Sheets("Clients").Range("a2") = TextBox1.Text
Sheets("Clients").Range("b2") = TextBox2.Text
Sheets("Clients").Range("c2") = TextBox3.Text
Sheets("Clients").Range("d2") = TextBox4.Text
Sheets("Clients").Range("e2") = TextBox5.Text
Sheets("Clients").Range("f2") = TextBox6.Text
Sheets("Clients").Range("g2") = TextBox7.Text
Sheets("Clients").Range("h2") = TextBox8.Text
Sheets("Clients").Range("i2") = TextBox9.Text
Sheets("Clients").Range("j2") = TextBox10.Text
Sheets("Clients").Range("k2") = TextBox11.Text
Sheets("Clients").Range("l2") = TextBox12.Text
Sheets("Clients").Range("m2") = TextBox13.Text
Sheets("Clients").Range("n2") = TextBox14.Text
Sheets("Clients").Range("o2") = TextBox15.Text
Sheets("Clients").Range("p2") = TextBox16.Text
Sheets("ARCHIVE").Range("A2") = TextBox16.Text
Sheets("archive").Range("q2") = TextBox1.Text
Sheets("archive").Range("r2") = TextBox2.Text
Sheets("archive").Range("s2") = TextBox3.Text
Sheets("archive").Range("t2") = TextBox4.Text
Sheets("archive").Range("u2") = TextBox5.Text
Sheets("archive").Range("v2") = TextBox6.Text
Sheets("archive").Range("w2") = TextBox7.Text
Sheets("archive").Range("x2") = TextBox8.Text
Sheets("archive").Range("y2") = TextBox9.Text
Sheets("archive").Range("z2") = TextBox10.Text
Sheets("archive").Range("aa2") = TextBox11.Text
Sheets("archive").Range("ab2") = TextBox12.Text
Sheets("archive").Range("ac2") = TextBox13.Text
Sheets("archive").Range("ad2") = TextBox14.Text
Sheets("archive").Range("ae2") = TextBox15.Text
Sheets("archive").Range("af2") = TextBox16.Text
Sheets("archive").Range("a2") = TextBox17.Text
Unload UserForm1
Sheets("Clients").Select
Rows("2, 2").Select
'copie de la selection
Selection.Copy
'selection d'une cellule ou tu desire coller la selection
Cells(65535, 1).End(xlUp)(2).Select
'Colle la plage copiée
:=False, Transpose:=False
ActiveWorkbook.Save
Private Sub TextBox10_Change()
'Pour le bouton Modifier
Dim Ligne As Long
Dim i As Integer
If MsgBox("Confirmez-vous la modification de ce contact ?", vbYesNo, "Demande de confirmation de modification") = vbYes Then
If Me.ComboBox1.ListIndex = -1 Then Exit Sub
Ligne = Me.TextBox1.ListIndex + 2
Ws.Cells(Ligne, "B") = TextBox2
For i = 1 To 16
If Me.Controls("TextBox" & i).Visible = True Then
Ws.Cells(Ligne, i + 2) = Me.Controls("TextBox" & i)
'Pour le bouton Quitter
Private Sub CommandButton3_Click()
Unload Me
Private Sub TextBox11_Change()
Private Sub TextBox17_Change()
Private Sub UserForm_Click()
