Impossible de charger ma listview
Bonjour a tous
ma listview a le plus grand mal a se charger deja sur 10 lignes
et moi j'aurai besoin de travail sur au moins 60000 lignes
si vous avez une solution pour optimiser le chargement de la listview
merci d'avance
Private Declare Function FindWindowA& Lib "User32" (ByVal lpClassName$, ByVal lpWindowName$)
Private Declare Function EnableWindow& Lib "User32" (ByVal hWnd&, ByVal bEnable&)
Private Declare Function GetWindowLongA& Lib "User32" (ByVal hWnd&, ByVal nIndex&)
Private Declare Function SetWindowLongA& Lib "User32" (ByVal hWnd&, ByVal nIndex&, ByVal dwNewLong&)
Option Compare Text 'Pour ignorer les majuscules ou minuscules
Dim Mem_Code_Art        'pour retrouver ligne excel si modif code art
Private Sub Majour_Lsvw_Click()
    'majour listview
    Call Majour_Lvw
Private Sub TextBox3_Change()
    If TextBox3 = "Néant" Then
        TextBox12.ForeColor = vbRed
        TextBox2.ForeColor = vbRed
        TextBox3.ForeColor = vbRed
        TextBox4.ForeColor = vbRed
        TextBox5.ForeColor = vbRed
        TextBox6.ForeColor = vbRed
        TextBox7.ForeColor = vbRed
        TextBox8.ForeColor = vbRed
        TextBox9.ForeColor = vbRed
        TextBox10.ForeColor = vbRed
        TextBox12.ForeColor = vbBlack
        TextBox2.ForeColor = vbBlack
        TextBox3.ForeColor = vbBlack
        TextBox4.ForeColor = vbBlack
        TextBox5.ForeColor = vbBlack
        TextBox6.ForeColor = vbBlack
        TextBox7.ForeColor = vbBlack
        TextBox8.ForeColor = vbBlack
        TextBox9.ForeColor = vbBlack
        TextBox10.ForeColor = vbBlack
Private Sub TextBox1_Change()
    Dim I As Long
    Dim C As Range
    ListView1.ListItems.Clear
    If TextBox1 <> "" Then
        With Sheets("BIBLIOTHEQUE DE PRIX TCE")
            I = 2
            Do
                For Each C In .Range(.Cells(I, 1), .Cells(I, 10))
                    If UCase(CStr(C.Value)) = UCase(TextBox1.Value) Or InStr(CStr(C), TextBox1) > 0 Then
                        IniLvw12 C.Row
                        Exit For
                Next C
                I = I + 1
            Loop While .Cells(I, 1) <> ""
        Me.TextBox2 = ""
        Me.TextBox3 = ""
        Me.TextBox4 = ""
        Me.TextBox5 = ""
        Me.TextBox6 = ""
        Me.TextBox7 = ""
        Me.TextBox8 = ""
        Me.TextBox9 = ""
        Me.TextBox10 = ""
        Me.TextBox12 = ""       'code art
        Call Majour_Lvw      'majour listview
Private Sub ListView1_ColumnClick(ByVal ColumnHeader As MSComctlLib.ColumnHeader)
    ListView1.Sorted = False
    ListView1.SortKey = ColumnHeader.Index - 1
    If ListView1.SortOrder = lvwAscending Then
        ListView1.SortOrder = lvwDescending
    ListView1.Sorted = True
    'Unload Me
    'CONSULTATION_PRIX.Show
Private Sub ListView1_ItemClick(ByVal Item As MSComctlLib.ListItem)
    Dim I As Integer
    Dim J As Integer
    Dim x
    I = Me.ListView1.SelectedItem.Index
    TextBox12 = ListView1.ListItems(I)
    Mem_Code_Art = TextBox12.Value
    For J = 1 To Me.ListView1.ColumnHeaders.Count - 1
        Me.Controls("Textbox" & J + 1) = ListView1.ListItems(I).ListSubItems(J).Text
    Next J
  'Unload Me
Sub IniLvw12(a As Long)
    Dim x
    Dim I
    Dim J
    Dim C
    With ListView1
        .ListItems.Add , , Sheets("BIBLIOTHEQUE DE PRIX TCE").Cells(a, 1)
        For I = 1 To 9
            .ListItems(.ListItems.Count).ListSubItems.Add , , Sheets("BIBLIOTHEQUE DE PRIX TCE").Cells(a, I + 1)
        .ListItems(.ListItems.Count).ListSubItems.Add , , a
        For I = 1 To .ListItems.Count
            If .ListItems(I) = TextBox1 Then .ListItems(I).Bold = True
            For J = 1 To .ColumnHeaders.Count - 1
                If .ListItems(I).ListSubItems(2).Text = "Néant" Then
                    .ListItems(I).ForeColor = vbRed
