Query count si X + date ne renvoi aucun résultat
Finalement, j'ai trouvé ça :
=QUERY(arrayformula(TEXTE('Solution Fil base dates'!A2:D14;"yyyy-MM-dd"));"SELECT count(Col1) WHERE Col4 <=  '"&TEXTE(A1;"yyyy-MM-dd")&"' label count(Col1)''")
Merveilleux, merci beaucoup.
J'essaie de l'adapter à du multi feuille basé sur ta proposition :
=query({'Base1'!F2:F;'Base2'!F2:F;'Base3'!F2:F;'Base4'!F2:F;'Base5'!F2:F;'Base6'!F2:F};"select count(Col6) where Col6 like '"&A2&"' label count(Col6)''")
j'ai tenté :
=QUERY(arrayformula(TEXTE({'Base1'!A2:V;'Base2'!A2:V}"yyyy-MM-dd"));"SELECT count(Col1) WHERE Col4 <=  '"&TEXTE(A15;"yyyy-MM-dd")&"' and (Col6 like '%XXXX%' or Col6 like '%YYYY%') and (Col2 like 'AA' or Col2 like 'BB') and Col22 like '%Envoyé%' label count(Col1)''")
mais aussi :
=QUERY(arrayformula(TEXTE({'Base1'!A2:V;"yyyy-MM-dd";'Base2'!A2:V;"yyyy-MM-dd"}));"SELECT count(Col1) WHERE Col4 <=  '"&TEXTE(A15;"yyyy-MM-dd")&"' and (Col6 like '%XXXX%' or Col6 like '%YYYY%') and (Col2 like 'AA' or Col2 like 'BB') and Col22 like '%Envoyé%' label count(Col1)''")
sans résultats :(
à tester :
=QUERY(arrayformula(TEXTE({'Base1'!A2:V;'Base2'!A2:V};"yyyy-MM-dd"));"SELECT count(Col1) WHERE Col4 <=  '"&TEXTE(A15;"yyyy-MM-dd")&"' and (Col6 like '%XXXX%' or Col6 like '%YYYY%') and (Col2 like 'AA' or Col2 like 'BB') and Col22 like '%Envoyé%' label count(Col1)''")
ou
=QUERY({arrayformula(TEXTE('Base1'!A2:V;"yyyy-MM-dd"));arrayformula(TEXTE('Base2'!A2:V;"yyyy-MM-dd"))};"SELECT count(Col1) WHERE Col4 <=  '"&TEXTE(A15;"yyyy-MM-dd")&"' and (Col6 like '%XXXX%' or Col6 like '%YYYY%') and (Col2 like 'AA' or Col2 like 'BB') and Col22 like '%Envoyé%' label count(Col1)''")
Rechercher des sujets similaires à "query count date renvoi aucun resultat"
