Problème majuscule
Bonjour à tous, j'ai trouvé ce code sur le forum pour forcer les majuscules :
If Not Application.Intersect(Target, Range("E10:E11")) Is Nothing Then
    Target = UCase(Target)
le code fonctionne mais quand je lance mon autre macro (ci dessous j'ai ce message d'erreur et le 1er code ne fonctionne plus
Sub Rectangle11_Cliquer()
Sheets("AJOUT").Select
    Range("B2:G2").Select
    Selection.Copy
    Sheets("BDD").Visible = True
    Sheets("BDD").Select
    If Range("B2").Value = "" Then
    Range("B2").Select
        :=False, Transpose:=False
    Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
        SkipBlanks:=False, Transpose:=False
    Range("B65535").End(xlUp).Offset(1, 0).Select
    Range("Tableau1[[N°]:[EQUIPIER GPI]]").Select
    ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort.SortFields.Add _
        Key:=Range("Tableau1[[Grade ]]"), SortOn:=xlSortOnValues, Order:= _
        xlAscending, CustomOrder:="ADJ,SGC,SGT,CLC,CAL,AV1,AVT", DataOption:= _
        xlSortNormal
        Key:=Range("Tableau1[Nom]"), SortOn:=xlSortOnValues, Order:=xlAscending, _
        DataOption:=xlSortNormal
    With ActiveWorkbook.Worksheets("BDD").ListObjects("Tableau1").Sort
        .Header = xlYes
        .MatchCase = False
        .Orientation = xlTopToBottom
        .SortMethod = xlPinYin
        .Apply
    'Accueil
    Sheets("ACCUEIL").Select
    Columns("K:K").Select
    Selection.ClearContents
    Range("Tableau1[Grade Nom]").Select
    Selection.Copy
    Range("K6").Select
    'CCPM
    Sheets("CCPM").Select
    Columns("B:B").Select
    Selection.Copy
    Range("B6").Select
    'VSA
    Sheets("VSA").Select
    Selection.Copy
    Range("B5").Select
    'LICENCE
    Sheets("LICENCE").Select
    Selection.Copy
    Range("B8").Select
    'PLD
    Sheets("PLD").Select
    Selection.Copy
    Range("B4").Select
    'BADGE
    Sheets("BADGE").Select
    Selection.Copy
    Range("B5").Select
    'FAMAS
    Sheets("FAMAS").Select
    Selection.Copy
    Range("B4").Select
    'RAMASSAGE
    Sheets("RAMASSAGE").Select
    Selection.Copy
    Range("B5").Select
    'POIC
    Sheets("POIC").Select
    Selection.Copy
    Range("B6").Select
    'INSTRUC
    Sheets("ENREGISTREMENT INSTRUC").Select
    Selection.Copy
    Range("B2").Select
    Sheets("BDD").Visible = False
    Range("E10:E14").Select
merci
sans titre
        If Target <> "" Then Target = UCase(Target)
Merci MFerrand mais ça m'affiche ce message d'erreur
sans titre2
Je ne vois aucun message !
En faisant quoi ?
Celui- ci , pardon
sans titre3
Je repose donc la question : en faisant quoi ?
Le code de ta macro (que j'ai été obligé de parcourir rapidement malgré mon aversion ) ne met en cause E10:E11 que pour les effacer.
Que cherches donc tu à mettre dans ces cellules pour déclencher une incompatibilité de type ?
Juste "GRADE en E10 "et "NOM en E11" et après "C2=E10 et C3=E11"
Ôte-moi d'un doute ?
C'est bien le texte : "C2=E10" que tu mets ? Non une formule ?
oui, C2=E10
Tant que tu tapes des valeurs texte ou assimilées, l'erreur que tu indiques ne peut pas se produire !
Non je t'assures, les 2 cellules sont vides, je viens de revérifier.
Je viens de trouver le problème , quand je met ce bout de code en commentaire je n'ai plus d'erreur, le soucis c'est que je ne peux plus effacer "E10:E14"
Je crois que cela vient du fait que Target est alors une plage de plusieurs cellules...
Modifie l'évènementielle ainsi :
    Dim isect As Range, c As Range
    Set isect = Intersect(Target, Range("E10:E11"))
    If Not isect Is Nothing Then
        For Each c In isect.Cells
            If c <> "" Then c = UCase(Target)
        Next c
Rétablis ta commande d'effacement. Et teste...
Ça fonctionne parfaitement MFerrand, un grand merci à toi pour ton aide.
Est t'il possible de forcer la cellule "E12" à mettre la 1ere lettre en majuscule ? Merci
range("E12")=application.worksheetfunction.proper(range("E12"))
Remodification pour intégrer E12 (et unification de la procédure...):
    Dim isect As Range, c As Range, conv As Integer
    Set isect = Intersect(Target, Range("E10:E12"))
            If c <> "" Then
                conv = IIf(c.Row < 12, vbUpperCase, vbProperCase)
                c = StrConv(c, conv)
        Next c
je comprend pas grand chose mais tout fonctionne . Tu es impressionnant MFerrand , un grand merci à toi pour ton aide.
Rechercher des sujets similaires à "probleme majuscule"