                    For C = 1 To .ColumnHeaders.Count
                        .ListItems(I).ListSubItems(C).Bold = True
                        .ListItems(I).ListSubItems(C).ForeColor = vbRed     'couleur colonne 2
                    Next C
            Next J
        Next I
Private Sub UserForm_Activate()
    EnableWindow FindWindowA("XLMAIN", Application.Caption), 1
    Dim hWnd As Long
    Dim ligne
    hWnd = FindWindowA(vbNullString, Me.Caption)
    SetWindowLongA hWnd, -16, GetWindowLongA(hWnd, -16) Or &H20000
    With Me.ListView1
        With .ColumnHeaders
            .Clear
            .Add , , "Code art.", 70, lvwColumnLeft
            .Add , , "Type Ets", 55, lvwColumnCenter
            .Add , , "Nom Ets (Client)", 95, lvwColumnCenter
            .Add , , "Désignation", 220, lvwColumnCenter
            .Add , , "D.U. (F)", 60, lvwColumnCenter
            .Add , , "D.U. (D/P)", 60, lvwColumnCenter
            .Add , , "D.U. (ST)", 50, lvwColumnCenter
            .Add , , "Unité", 35, lvwColumnCenter
            .Add , , "Qté", 50, lvwColumnCenter
            .Add , , "Sous-traitant", 140, lvwColumnCenter
        ligne = 1
        .Gridlines = True
        .View = lvwReport
        .FullRowSelect = True
        Majour_Lvw
Sub Majour_Lvw()
    Dim Nbl As Long, I As Long, J As Long, C As Range
    'If TextBox12 = "" Then
            I = 2
            J = .Range("A456541").End(xlUp).Row
            For Each C In .Range("A2:A" & .Range("A456541").End(xlUp).Row)
                Call IniLvw_Maj(C.Row)
            Next C
    'Else
    '    MsgBox "Attention code article vide---------------Majour_Lvw!!!!!!"
    'End If
Sub IniLvw_Maj(a As Long)
    Dim x
    Dim I
    Dim J
    Dim C
    With ListView1
        For I = 1 To 9
                    Next C
            Next J
        Next I
55bl-listview-bis.xlsm (861.72 Ko)
trop de ligne pour la memoire
fait une Listbox a la place
Maurice
Maurice
Bonjour a tous c'est long meme avec une dizaine de ligne
j'ai besoin de colorer les lignes sous condition d'ou la listview
se n'ai apparemment pas possible avec une listbox
si tu a une solution merci d'avance
voila une nouvelle listview sur 1000 ligne
A toi de voir
Maurice
41bl-listview-bis.xlsm (872.79 Ko)
pas tout compris au coloriage mais mis en bleu et rouge
mis en commentaire le textbox1change car sur 80000 lignes pas adequate
il vaut mieux remplir la listview en une seule fois plutot que de reprendre les données de la listview avec une double boucle pour mettre en gras et en couleur
bonne continuation
bonne continuation
Bonjour et merci
et du coup comment faire une recherche dynamique dans la listview
Re
Par un bouton ou par afterupdate mais pas par textboxchange
Re
avec recherche et tu peux choisir ta colonne
dernier envoie
Maurice
35bl-listview-bis.xlsm (879.19 Ko)
Re
Re
J'ai remplacer change par afterupdate mais ne fonction pas
Private Sub TextBox1_AfterUpdate()
    Dim I As Long
    Dim C As Range
            I = 2
            Do
                        IniLvw12 C.Row
                        Exit For
                Next C
                I = I + 1
        Me.TextBox2 = ""
        Me.TextBox3 = ""
        Me.TextBox4 = ""
        Me.TextBox5 = ""
        Me.TextBox6 = ""
        Me.TextBox7 = ""
        Me.TextBox8 = ""
        Me.TextBox9 = ""
        Me.TextBox10 = ""
Rere
dans ton code, tu recommence tes boucles
j'ai donc modifié le code du afterupdate mais la prochaine étape est le find pour éviter les boucles
sur un tableau tu peux pas faire un delete
j'ais refait la base sans décor pour etre tranquile
et la ses vraiment ma dernieres reponse
Maurice
38bl-listview-1.xlsm (854.50 Ko)
Maurice
BL_ListView-1.xlsm
Re
Super merci beaucoup pour le coup de main
Rechercher des sujets similaires à "impossible charger listview"
