Impossible de charger ma listview
Bonjour a tous
ma listview a le plus grand mal a se charger deja sur 10 lignes
et moi j'aurai besoin de travail sur au moins 60000 lignes
si vous avez une solution pour optimiser le chargement de la listview
merci d'avance
Private Declare Function FindWindowA& Lib "User32" (ByVal lpClassName$, ByVal lpWindowName$)
Private Declare Function EnableWindow& Lib "User32" (ByVal hWnd&, ByVal bEnable&)
Private Declare Function GetWindowLongA& Lib "User32" (ByVal hWnd&, ByVal nIndex&)
Private Declare Function SetWindowLongA& Lib "User32" (ByVal hWnd&, ByVal nIndex&, ByVal dwNewLong&)
Option Compare Text 'Pour ignorer les majuscules ou minuscules
Dim Mem_Code_Art 'pour retrouver ligne excel si modif code art
Private Sub Majour_Lsvw_Click()
'majour listview
Call Majour_Lvw
Private Sub TextBox3_Change()
If TextBox3 = "Néant" Then
TextBox12.ForeColor = vbRed
TextBox2.ForeColor = vbRed
TextBox3.ForeColor = vbRed
TextBox4.ForeColor = vbRed
TextBox5.ForeColor = vbRed
TextBox6.ForeColor = vbRed
TextBox7.ForeColor = vbRed
TextBox8.ForeColor = vbRed
TextBox9.ForeColor = vbRed
TextBox10.ForeColor = vbRed
TextBox12.ForeColor = vbBlack
TextBox2.ForeColor = vbBlack
TextBox3.ForeColor = vbBlack
TextBox4.ForeColor = vbBlack
TextBox5.ForeColor = vbBlack
TextBox6.ForeColor = vbBlack
TextBox7.ForeColor = vbBlack
TextBox8.ForeColor = vbBlack
TextBox9.ForeColor = vbBlack
TextBox10.ForeColor = vbBlack
Private Sub TextBox1_Change()
Dim I As Long
Dim C As Range
ListView1.ListItems.Clear
If TextBox1 <> "" Then
With Sheets("BIBLIOTHEQUE DE PRIX TCE")
I = 2
Do
For Each C In .Range(.Cells(I, 1), .Cells(I, 10))
If UCase(CStr(C.Value)) = UCase(TextBox1.Value) Or InStr(CStr(C), TextBox1) > 0 Then
IniLvw12 C.Row
Exit For
Next C
I = I + 1
Loop While .Cells(I, 1) <> ""
Me.TextBox2 = ""
Me.TextBox3 = ""
Me.TextBox4 = ""
Me.TextBox5 = ""
Me.TextBox6 = ""
Me.TextBox7 = ""
Me.TextBox8 = ""
Me.TextBox9 = ""
Me.TextBox10 = ""
Me.TextBox12 = "" 'code art
Call Majour_Lvw 'majour listview
Private Sub ListView1_ColumnClick(ByVal ColumnHeader As MSComctlLib.ColumnHeader)
ListView1.Sorted = False
ListView1.SortKey = ColumnHeader.Index - 1
If ListView1.SortOrder = lvwAscending Then
ListView1.SortOrder = lvwDescending
ListView1.Sorted = True
'Unload Me
'CONSULTATION_PRIX.Show
Private Sub ListView1_ItemClick(ByVal Item As MSComctlLib.ListItem)
Dim I As Integer
Dim J As Integer
Dim x
I = Me.ListView1.SelectedItem.Index
TextBox12 = ListView1.ListItems(I)
Mem_Code_Art = TextBox12.Value
For J = 1 To Me.ListView1.ColumnHeaders.Count - 1
Me.Controls("Textbox" & J + 1) = ListView1.ListItems(I).ListSubItems(J).Text
Next J
'Unload Me
Sub IniLvw12(a As Long)
Dim x
Dim I
Dim J
Dim C
With ListView1
.ListItems.Add , , Sheets("BIBLIOTHEQUE DE PRIX TCE").Cells(a, 1)
For I = 1 To 9
.ListItems(.ListItems.Count).ListSubItems.Add , , Sheets("BIBLIOTHEQUE DE PRIX TCE").Cells(a, I + 1)
