Combiné 2 beforedoubleclic ???
Bonjour le forum.
Voila ma question est très claire. Comment combiné c'Est deux formules (je suis incapable de mettre 2 beforedoubleclic dans la meme feuil.
A,b,c,Dcoche sont des nom défini.
If Intersect(Range("Acoche, Bcoche"), Target) Is Nothing Then Exit Sub
If IsEmpty(Target) Then
    Target = "X"
    Cancel = True
If Target = "X" Then
    Target = "R"
    Cancel = True
If Intersect(Range("Ccoche, Dcoche"), Target) Is Nothing Then Exit Sub
    Target = "X"
    Cancel = True
    Target = "D"
    Cancel = True
Merci d'avance a tous ceux qui pourront m'aider!
Peri
essaie avec ce code :
If Not Intersect(Union(Range("Acoche"), Range("Bcoche")), Target) Is Nothing Then
        Target = "X"
    ElseIf Target = "X" Then
        Target = "R"
    Cancel = True
ElseIf Not Intersect(Range("Ccoche, Dcoche"), Target) Is Nothing Then
        Target = "X"
        Target = "D"
    Cancel = True
Nickel, Merci beaucoup Felix
Voici le code final, qui pemet de créé une sorte de boucle ^^
If Not Intersect(Range("Acoche, Bcoche"), Target) Is Nothing Then
        Target = "X"
        Target = "R"
    ElseIf Target = "R" Then
        Target = ""
    Cancel = True
        Target = "X"
        Target = "D"
    ElseIf Target = "D" Then
        Target = ""
    Cancel = True
13facture.xlsx (81.14 Ko)
Rechercher des sujets similaires à "combine beforedoubleclic"
