Simplification de code
bonjour, j'ai fais ce code qui fonctionne mais je n'arrive pas à le simplifier
If Range("D2").Value = 1 Then
                    If Range("D3").Value = 1 Then
                    Sheets("Base de donnée").Select
                    Range("E3").Select
                            :=False, Transpose:=False
                    ElseIf Range("D3").Value = 2 Then
                    Range("F3").Select
                    ElseIf Range("D3").Value = 3 Then
                    Range("G3").Select
                    ElseIf Range("D3").Value = 4 Then
                    Range("H3").Select
                    ElseIf Range("D3").Value = 5 Then
                    Range("I3").Select
                    ElseIf Range("D3").Value = 6 Then
                    Range("J3").Select
                    ElseIf Range("D3").Value = 7 Then
                    Range("K3").Select
                    ElseIf Range("D3").Value = 8 Then
                    Range("L3").Select
                    ElseIf Range("D3").Value = 9 Then
                    Range("M3").Select
                    ElseIf Range("D3").Value = 10 Then
                    Range("N3").Select
                    ElseIf Range("D3").Value = 11 Then
                    Range("O3").Select
                    ElseIf Range("D3").Value = 12 Then
                    Range("P3").Select
                    ElseIf Range("D3").Value = 13 Then
                    Range("Q3").Select
                    ElseIf Range("D3").Value = 14 Then
                    Range("R3").Select
                    ElseIf Range("D3").Value = 15 Then
                    Range("S3").Select
                    ElseIf Range("D3").Value = 16 Then
                    Range("T3").Select
                    ElseIf Range("D3").Value = 17 Then
                    Range("U3").Select
                    ElseIf Range("D3").Value = 18 Then
                    Range("V3").Select
                    ElseIf Range("D3").Value = 19 Then
                    Range("W3").Select
                    ElseIf Range("D3").Value = 20 Then
                    Range("X3").Select
                    ElseIf Range("D3").Value = 21 Then
                    Range("Y3").Select
                    ElseIf Range("D3").Value = 22 Then
                    Range("Z3").Select
                    ElseIf Range("D3").Value = 23 Then
                    Range("AA3").Select
                    ElseIf Range("D3").Value = 24 Then
                    Range("AB3").Select
                    ElseIf Range("D3").Value = 25 Then
                    Range("AC3").Select
                    ElseIf Range("D3").Value = 26 Then
                    Range("AD3").Select
                    ElseIf Range("D3").Value = 27 Then
                    Range("AE3").Select
                    ElseIf Range("D3").Value = 28 Then
                    Range("AF3").Select
                    ElseIf Range("D3").Value = 29 Then
                    Range("AG3").Select
                    ElseIf Range("D3").Value = 30 Then
                    Range("AH3").Select
                    ElseIf Range("D3").Value = 31 Then
                    Range("AI3").Select
                    ElseIf Range("D3").Value = 32 Then
                    Range("AJ3").Select
                    ElseIf Range("D3").Value = 33 Then
                    Range("AK3").Select
                    ElseIf Range("D3").Value = 34 Then
                    Range("AL3").Select
                    ElseIf Range("D3").Value = 35 Then
                    Range("AM3").Select
                    ElseIf Range("D3").Value = 36 Then
                    Range("AN3").Select
                    ElseIf Range("D3").Value = 37 Then
                    Range("AO3").Select
                    ElseIf Range("D3").Value = 38 Then
                    Range("AP3").Select
                    ElseIf Range("D3").Value = 39 Then
                    Range("AQ3").Select
                    ElseIf Range("D3").Value = 40 Then
                    Range("AR3").Select
                    ElseIf Range("D3").Value = 41 Then
                    Range("AS3").Select
                    ElseIf Range("D3").Value = 42 Then
                    Range("AT3").Select
                    ElseIf Range("D3").Value = 43 Then
                    Range("AU3").Select
                    ElseIf Range("D3").Value = 44 Then
                    Range("AV3").Select
                    ElseIf Range("D3").Value = 45 Then
                    Range("AW3").Select
                    ElseIf Range("D3").Value = 46 Then
                    Range("AX3").Select
                    ElseIf Range("D3").Value = 47 Then
                    Range("AY3").Select
                    ElseIf Range("D3").Value = 48 Then
                    Range("AZ3").Select
                    ElseIf Range("D3").Value = 49 Then
                    Range("BA3").Select
                    ElseIf Range("D3").Value = 50 Then
                    Range("BB3").Select
                    ElseIf Range("D3").Value = 51 Then
                    Range("BC3").Select
                    ElseIf Range("D3").Value = 52 Then
                    Range("BD3").Select
                    ElseIf Range("D3").Value = 53 Then
                    Range("BE3").Select
                    ElseIf Range("D3").Value = 54 Then
                    Range("BF3").Select
                    ElseIf Range("D3").Value = 55 Then
                    Range("BG3").Select
                    ElseIf Range("D3").Value = 56 Then
                    Range("BH3").Select
                    ElseIf Range("D3").Value = 57 Then
                    Range("BI3").Select
                    ElseIf Range("D3").Value = 58 Then
                    Range("BJ3").Select
                    ElseIf Range("D3").Value = 59 Then
                    Range("BK3").Select
                    ElseIf Range("D3").Value = 60 Then
                    Range("BL3").Select
                    ElseIf Range("D3").Value = 61 Then
                    Range("BM3").Select
                    ElseIf Range("D3").Value = 62 Then
                    Range("BN3").Select
                    ElseIf Range("D3").Value = 63 Then
                    Range("BO3").Select
A adapter
Dim i As Integer
For i = 1 To 63
    If i = Range("D3").Value Then
   Range("A1").Value = Cells(3, 4 + i).Value
bonjour,
Moi je l'ai compris comme ça :
Dim i%
With Sheets("Base de donnée")
For i = 1 To 63
   .Cells(3, 4 + i).Value = .Cells(3, 4 + i)
Là encore c'est à adapter et ça ne fonctionne que si D3 est modifié par l'utilisateur. Si D3 est le résultat d'une formule ça ne marche pas. dans ce cas il faut utiliser Calculate...
C'est l'inconvénient de ne donner qu'une partie du code...
Je vous joins le fichier , la macro est dans la feuille "TAD" bouton "Valider" (Macro 6). Merci
22essai.xlsm (210.14 Ko)
Pour le coup ça devient complètement incompréhensible.
Je passe la main.
Bonjour galopin01, qu'est ce qui est incomprehensible?
Rechercher des sujets similaires à "simplification code"
