Donc voilà le code modifié mais j'ai encore des doutes :
#If VBA7 Then
Public Declare PtrSafe Function GetAsyncKeyState Lib "user32.dll" (ByVal vKey As LongPtr) As Integer
Public Declare PtrSafe Function GetWindowDC Lib "user32" (ByVal hwnd As LongPtr) As Long
Public Declare PtrSafe Function GetCursorPos Lib "user32" (lpPoint As POINT) As Long
Public Declare PtrSafe Function GetPixel Lib "gdi32" (ByVal hdc As LongPtr, ByVal x As LongPtr, ByVal y As LongPtr) As Long
Public Declare PtrSafe Function ReleaseDC Lib "user32" (ByVal hwnd As LongPtr, ByVal hdc As LongPtr) As Long
Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As LongPtr)
#Else
Public Declare Function GetAsyncKeyState Lib "user32.dll" (ByVal vKey As Long) As Integer
Public Declare Function GetWindowDC Lib "user32" (ByVal hwnd As Long) As Long
Public Declare Function GetCursorPos Lib "user32" (lpPoint As POINT) As Long
Public Declare Function GetPixel Lib "gdi32" (ByVal hdc As Long, ByVal x As Long, ByVal y As Long) As Long
Public Declare Function ReleaseDC Lib "user32" (ByVal hwnd As Long, ByVal hdc As Long) As Long
Public Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
#End If
Public Type POINT
x As Long
y As Long
End Type
N'y a t-il pas une conversion à apporter aussi à cette partie pour que tout fonctionne ?
Public Type POINT
x As Long
y As Long
End Type
