Simplification de code
B
bonjour, j'ai fais ce code qui fonctionne mais je n'arrive pas à le simplifier
If Range("D2").Value = 1 Then
If Range("D3").Value = 1 Then
Sheets("Base de donnée").Select
Range("E3").Select
:=False, Transpose:=False
ElseIf Range("D3").Value = 2 Then
Range("F3").Select
ElseIf Range("D3").Value = 3 Then
Range("G3").Select
ElseIf Range("D3").Value = 4 Then
Range("H3").Select
ElseIf Range("D3").Value = 5 Then
Range("I3").Select
ElseIf Range("D3").Value = 6 Then
Range("J3").Select
ElseIf Range("D3").Value = 7 Then
Range("K3").Select
ElseIf Range("D3").Value = 8 Then
Range("L3").Select
ElseIf Range("D3").Value = 9 Then
Range("M3").Select
ElseIf Range("D3").Value = 10 Then
Range("N3").Select
ElseIf Range("D3").Value = 11 Then
Range("O3").Select
ElseIf Range("D3").Value = 12 Then
Range("P3").Select
ElseIf Range("D3").Value = 13 Then
Range("Q3").Select
ElseIf Range("D3").Value = 14 Then
Range("R3").Select
ElseIf Range("D3").Value = 15 Then
Range("S3").Select
ElseIf Range("D3").Value = 16 Then
Range("T3").Select
ElseIf Range("D3").Value = 17 Then
Range("U3").Select
ElseIf Range("D3").Value = 18 Then
Range("V3").Select
ElseIf Range("D3").Value = 19 Then
Range("W3").Select
ElseIf Range("D3").Value = 20 Then
Range("X3").Select
ElseIf Range("D3").Value = 21 Then
Range("Y3").Select
ElseIf Range("D3").Value = 22 Then
Range("Z3").Select
ElseIf Range("D3").Value = 23 Then
Range("AA3").Select
ElseIf Range("D3").Value = 24 Then
Range("AB3").Select
ElseIf Range("D3").Value = 25 Then
Range("AC3").Select
ElseIf Range("D3").Value = 26 Then
Range("AD3").Select
ElseIf Range("D3").Value = 27 Then
Range("AE3").Select
ElseIf Range("D3").Value = 28 Then
Range("AF3").Select
ElseIf Range("D3").Value = 29 Then
Range("AG3").Select
ElseIf Range("D3").Value = 30 Then
Range("AH3").Select
ElseIf Range("D3").Value = 31 Then
Range("AI3").Select
ElseIf Range("D3").Value = 32 Then
Range("AJ3").Select
ElseIf Range("D3").Value = 33 Then
Range("AK3").Select
ElseIf Range("D3").Value = 34 Then
Range("AL3").Select
ElseIf Range("D3").Value = 35 Then
Range("AM3").Select
ElseIf Range("D3").Value = 36 Then
Range("AN3").Select
ElseIf Range("D3").Value = 37 Then
Range("AO3").Select
ElseIf Range("D3").Value = 38 Then
Range("AP3").Select
ElseIf Range("D3").Value = 39 Then
Range("AQ3").Select
ElseIf Range("D3").Value = 40 Then
Range("AR3").Select
ElseIf Range("D3").Value = 41 Then
Range("AS3").Select
ElseIf Range("D3").Value = 42 Then
Range("AT3").Select
ElseIf Range("D3").Value = 43 Then
Range("AU3").Select
ElseIf Range("D3").Value = 44 Then
Range("AV3").Select
ElseIf Range("D3").Value = 45 Then
Range("AW3").Select
ElseIf Range("D3").Value = 46 Then
Range("AX3").Select
ElseIf Range("D3").Value = 47 Then
Range("AY3").Select
ElseIf Range("D3").Value = 48 Then
Range("AZ3").Select
ElseIf Range("D3").Value = 49 Then
Range("BA3").Select
ElseIf Range("D3").Value = 50 Then
Range("BB3").Select
ElseIf Range("D3").Value = 51 Then
Range("BC3").Select
ElseIf Range("D3").Value = 52 Then
Range("BD3").Select
ElseIf Range("D3").Value = 53 Then
Range("BE3").Select
ElseIf Range("D3").Value = 54 Then
Range("BF3").Select
ElseIf Range("D3").Value = 55 Then
Range("BG3").Select
ElseIf Range("D3").Value = 56 Then
Range("BH3").Select
ElseIf Range("D3").Value = 57 Then
Range("BI3").Select
ElseIf Range("D3").Value = 58 Then
Range("BJ3").Select
ElseIf Range("D3").Value = 59 Then
Range("BK3").Select
ElseIf Range("D3").Value = 60 Then
Range("BL3").Select
ElseIf Range("D3").Value = 61 Then
Range("BM3").Select
ElseIf Range("D3").Value = 62 Then
Range("BN3").Select
ElseIf Range("D3").Value = 63 Then
Range("BO3").Select
End IfMerci
A adapter
Dim i As Integer
For i = 1 To 63
If i = Range("D3").Value Then
Range("A1").Value = Cells(3, 4 + i).Value
End Subbonjour,
Moi je l'ai compris comme ça :
Dim i%
With Sheets("Base de donnée")
For i = 1 To 63
.Cells(3, 4 + i).Value = .Cells(3, 4 + i)
End SubLà encore c'est à adapter et ça ne fonctionne que si D3 est modifié par l'utilisateur. Si D3 est le résultat d'une formule ça ne marche pas. dans ce cas il faut utiliser Calculate...
C'est l'inconvénient de ne donner qu'une partie du code...
B
Je vous joins le fichier , la macro est dans la feuille "TAD" bouton "Valider" (Macro 6). Merci
Pour le coup ça devient complètement incompréhensible.
Je passe la main.
B
Bonjour galopin01, qu'est ce qui est incomprehensible?
