ouvre le VBE (ALT-F11) insertion module et tu colles ceci puis tu le lances
Regarde avant/après par CTRL-END où est la dernière cellule
Sub NettoieEtDerniereCellule() ' Laurent Longre 2000
Dim Sht As Worksheet, DCell As Range, Calc As Long, Rien As String
On Error Resume Next
Calc = Application.Calculation
With Application
.Calculation = xlCalculationManual
.StatusBar = "Nettoyage en cours..."
.EnableCancelKey = xlErrorHandler
.ScreenUpdating = False
For Each Sht In Worksheets
If Sht.UsedRange.Address <> "$A$1" Or Not IsEmpty(Sht.[A1]) Then
Set DCell = Sht.Cells.Find("*", , , , xlByRows, xlPrevious)(2)
If Not DCell Is Nothing Then
Sht.Range(DCell, Sht.Cells([A:A].Count, 1)).EntireRow.Clear
Set DCell = Nothing
Set DCell = Sht.Cells.Find("*", , , , xlByColumns, xlPrevious)(, 2)
If Not DCell Is Nothing Then _
Sht.Range(DCell, Sht.[IV1]).EntireColumn.Clear
Rien = Sht.UsedRange.Address
Next Sht
Application.StatusBar = False
Application.Calculation = Calc
