechercher.ListCount - 1) = OCLI.Range("B" & I) _
& " " & OCLI.Range("C" & I)
lst_rechercher.Column(2, lst_rechercher.ListCount - 1) = OCOM.Range("C" & i2)
lst_rechercher.Column(3, lst_rechercher.ListCount - 1) = OCOM.Range("D" & i2)
lst_rechercher.Column(4, lst_rechercher.ListCount - 1) = OCOM.Range("B" & i2)
Next I
For i3 = 2 To OSAV.Range("A" & Rows.Count).End(xlUp).Row
lst_sav_liste.ColumnWidths = "30;45;45;45;45"
lst_sav_liste.AddItem
lst_sav_liste.Column(0, lst_sav_liste.ListCount - 1) = OSAV.Range("A" & i3)
lst_sav_liste.Column(1, lst_sav_liste.ListCount - 1) = OSAV.Range("B" & i3)
lst_sav_liste.Column(2, lst_sav_liste.ListCount - 1) = OSAV.Range("C" & i3)
lst_sav_liste.Column(3, lst_sav_liste.ListCount - 1) = OSAV.Range("D" & i3)
lst_sav_liste.Column(4, lst_sav_liste.ListCount - 1) = OSAV.Range("E" & i3)
lst_sav_liste.Column(5, lst_sav_liste.ListCount - 1) = OSAV.Range("F" & i3)
Next i3
