Enregistrement sans macro & Inputbox
J'ai un problème qui est difficile à résoudre.
J'ai un fichier excel avec macros maintenant je le veux enregistrer sans macro .xlsx mais il me doit demander le nom du fichier et après le répertoire. Mais je reçoit un message d'erreur Où est la le problème?
Sub Speichern()
    Dim strCopyName As String
    Dim strPath As String
    Dim strName As String
    Dim Ret
    Dateiname = InputBox("Après l'enregistrement le fichier se trouve sur votre desktop !" & vbCrLf & vbCrLf & "Entrer le nom du fichier:", "ENREGISTREMENT SANS MACRO")
    'If Dateiname = "" Then
    strPath = ActiveWorkbook.Path
    strName = ActiveWorkbook.Name
    Ret = BrowseForFolder("C:\")
    strCopyName = Ret & Dateiname
    ActiveWorkbook.SaveAs strCopyName, FileFormat:=xlOpenXMLWorkbook
    ActiveWorkbook.SaveAs strPath & "\" & strName, FileFormat:=xlOpenXMLWorkbookMacroEnabled
       'End If
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
     'Function purpose:  To Browser for a user selected folder.
     'If the "OpenAt" path is provided, open the browser at that directory
     'NOTE:  If invalid, it will open at the Desktop level
    Dim ShellApp As Object
     'Create a file browser window at the default folder
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
     'Set the folder to that selected.  (On error in case cancelled)
    On Error Resume Next
    BrowseForFolder = ShellApp.self.Path
    On Error GoTo 0
     'Destroy the Shell Application
    Set ShellApp = Nothing
     'Check for invalid or non-entries and send to the Invalid error
     'handler if found
     'Valid selections can begin L: (where L is a letter) or
     '\\ (as in \\servername\sharename.  All others are invalid
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
     'If it was determined that the selection was invalid, set to False
    BrowseForFolder = False
End Function
quel message d'erreur?
printscreen
Au lieu de :
utilise :
    strCopyName = Ret & "\" & Dateiname
ric
Maintenant il me donne une erreur syntax
printscreen1
Sur ma machine, le code corrigé fonctionne bien.
ric
Voici le fichier test ...
ric
Aaah maintenant il marche aussi sur ma machine j'ai pas mis les "&" Très bien merci beaucoup
ric
Bonjour Ric,
J'ai remarquer aussi dans ton fichier que si tu click sur "annuler" dans la deuxième fenêtre pour faire la sélection du répertoire alors il donne de nouveau un message d'erreur
printscreen
Effectivement, je n'avais pas géré les annulations ... désolé.
Voici le fichier avec les corrections.
On peut annuler à l'étape Inputbox ou à la seconde étape, lors du choix du dossier de destination.
ric
Bonjour Ric,
J'ai changer un peut la macro mais maintenant de nouveau le problème avec le deuxième Annuler
Sub Enregistrement_sans_macro()
    Dim Dateiname As String
    Dim Reponse As String
    Dim Ret
    Application.UserName = UserName
Retry:
    Reponse = InputBox("Quel est est le nom du fichier ?", "ENREGISTREMENT SANS MACRO")
  If StrPtr(Reponse) = 0 Then
  Exit Sub
    Dateiname = Reponse
    If Reponse = "" Then
    MsgBox "Enregistrement sans caractères pas possible !", vbCritical, "Service de documentation juridique"
GoTo Retry
    Ret = BrowseForFolder("C:\ & Username")
    If Ret = "" Then Exit Sub
    BrowseForFolder(0, "Tu dois sélectionner ou créer un dossier !", 0, OpenAt)
    On Error GoTo 0
     'handler if found
    Case Is = ":"
    Case Is = "\"
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
End Function
Tu n'as pas utilisé la Function contenue dans mon fichier, je l'ai légèrement modifiée pour gérer l'annulation à la 2e étape ... Celle-ci ...
    On Error Resume Next     ' ric correction annuler ( remonté ici )
    If ShellApp Is Nothing Then Exit Function     ' ric correction annuler
    On Error GoTo 0
     'handler if found
    Case Is = ":"
    Case Is = "\"
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
End Function
ric
Rechercher des sujets similaires à "enregistrement macro inputbox"
