Combiné 2 beforedoubleclic ???
P
Bonjour le forum.
Voila ma question est très claire. Comment combiné c'Est deux formules (je suis incapable de mettre 2 beforedoubleclic dans la meme feuil.
A,b,c,Dcoche sont des nom défini.
If Intersect(Range("Acoche, Bcoche"), Target) Is Nothing Then Exit Sub
If IsEmpty(Target) Then
Target = "X"
Cancel = True
If Target = "X" Then
Target = "R"
Cancel = True
If Intersect(Range("Ccoche, Dcoche"), Target) Is Nothing Then Exit Sub
Target = "X"
Cancel = True
Target = "D"
Cancel = True
End SubMerci d'avance a tous ceux qui pourront m'aider!
Peri
f
essaie avec ce code :
If Not Intersect(Union(Range("Acoche"), Range("Bcoche")), Target) Is Nothing Then
Target = "X"
ElseIf Target = "X" Then
Target = "R"
Cancel = True
ElseIf Not Intersect(Range("Ccoche, Dcoche"), Target) Is Nothing Then
Target = "X"
Target = "D"
Cancel = True
End SubP
Nickel, Merci beaucoup Felix
Voici le code final, qui pemet de créé une sorte de boucle ^^
If Not Intersect(Range("Acoche, Bcoche"), Target) Is Nothing Then
Target = "X"
Target = "R"
ElseIf Target = "R" Then
Target = ""
Cancel = True
Target = "X"
Target = "D"
ElseIf Target = "D" Then
Target = ""
Cancel = True
