Hello,
Un exemple brut qu'il faudra adapter au besoin :
Sub WordArray()
Dim WordApp As Object, WordDoc As Object
Dim bytLimitInf As Byte, bytLimitSup As Byte, bytNbArrayRow As Byte
Dim bytArrayWordCol As Byte, bytTmpRow As Byte, bytTmpCol As Byte
' ######### Partie Excel ##########
bytLimitInf = 4 'Premiere ligne de la colonne Excel
bytLimitSup = 28 'Derniere ligne de la colonne Excel
bytNbArrayRow = (bytLimitSup - bytLimitInf) ' Nb de lignes du tableau Word
' ######### Partie Word ##########
bytArrayWordCol = 4 'Nb Col du tableau word
On Error Resume Next
Set WordApp = GetObject(, "Word.Application")
If Err.Number = 429 Then
Err.Clear
Set WordApp = CreateObject("Word.Application")
On error goto 0
WordApp.Visible = True
WordApp.Activate
Set WordDoc = WordApp.Documents.Add
WordDoc.Tables.Add Range:=WordDoc.Range(0, 0), NumRows:=bytNbArrayRow, NumColumns:=bytArrayWordCol
With WordDoc.Tables(1)
For bytTmpRow = 1 To bytNbArrayRow
For bytTmpCol = 1 To bytArrayWordCol
.cell(bytTmpRow, bytTmpCol) = "Ligne : " & bytTmpRow
Next bytTmpCol
Next bytTmpRow
.Borders.Enable = True
