Erreur 1004 : la methode Paste de la classe Worksheet a échoué
J'ai cette erreur (" Erreur 1004 : la methode Paste de la classe Worksheet a échoué ") qui s'affiche lorsque j'utilise cette macro :
Sub Clean()
activesheet.Unprotect "??"
activesheet.Range("R18").Value = "/"
activesheet.Range("R19").Value = "/"
activesheet.Range("R12").Value = "/"
activesheet.Range("R13").Value = "/"
activesheet.Range("R6").Value = "/"
activesheet.Range("R7").Value = "/"
activesheet.Range("R4").Value = ""
activesheet.Range("Supr.4").Value = "1"
activesheet.Protect "??", True, True, True
End SubSauf que l'erreur ne s'affiche pas tjr, voir jamais...
J'ai souvent ce problème lorsque j'utilise la macro juste après avoir ouvert mon excel.
Pour information lorsque j'utilise ma macro ces macros qui s'active toute seul.
If Not Intersect(Target, activesheet.Range("R6")) Is Nothing Then
If Range("R6") <> "/" Then
activesheet.Range("Supr.1") = ""
activesheet.Range("R7").Value = "a"
If Range("R6") = "/" Then
If Not Intersect(Target, activesheet.Range("R12")) Is Nothing Then
If Range("R12") <> "/" Then
activesheet.Range("Supr.2") = ""
activesheet.Range("R13").Value = "b"
If Range("R12") = "/" Then
If Not Intersect(Target, activesheet.Range("R18")) Is Nothing Then
If Range("R18") <> "/" Then
activesheet.Range("Supr.3") = ""
activesheet.Range("R19").Value = "c"
If Range("R18") = "/" Then
If Not Intersect(Target, activesheet.Range("R2")) Is Nothing Then
activesheet.Range("R4") = ""
activesheet.Range("R3") = ""
If Target.Address = "$R$6" Then
'-- suppression
For Each s In activesheet.Shapes
If s.Type = 13 Then
If s.TopLeftCell.Address = Target.Offset(0, -11).Address Then
s.Delete
Next s
If Target <> "" Then
Sheets("DONNEES").Shapes(Target).Copy
Target.Offset(0, 2).Select
activesheet.Activate
activesheet.Paste
Selection.ShapeRange.Left = ActiveCell.Left - 867
Selection.ShapeRange.Top = ActiveCell.Top + 8
Target.Select
End IfMerci pour votre aide les experts de VBA!
Tu as des instructions contradictoires en R6, R12 et R18.
Il faudra choisir soit l'une, soit l'autre.
ric
Salut,
C'est à dire?
Regarde ton code, sur les trois cellules mentionnées, il y a deux instructions qui écrivent au même endoit ...
Exemple :
If Not Intersect(Target, ActiveSheet.Range("R6")) Is Nothing Then
ActiveSheet.Range("Supr.1") = ""
ActiveSheet.Range("R7").Value = "a"
ActiveSheet.Range("R7").Value = "/"
End Ifric
Merci pour ton commentaires, j'ai corrigé ca...On verra bien si j'ai encore le problème.
