Filtres élaborés
Prière de nous aider pour compléter cet userform
merci d'avance
Invité
Prière de ne pas rédiger un texto et de donner des explications
De rien
Les données sont en deux feuilles : "payant" et "gratuit"
Troisième feuille "temp" est lié au userform
payant
gratuit
userform
Explication
codes usf
Private Sub CheckBox1_Click()
Private Sub ComboBox1_Change()
If Me.ComboBox1.Value = "GRATUIT" Then
Me.ComboBox2.Visible = True
Me.ComboBox2.Visible = False
Private Sub ComboBox2_Change()
If Me.ComboBox2 = "" Then
temp.Range("S2").Value = ""
temp.Range("S2").Value = ComboBox2.Text
Private Sub ComboBox3_Change()
If Me.ComboBox3 = "" Or Me.ComboBox3 = "TOUT" Then
temp.Range("E2").Value = ""
' temp.Range("O2").Value = ""
temp.Range("E2").Value = ComboBox3.Text
' temp.Range("O2").Value = ComboBox3.Text
Private Sub ComboBox4_Change()
If Me.ComboBox4 = "" Or Me.ComboBox4 = "TOUT" Then
temp.Range("F2").Value = ""
' temp.Range("P2").Value = ""
temp.Range("F2").Value = ComboBox4.Text
' temp.Range("P2").Value = ComboBox4.Text
Dim LISTArray()
Dim I As Byte
Dim E As Long: E = 0
Dim RW As Long
temp.Range("A4:H500000").Delete Shift:=xlUp
temp.Range("K4:R500000").Delete Shift:=xlUp
Me.ListBox1.Clear
Select Case Me.ComboBox1.Text
Case "TOUT"
Call PAYANT
Call GRATUIT
LRWPAYANT = temp.Range("a100000").End(xlUp).Row
LRWGRATUIT = temp.Range("k100000").End(xlUp).Row
If LRWPAYANT = 3 Then GoTo 1
For RW = 4 To LRWPAYANT
E = E + 1: ReDim Preserve LISTArray(1 To 8, 1 To E)
For I = 1 To 8
LISTArray(I, E) = temp.Cells(RW, I)
If LRWGRATUIT = 3 Then GoTo 2
1 For RW = 4 To LRWGRATUIT
For I = 1 To 8
LISTArray(I, E) = temp.Cells(RW, I + 10)
2 If E > 0 Then
If UBound(LISTArray, 2) > 1 Then
Me.ListBox1.List = Application.Transpose(LISTArray)
Dim c(1 To 1, 1 To 8)
For I = 1 To 8
c(1, I) = LISTArray(I, 1)
Me.ListBox1.List = c
Case "PAYANT"
Call PAYANT
Me.ListBox1.List = temp.Range("a4:h" & LRWPAYANT).Value
Case "GRATUIT"
Call GRATUIT
Me.ListBox1.List = temp.Range("k4:r" & LRWGRATUIT).Value
End Select
TextBox3.Value = Me.ListBox1.ListCount
TextBox4.Value = temp.Range("x1").Value
Effacer
Private Sub DTPicker1_Change()
If Me.ComboBox1.Text = "" Or Me.ComboBox1.Text = "TOUT" Then
temp.Range("T1").Value = DTPicker1.Value
temp.Range("T2").Value = DTPicker1.Value
ElseIf Me.ComboBox1.Text = "PAYANT" Then
ElseIf Me.ComboBox1.Text = "GRATUIT" Then
Private Sub DTPicker2_Change()
temp.Range("U1").Value = DTPicker2.Value
temp.Range("U2").Value = DTPicker2.Value
Private Sub Frame2_Click()
Private Sub UserForm_Activate()
With Me
With .ComboBox1
.AddItem "TOUT"
.AddItem "PAYANT"
.AddItem "GRATUIT"
With .ComboBox2
.AddItem "CARTE"
.AddItem "RECU"
.AddItem "CERTIFICAT"
With .ComboBox3
.AddItem "TOUT"
.AddItem "CSORL"
.AddItem "CGORL"
.AddItem "CML"
.AddItem "URGENCES"
.AddItem "AMY"
.AddItem "AMY2"
.AddItem "APCH"
.AddItem "CSTOMA"
.AddItem "HJSTOM"
With .ComboBox4
.AddItem "TOUT"
.AddItem "CSS"
.AddItem "CSORL"
.AddItem "CGORL"
.AddItem "D296"
.AddItem "D254"
.AddItem "D331"
.AddItem "CTRAMY"
.AddItem "D352"
.AddItem "BAMY"
.AddItem "CSTOMA"
.AddItem "D744"
.AddItem "D736"
.AddItem "ORL"
.AddItem "OPH"
Private Sub UserForm_Click()
End Subcodes module
Sub PAYANT()
Sheets("payant").Range("A1").CurrentRegion.AdvancedFilter Action:=xlFilterCopy, _
CriteriaRange:=temp.Range("A1:I2"), CopyToRange:=temp.Range("A3:H3"), Unique:=False
Sub GRATUIT()
Sheets("Gratuit").Range("A1").CurrentRegion.AdvancedFilter Action:=xlFilterCopy, _
CriteriaRange:=temp.Range("K1:S2"), CopyToRange:=temp.Range("K3:R3"), Unique:=False
Sub Effacer()
With temp
.Range("C2:I2").ClearContents
.Range("t1:u1").ClearContents
.Range("M2:U2").ClearContents
Sub shUF()
UserForm1.Show
End SubExemple de résultats
