Insertion Signature
E
Je souhaite générer un mail avec du texte, une image (au centre) et ma signature (à la fin).
J'utilise le code ci-dessous :
Sub createMailWithSignature()
Dim objMsg As Object
Dim OutMail As Object
Dim wb As Workbook
Dim wDoc As Object
Set wb = ActiveWorkbook
Set objMsg = CreateObject("Outlook.Application")
Set OutMail = objMsg.CreateItem(olMailItem)
Set wDoc = OutMail.GetInspector.WordEditor
With OutMail
.Display
.To = "xxx@xxx.com"
.CC = "xxx@xxx.com"
.Subject = "SUJET"
wb.Sheets(1).Range("A2:J9").CopyPicture
Set Rng = wDoc.Content
Rng.Application.Selection.Paste
If Not (Rng Is Nothing) Then
Rng.InsertBefore ("Bonjour" & vbCr & vbCr & "blablabla" & vbCr & vbCr)
Rng.InsertAfter (vbCr & vbCr & "blablabla" & vbCr & vbCr & "Cordialement," & vbCr)
Set Rng = Nothing
InsertSignature OutMail, "RT"
End SubEt la fonction suivante :
Sub InsertSignature(OutMail As Object, SignatureName As String)
Dim wd As Object, obSelection As Object
Dim enviro, strSigFilePath
Const wdStory = 6
Const wdParagraph = 4
Const wdGoToBookmark = -1
Const wdExtend = 0
Const wdSortByName = 0
enviro = CStr(Environ("appdata"))
strSigFilePath = enviro & "\Microsoft\Signatures\"
Set wd = OutMail.GetInspector.WordEditor
Set obSelection = wd.Application.Selection
obSelection.Move wdStory, -1
obSelection.Move wdParagraph, 1
obSelection.Paragraphs.Add
Dim oBookmark
Set oBookmark = obSelection.Bookmarks.Add("_Sig", obSelection.Range)
If Dir(strSigFilePath & SignatureName & ".htm", vbNormal) <> "" Then
obSelection.InsertFile Filename:=strSigFilePath & SignatureName & ".htm", Range:="", ConfirmConversions:= _
False, Link:=False, Attachment:=False
obSelection.GoTo What:=wdGoToBookmark, Name:="_Sig"
obSelection.EndKey Unit:=wdStory, Extend:=wdExtend
With wd.Bookmarks
.Add Range:=obSelection.Range, Name:="_MailAutoSig"
.DefaultSorting = wdSortByName
.ShowHidden = False
End SubLe code fonctionne mais le soucis c'est qu'il insère la signature après le "Bonjour" au lieu de mettre à la fin
Avez-vous une solution ?
Salut Erhan,
Un simple Call InsertSignature ne fonctionne pas ?
Sinon, regarde ici, une autre manière de mettre une signature
Bonne soirée,
Baboutz
Bonjour Erhan, bonjour Baboutz
Pour insérer ma signature, je faisais très simplement :
With OutMail
.htmlbody = "Bla bla " & .htmlbody
' ... le reste des options
.display
end with
