Macro impressions successives
Bonjour, je souhaite lancer 2 impressions successives avec des paramètres différents. J'ai effectuée une macro classique que j'ai intégrée dans le code d'un bouton de commande. Mais seule la première impression fonctionne, pour la deuxième j'ai un "bogue". C'est cette commande qui a l'air de poser problème : "Application.PrintCommunication = True". Je vous joins le code. Merci pour votre aide. Stéphane
' PrintAffichage1 Macro
ActiveSheet.Unprotect
Range("A4").Select
With ActiveSheet.PivotTables("Tableau croisé dynamique7").PivotFields( _
"Emplacement")
.PivotItems("").Visible = False
ActiveSheet.PivotTables("Tableau croisé dynamique7").PivotFields("Emplacement") _
.LayoutPageBreak = True
ActiveWindow.SelectedSheets.PrintOut Copies:=1, Collate:=True, _
IgnorePrintAreas:=False
.LayoutPageBreak = False
Application.PrintCommunication = False
With ActiveSheet.PageSetup
.PrintTitleRows = "$2:$3"
.PrintTitleColumns = ""
ActiveSheet.PageSetup.PrintArea = ""
.LeftHeader = ""
.CenterHeader = ""
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.LeftMargin = Application.InchesToPoints(0.25)
.RightMargin = Application.InchesToPoints(0.25)
.TopMargin = Application.InchesToPoints(0.75)
.BottomMargin = Application.InchesToPoints(0.75)
.HeaderMargin = Application.InchesToPoints(0.3)
.FooterMargin = Application.InchesToPoints(0.3)
.PrintHeadings = False
.PrintGridlines = False
.PrintComments = xlPrintSheetEnd
.PrintQuality = -2
.CenterHorizontally = False
.CenterVertically = False
.Orientation = xlLandscape
.Draft = False
.PaperSize = xlPaperA4
.FirstPageNumber = xlAutomatic
.Order = xlDownThenOver
.BlackAndWhite = False
.Zoom = True
.FitToPagesWide = 1
.FitToPagesTall = False
.PrintErrors = xlPrintErrorsDisplayed
.OddAndEvenPagesHeaderFooter = False
.DifferentFirstPageHeaderFooter = False
.ScaleWithDocHeaderFooter = True
.AlignMarginsHeaderFooter = True
.EvenPage.LeftHeader.Text = ""
.EvenPage.CenterHeader.Text = ""
.EvenPage.RightHeader.Text = ""
.EvenPage.LeftFooter.Text = ""
.EvenPage.CenterFooter.Text = ""
.EvenPage.RightFooter.Text = ""
.FirstPage.LeftHeader.Text = ""
.FirstPage.CenterHeader.Text = ""
.FirstPage.RightHeader.Text = ""
.FirstPage.LeftFooter.Text = ""
.FirstPage.CenterFooter.Text = ""
.FirstPage.RightFooter.Text = ""
.LeftHeader = ""
.CenterHeader = ""
.RightHeader = ""
.LeftFooter = ""
.CenterFooter = ""
.RightFooter = ""
.PrintQuality = -2
.Draft = False
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 1
ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True _
, AllowFiltering:=True
Range("A1").Select
End SubBonjour, je relance cette question. Merci.
legreffier
Invité
Bonjour Legreffier
Vous avez bien fait
de ce que je vois et que je comprends, le code peut être réduit à ceci
Dim Ind As Integer
' Avec l'objet conteneur parent
With ActiveSheet
.Unprotect
' Mise en page
With .PageSetup
.LeftMargin = Application.CentimetersToPoints(0.8)
.RightMargin = Application.CentimetersToPoints(0.8)
.TopMargin = Application.CentimetersToPoints(0.8)
.BottomMargin = Application.CentimetersToPoints(0.8)
.Zoom = True
.FitToPagesWide = 1
' Définir le pivot table
With .PivotTables("Tableau croisé dynamique7")
.PivotFields("Emplacement").PivotItems("").Visible = False
.PivotFields("Emplacement").LayoutPageBreak = True
' Imprimer 2 fois
For Ind = 1 To 2
.PrintOut Copies:=1, Collate:=True, IgnorePrintAreas:=False
Next Ind
' supprimer saut de page du pivot !?
.PivotFields("Emplacement").LayoutPageBreak = False
' Reprotéger la feuille
.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True, AllowFiltering:=True
End SubA tester
Bonjour BrunoM45, c'est nickel ! Merci à vous et bon we :-)