.ListItems(.ListItems.Count).ListSubItems.Add , , a
For I = 1 To .ListItems.Count
If .ListItems(I) = TextBox1 Then .ListItems(I).Bold = True
For J = 1 To .ColumnHeaders.Count - 1
If .ListItems(I).ListSubItems(2).Text = "Néant" Then
.ListItems(I).ForeColor = vbRed
For C = 1 To .ColumnHeaders.Count
.ListItems(I).ListSubItems(C).Bold = True
.ListItems(I).ListSubItems(C).ForeColor = vbRed 'couleur colonne 2
Next C
Next J
Next I
Private Sub UserForm_Activate()
EnableWindow FindWindowA("XLMAIN", Application.Caption), 1
Dim hWnd As Long
Dim ligne
hWnd = FindWindowA(vbNullString, Me.Caption)
SetWindowLongA hWnd, -16, GetWindowLongA(hWnd, -16) Or &H20000
With Me.ListView1
With .ColumnHeaders
.Clear
.Add , , "Code art.", 70, lvwColumnLeft
.Add , , "Type Ets", 55, lvwColumnCenter
.Add , , "Nom Ets (Client)", 95, lvwColumnCenter
.Add , , "Désignation", 220, lvwColumnCenter
.Add , , "D.U. (F)", 60, lvwColumnCenter
.Add , , "D.U. (D/P)", 60, lvwColumnCenter
.Add , , "D.U. (ST)", 50, lvwColumnCenter
.Add , , "Unité", 35, lvwColumnCenter
.Add , , "Qté", 50, lvwColumnCenter
.Add , , "Sous-traitant", 140, lvwColumnCenter
ligne = 1
.Gridlines = True
.View = lvwReport
.FullRowSelect = True
Majour_Lvw
Sub Majour_Lvw()
Dim Nbl As Long, I As Long, J As Long, C As Range
'If TextBox12 = "" Then
I = 2
J = .Range("A456541").End(xlUp).Row
For Each C In .Range("A2:A" & .Range("A456541").End(xlUp).Row)
Call IniLvw_Maj(C.Row)
Next C
'Else
' MsgBox "Attention code article vide---------------Majour_Lvw!!!!!!"
'End If
Sub IniLvw_Maj(a As Long)
Dim x
Dim I
Dim J
Dim C
With ListView1
For I = 1 To 9
Next C
Next J
Next I
trop de ligne pour la memoire
fait une Listbox a la place
Maurice
voila une nouvelle listview sur 1000 ligne
A toi de voir
Maurice
pas tout compris au coloriage mais mis en bleu et rouge
mis en commentaire le textbox1change car sur 80000 lignes pas adequate
il vaut mieux remplir la listview en une seule fois plutot que de reprendre les données de la listview avec une double boucle pour mettre en gras et en couleur
bonne continuation
bonne continuation
Bonjour et merci
et du coup comment faire une recherche dynamique dans la listview
Re
Par un bouton ou par afterupdate mais pas par textboxchange
Re
avec recherche et tu peux choisir ta colonne
dernier envoie
Maurice
Re
Re
J'ai remplacer change par afterupdate mais ne fonction pas
Private Sub TextBox1_AfterUpdate()
Dim I As Long
Dim C As Range
I = 2
Do
IniLvw12 C.Row
Exit For
Next C
I = I + 1
Me.TextBox2 = ""
Me.TextBox3 = ""
Me.TextBox4 = ""
Me.TextBox5 = ""
Me.TextBox6 = ""
Me.TextBox7 = ""
Me.TextBox8 = ""
Me.TextBox9 = ""
Me.TextBox10 = ""
Rere
dans ton code, tu recommence tes boucles
j'ai donc modifié le code du afterupdate mais la prochaine étape est le find pour éviter les boucles
sur un tableau tu peux pas faire un delete
j'ais refait la base sans décor pour etre tranquile
et la ses vraiment ma dernieres reponse
Maurice
