Filtres élaborés
Prière de nous aider pour compléter cet userform
merci d'avance
Prière de ne pas rédiger un texto et de donner des explications
De rien
Les données sont en deux feuilles : "payant" et "gratuit"
Troisième feuille "temp" est lié au userform
payant
gratuit
userform
Explication
codes usf
Private Sub CheckBox1_Click()
Private Sub ComboBox1_Change()
    If Me.ComboBox1.Value = "GRATUIT" Then
        Me.ComboBox2.Visible = True
        Me.ComboBox2.Visible = False
Private Sub ComboBox2_Change()
    If Me.ComboBox2 = "" Then
            temp.Range("S2").Value = ""
            temp.Range("S2").Value = ComboBox2.Text
Private Sub ComboBox3_Change()
    If Me.ComboBox3 = "" Or Me.ComboBox3 = "TOUT" Then
            temp.Range("E2").Value = ""
'            temp.Range("O2").Value = ""
            temp.Range("E2").Value = ComboBox3.Text
'            temp.Range("O2").Value = ComboBox3.Text
Private Sub ComboBox4_Change()
    If Me.ComboBox4 = "" Or Me.ComboBox4 = "TOUT" Then
            temp.Range("F2").Value = ""
'            temp.Range("P2").Value = ""
            temp.Range("F2").Value = ComboBox4.Text
'            temp.Range("P2").Value = ComboBox4.Text
Dim LISTArray()
Dim I As Byte
Dim E As Long: E = 0
Dim RW As Long
         temp.Range("A4:H500000").Delete Shift:=xlUp
         temp.Range("K4:R500000").Delete Shift:=xlUp
         Me.ListBox1.Clear
    Select Case Me.ComboBox1.Text
        Case "TOUT"
            Call PAYANT
            Call GRATUIT
            LRWPAYANT = temp.Range("a100000").End(xlUp).Row
            LRWGRATUIT = temp.Range("k100000").End(xlUp).Row
                If LRWPAYANT = 3 Then GoTo 1
                For RW = 4 To LRWPAYANT
                E = E + 1: ReDim Preserve LISTArray(1 To 8, 1 To E)
                           For I = 1 To 8
                                LISTArray(I, E) = temp.Cells(RW, I)
                If LRWGRATUIT = 3 Then GoTo 2
1               For RW = 4 To LRWGRATUIT
                           For I = 1 To 8
                                LISTArray(I, E) = temp.Cells(RW, I + 10)
2               If E > 0 Then
                    If UBound(LISTArray, 2) > 1 Then
                        Me.ListBox1.List = Application.Transpose(LISTArray)
                        Dim c(1 To 1, 1 To 8)
                            For I = 1 To 8
                                 c(1, I) = LISTArray(I, 1)
                        Me.ListBox1.List = c
        Case "PAYANT"
            Call PAYANT
            Me.ListBox1.List = temp.Range("a4:h" & LRWPAYANT).Value
        Case "GRATUIT"
            Call GRATUIT
            Me.ListBox1.List = temp.Range("k4:r" & LRWGRATUIT).Value
    End Select
TextBox3.Value = Me.ListBox1.ListCount
TextBox4.Value = temp.Range("x1").Value
Effacer
Private Sub DTPicker1_Change()
    If Me.ComboBox1.Text = "" Or Me.ComboBox1.Text = "TOUT" Then
        temp.Range("T1").Value = DTPicker1.Value
        temp.Range("T2").Value = DTPicker1.Value
    ElseIf Me.ComboBox1.Text = "PAYANT" Then
    ElseIf Me.ComboBox1.Text = "GRATUIT" Then
Private Sub DTPicker2_Change()
        temp.Range("U1").Value = DTPicker2.Value
        temp.Range("U2").Value = DTPicker2.Value
Private Sub Frame2_Click()
Private Sub UserForm_Activate()
    With Me
        With .ComboBox1
            .AddItem "TOUT"
            .AddItem "PAYANT"
            .AddItem "GRATUIT"
        With .ComboBox2
            .AddItem "CARTE"
            .AddItem "RECU"
            .AddItem "CERTIFICAT"
        With .ComboBox3
            .AddItem "TOUT"
            .AddItem "CSORL"
            .AddItem "CGORL"
            .AddItem "CML"
            .AddItem "URGENCES"
            .AddItem "AMY"
            .AddItem "AMY2"
            .AddItem "APCH"
            .AddItem "CSTOMA"
            .AddItem "HJSTOM"
        With .ComboBox4
            .AddItem "TOUT"
            .AddItem "CSS"
            .AddItem "CSORL"
            .AddItem "CGORL"
            .AddItem "D296"
            .AddItem "D254"
            .AddItem "D331"
            .AddItem "CTRAMY"
            .AddItem "D352"
            .AddItem "BAMY"
            .AddItem "CSTOMA"
            .AddItem "D744"
            .AddItem "D736"
            .AddItem "ORL"
            .AddItem "OPH"
Private Sub UserForm_Click()
codes module
Sub PAYANT()
    Sheets("payant").Range("A1").CurrentRegion.AdvancedFilter Action:=xlFilterCopy, _
        CriteriaRange:=temp.Range("A1:I2"), CopyToRange:=temp.Range("A3:H3"), Unique:=False
Sub GRATUIT()
    Sheets("Gratuit").Range("A1").CurrentRegion.AdvancedFilter Action:=xlFilterCopy, _
        CriteriaRange:=temp.Range("K1:S2"), CopyToRange:=temp.Range("K3:R3"), Unique:=False
Sub Effacer()
    With temp
        .Range("C2:I2").ClearContents
        .Range("t1:u1").ClearContents
        .Range("M2:U2").ClearContents
Sub shUF()
    UserForm1.Show
Exemple de résultats
Rechercher des sujets similaires à "filtres elabores"
