Raccourcicement d'un code
Salut !
Je poste ici pour demander une méthode afin de raccourcir mon code ci-dessous.
Dim note As Date
note = DatePart("m", Date)
Choix = TextBox_Choix.Value
If Choix = "Croix Changée" And note = 1 Then
Sheets("Feuil1").Range("C4").Value = Sheets("Feuil1").Range("C4").Value + 1
Sheets("Feuil2").Range("B3").Value = Sheets("Feuil2").Range("B3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 2 Then
    Sheets("Feuil1").Range("D4").Value = Sheets("Feuil1").Range("D4").Value + 1
    Sheets("Feuil2").Range("C3").Value = Sheets("Feuil2").Range("C3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 3 Then
    Sheets("Feuil1").Range("E4").Value = Sheets("Feuil1").Range("E4").Value + 1
    Sheets("Feuil2").Range("D3").Value = Sheets("Feuil2").Range("D3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 4 Then
    Sheets("Feuil1").Range("F4").Value = Sheets("Feuil1").Range("F4").Value + 1
    Sheets("Feuil2").Range("E3").Value = Sheets("Feuil2").Range("E3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 5 Then
    Sheets("Feuil1").Range("G4").Value = Sheets("Feuil1").Range("G4").Value + 1
    Sheets("Feuil2").Range("F3").Value = Sheets("Feuil2").Range("F3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 6 Then
    Sheets("Feuil1").Range("H4").Value = Sheets("Feuil1").Range("H4").Value + 1
    Sheets("Feuil2").Range("G3").Value = Sheets("Feuil2").Range("G3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 7 Then
    Sheets("Feuil1").Range("I4").Value = Sheets("Feuil1").Range("I4").Value + 1
    Sheets("Feuil2").Range("H3").Value = Sheets("Feuil2").Range("H3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 8 Then
    Sheets("Feuil1").Range("J4").Value = Sheets("Feuil1").Range("J4").Value + 1
    Sheets("Feuil2").Range("I3").Value = Sheets("Feuil2").Range("I3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 9 Then
    Sheets("Feuil1").Range("K4").Value = Sheets("Feuil1").Range("K4").Value + 1
    Sheets("Feuil2").Range("J3").Value = Sheets("Feuil2").Range("J3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 10 Then
    Sheets("Feuil1").Range("L4").Value = Sheets("Feuil1").Range("L4").Value + 1
    Sheets("Feuil2").Range("K3").Value = Sheets("Feuil2").Range("K3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 11 Then
    Sheets("Feuil1").Range("M4").Value = Sheets("Feuil1").Range("M4").Value + 1
    Sheets("Feuil2").Range("L3").Value = Sheets("Feuil2").Range("L3").Value + 1
    ElseIf Choix = "Croix Changée" And note = 12 Then
    Sheets("Feuil1").Range("N4").Value = Sheets("Feuil1").Range("N4").Value + 1
    Sheets("Feuil2").Range("M3").Value = Sheets("Feuil2").Range("M3").Value + 1
UserForm1.Hide
Imaginez que je le fais 24 fois sauf que ca passe pas la commande est trop longue
Il s'agit d'un code qui me permet d'envoyer dans deux tableau un +1 en fonction de ce qui a été sélectionné dans une pop up et en fonction du mois.
Est ce que quelqu'un aurait une idée de comment je pourrais le raccourcir ?
TMM
bonjour,
une proposition (non testée, faute d'avoir ton classeur)
    Dim note As Integer
    note = Month(Date)
    If Choix = "Croix Changée" Then
        Sheets("Feuil1").Cells(4, 2 + note).Value = Sheets("Feuil1").Cells(4, 2 + note).Value + 1
        Sheets("Feuil2").Cells(3, 1 + note).Value = Sheets("Feuil2").Cells(3, 1 + note).Value + 1
    UserForm1.Hide
Salut h2so4,
Je t'ai mis l'excel en question, le code est dans le userform1
bonjour,
je te laisse tester.
On dirait que ca marche mais est ce que tu pourrais m'expliquer comment ca marche exactement ?
En tout cas merci
re-bonjour,
si le choix est croix changée on ajoute 1 dans la cellule de la feuil1 en ligne 4 colonne 3 quand note vaut 1, colonne 4 quand note vaut 2, ...
donc la colonne est donnée par la formule : 2 + note
donc on ajoute 1 dans la cellule de la feuille 1 (ligne 4, colonne 2+ note),
on applique un raisonnement similaire pour la feuille 2 (ligne 3 , mais colonne en fonction de note est donné par la formule 1 + note)
Du coup pour le réutiliser l'année prochaine je dois rechanger le code ? Parce qu'en plus il commence en mai
si tu veux vraiment raccourcir ton code. fais en sorte d'écrire tes réparations dans un journal, avec date, type de panne, type de réparation, type de matériel, etc... et utilise les fonctions standard d' Excel pour tes statistiques (en l'occurrence TCD)
ok merci pour ton aide
Rechercher des sujets similaires à "raccourcicement code"
