Macro impressions successives
Bonjour, je souhaite lancer 2 impressions successives avec des paramètres différents. J'ai effectuée une macro classique que j'ai intégrée dans le code d'un bouton de commande. Mais seule la première impression fonctionne, pour la deuxième j'ai un "bogue". C'est cette commande qui a l'air de poser problème : "Application.PrintCommunication = True". Je vous joins le code. Merci pour votre aide. Stéphane
' PrintAffichage1 Macro
    ActiveSheet.Unprotect
    Range("A4").Select
    With ActiveSheet.PivotTables("Tableau croisé dynamique7").PivotFields( _
        "Emplacement")
        .PivotItems("").Visible = False
    ActiveSheet.PivotTables("Tableau croisé dynamique7").PivotFields("Emplacement") _
        .LayoutPageBreak = True
    ActiveWindow.SelectedSheets.PrintOut Copies:=1, Collate:=True, _
        IgnorePrintAreas:=False
        .LayoutPageBreak = False
    Application.PrintCommunication = False
    With ActiveSheet.PageSetup
        .PrintTitleRows = "$2:$3"
        .PrintTitleColumns = ""
    ActiveSheet.PageSetup.PrintArea = ""
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .LeftMargin = Application.InchesToPoints(0.25)
        .RightMargin = Application.InchesToPoints(0.25)
        .TopMargin = Application.InchesToPoints(0.75)
        .BottomMargin = Application.InchesToPoints(0.75)
        .HeaderMargin = Application.InchesToPoints(0.3)
        .FooterMargin = Application.InchesToPoints(0.3)
        .PrintHeadings = False
        .PrintGridlines = False
        .PrintComments = xlPrintSheetEnd
        .PrintQuality = -2
        .CenterHorizontally = False
        .CenterVertically = False
        .Orientation = xlLandscape
        .Draft = False
        .PaperSize = xlPaperA4
        .FirstPageNumber = xlAutomatic
        .Order = xlDownThenOver
        .BlackAndWhite = False
        .Zoom = True
        .FitToPagesWide = 1
        .FitToPagesTall = False
        .PrintErrors = xlPrintErrorsDisplayed
        .OddAndEvenPagesHeaderFooter = False
        .DifferentFirstPageHeaderFooter = False
        .ScaleWithDocHeaderFooter = True
        .AlignMarginsHeaderFooter = True
        .EvenPage.LeftHeader.Text = ""
        .EvenPage.CenterHeader.Text = ""
        .EvenPage.RightHeader.Text = ""
        .EvenPage.LeftFooter.Text = ""
        .EvenPage.CenterFooter.Text = ""
        .EvenPage.RightFooter.Text = ""
        .FirstPage.LeftHeader.Text = ""
        .FirstPage.CenterHeader.Text = ""
        .FirstPage.RightHeader.Text = ""
        .FirstPage.LeftFooter.Text = ""
        .FirstPage.CenterFooter.Text = ""
        .FirstPage.RightFooter.Text = ""
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = -2
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .FitToPagesTall = 1
    ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True _
        , AllowFiltering:=True
    Range("A1").Select
Bonjour, je relance cette question. Merci.
legreffier
Bonjour Legreffier
Vous avez bien fait
de ce que je vois et que je comprends, le code peut être réduit à ceci
  Dim Ind As Integer
  ' Avec l'objet conteneur parent
  With ActiveSheet
    .Unprotect
    ' Mise en page
    With .PageSetup
      .LeftMargin = Application.CentimetersToPoints(0.8)
      .RightMargin = Application.CentimetersToPoints(0.8)
      .TopMargin = Application.CentimetersToPoints(0.8)
      .BottomMargin = Application.CentimetersToPoints(0.8)
      .Zoom = True
      .FitToPagesWide = 1
    ' Définir le pivot table
    With .PivotTables("Tableau croisé dynamique7")
      .PivotFields("Emplacement").PivotItems("").Visible = False
      .PivotFields("Emplacement").LayoutPageBreak = True
    ' Imprimer 2 fois
    For Ind = 1 To 2
    .PrintOut Copies:=1, Collate:=True, IgnorePrintAreas:=False
    Next Ind
    ' supprimer saut de page du pivot !?
      .PivotFields("Emplacement").LayoutPageBreak = False
    ' Reprotéger la feuille
    .Protect DrawingObjects:=True, Contents:=True, Scenarios:=True, AllowFiltering:=True
A tester
Bonjour BrunoM45, c'est nickel ! Merci à vous et bon we :-)
Rechercher des sujets similaires à "macro impressions successives"
