Bonjour à tous, j'ai trouvé ce code sur le forum pour forcer les majuscules :
If Not Application.Intersect(Target, Range("E10:E11")) Is Nothing Then
Target = UCase(Target)
le code fonctionne mais quand je lance mon autre macro (ci dessous j'ai ce message d'erreur et le 1er code ne fonctionne plus
Sub Rectangle11_Cliquer()
Sheets("AJOUT").Select
Range("B2:G2").Select
Selection.Copy
Sheets("BDD").Visible = True
Sheets("BDD").Select
If Range("B2").Value = "" Then
Range("B2").Select
:=False, Transpose:=False
Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
SkipBlanks:=False, Transpose:=False
Range("B65535").End(xlUp).Offset(1, 0).Select
Range("Tableau1[[N°]:[EQUIPIER GPI]]").Select
ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort.SortFields.Add _
Key:=Range("Tableau1[[Grade ]]"), SortOn:=xlSortOnValues, Order:= _
xlAscending, CustomOrder:="ADJ,SGC,SGT,CLC,CAL,AV1,AVT", DataOption:= _
xlSortNormal
Key:=Range("Tableau1[Nom]"), SortOn:=xlSortOnValues, Order:=xlAscending, _
DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
'Accueil
Sheets("ACCUEIL").Select
Columns("K:K").Select
Selection.ClearContents
Range("Tableau1[Grade Nom]").Select
Selection.Copy
Range("K6").Select
'CCPM
Sheets("CCPM").Select
Columns("B:B").Select
Selection.Copy
Range("B6").Select
'VSA
Sheets("VSA").Select
Selection.Copy
Range("B5").Select
'LICENCE
Sheets("LICENCE").Select
Selection.Copy
Range("B8").Select
'PLD
Sheets("PLD").Select
Selection.Copy
Range("B4").Select
'BADGE
Sheets("BADGE").Select
Selection.Copy
Range("B5").Select
'FAMAS
Sheets("FAMAS").Select
Selection.Copy
Range("B4").Select
'RAMASSAGE
Sheets("RAMASSAGE").Select
Selection.Copy
Range("B5").Select
'POIC
Sheets("POIC").Select
Selection.Copy
Range("B6").Select
'INSTRUC
Sheets("ENREGISTREMENT INSTRUC").Select
Selection.Copy
Range("B2").Select
Sheets("BDD").Visible = False
Range("E10:E14").Select
merci
