Est-ce que quelqu'un peut-il m'expliquer ce code et comment l'intégrer 'si correct) dans mon PT?
Il permettrait d'ajouter une colonne dans un PIVOT Table afin d'insérer des commentaires et de les mémoriser.
Je ne suis pas spécialiste VBA,
Dim ShComments As Worksheet
Dim ColCustomer As Integer
Dim ColComments As Integer
Dim r As Long
With PivotTables("Pivot All GBP")
ColCustomer = .PivotFields("Customer").LabelRange.Column
With .TableRange1
ColComments = .Columns.Count - .Column + 2
If Application.Intersect(Target, Columns(ColComments)) Is Nothing Then Exit Sub
On Error Resume Next
Set ShComments = Worksheets("Comments")
If Err <> 0 Then
Err.Clear
Set ShComments = Worksheets.Add(After:=Me)
Me.Activate
With ShComments
ShComments.Name = "Comments"
.Cells(1, 1).Value = "Customer"
.Cells(1, 2).Value = "Comment"
On Error GoTo 0
With ShComments
If WorksheetFunction.CountIf(.Columns(1), Cells(Target.Row, ColCustomer).Value) > 0 Then
r = WorksheetFunction.Match(Cells(Target.Row, ColCustomer).Value, .Columns(1), False)
r = .Cells(.Rows.Count, 1).End(xlUp).Row + 1
.Cells(r, 1).Value = Cells(Target.Row, ColCustomer).Value
.Cells(r, 2).Value = Target.Value
Private Sub Worksheet_Calculate()
Dim RngCustomer As Range
Dim Cell As Range
Dim r As Long
If Err <> 0 Then
Err.Clear
Exit Sub
On Error GoTo 0
Set RngCustomer = .PivotFields("Customer").DataRange
With .TableRange1
With ShComments
For Each Cell In RngCustomer
If WorksheetFunction.CountIf(.Columns(1), Cell.Value) > 0 Then
r = WorksheetFunction.Match(Cell.Value, .Columns(1), False)
Cells(Cell.Row, ColComments).Value = .Cells(r, 2).Value
Cells(Cell.Row, ColComments).Value = ""
Next Cell
When comments are added the Worksheet_Change event procedure stores them in a new worksheet. When the pivot table is refreshed the Worksheet_Calculate event procedure reads the values form that sheet and updates them.
