Bonjour le forum,
Je n'arrive pas à mettre le code ci-dessous sur 2 lignes => exemple scinder à partir de "ggg"
Case "aaa", "bbb", "ccc", "ddd", "eee", "fff", "ggg", "hhh", "iii", "jjj", "kkk", "lll", "mmm", "nnn"
De la macro ci-dessous
Private Sub Workbook_SheetBeforeDoubleClick(ByVal sh As Object, ByVal Target As Range, Cancel As Boolean)
Dim Indice As Integer, NbColonne As Integer
Dim Tb, TbCoul, X, TbFont, Label As String
Dim Ligne As Integer
If Target.Address = "$A$2" Then Application.Run ("AfficherMasquerLignesVides")
Cancel = True
If Target.Address = "$A$2" Then Application.Run ("DeprotegerFeuilles")
Cancel = True
Select Case UCase(sh.Name) ' Cette ligne permet de modifier l'onglet. Exemple "aaa" à la place de "AAA" sans modifier la macro "AAA"
NbColonne = 2
End Select
Ligne = Range("A" & Rows.Count).End(xlUp).Row
If (Target.Row = Ligne And Range("A" & Ligne) <> "") Or (Target.Row = Ligne + 1 And Range("A" & Ligne + 1) = "") Then
If Target.Column = NbColonne + 1 And Target.Row >= 3 Then ' And Range("A" & Target.Row) <> "" Then
TbFont = Array(5, 1)
TbCoul = Array(35, 40)
Tb = Array("", "Oui")
Cancel = True
X = UCase(Trim(Target))
If UBound(Filter(Tb, X, compare:=vbTextCompare)) >= 0 Then
Indice = Application.Match(X, Tb, 0) Mod (1 + UBound(Tb))
Label = Tb(Indice)
With Target
.Value = Label
.Interior.ColorIndex = TbCoul(Indice)
.Font.ColorIndex = TbFont(Indice)
With ActiveCell.Offset(0, -NbColonne).Resize(1, NbColonne)
If Label = "Oui" Then
.Font.Strikethrough = True
Target.Offset(, 1).Value = Date
Target.Offset(, -2) = Application.Proper(Format(Date, "dddd dd mmmm yyyy"))
Target.Offset(, -1).Value = sh.Name
.Font.Strikethrough = False
Target.Offset(, 1).ClearContents
Target.Offset(, -2).ClearContents
Target.Offset(, -1).ClearContents
Range("A1").Select
Merci pour vos éventuels retours
