Erreur de compilation sur macro enregistrée
Bonjour !
Alors, j'ai enregistré une macro pour copier une plage de cellule en conservant valeurs, mise en forme et contrôles activeX et la coller dans un nouveau document excel.
voilà le code de la macro, en rouge la ligne où cela bug :
Sub try()
' try Macro
Range("C1:N76").Select
Selection.Copy
Workbooks.Add
Range("C1").Select
ActiveSheet.DropDowns.Add(530.25, 96, 105, 14.25).Select
ActiveSheet.DropDowns.Add(306, 443.25, 135.75, 18).Select
ActiveSheet.DropDowns.Add(306, 405.75, 135.75, 16.5).Select
ActiveSheet.DropDowns.Add(306, 423.75, 135.75, 14.25).Select
ActiveSheet.DropDowns.Add(531.75, 550.5, 97.5, 15.75).Select
ActiveSheet.DropDowns.Add(306, 553.5, 135.75, 16.5).Select
ActiveSheet.DropDowns.Add(434.25, 534.75, 96, 17.25).Select
ActiveSheet.DropDowns.Add(306, 607.5, 135.75, 17.25).Select
ActiveSheet.DropDowns.Add(306, 620.25, 135.75, 14.25).Select
ActiveSheet.DropDowns.Add(306, 634.5, 135.75, 15.75).Select
ActiveSheet.DropDowns.Add(306, 647.25, 135.75, 15.75).Select
ActiveSheet.DropDowns.Add(530.25, 440.25, 120, 17.25).Select
ActiveSheet.DropDowns.Add(530.25, 607.5, 96.75, 17.25).Select
ActiveSheet.DropDowns.Add(530.25, 620.25, 96.75, 14.25).Select
ActiveSheet.DropDowns.Add(530.25, 647.25, 96.75, 15.75).Select
ActiveSheet.DropDowns.Add(530.25, 503.25, 120, 18.75).Select
ActiveSheet.Buttons.Add(531.75, 78.75, 163.5, 16.5).Select
ActiveSheet.Buttons.Add(532.5, 519, 161.25, 15.75).Select
ActiveSheet.Buttons.Add(308.25, 588, 168, 15).Select
ActiveSheet.Paste
Columns("C:C").ColumnWidth = 21.5
Columns("D:D").ColumnWidth = 21.5
Columns("E:E").ColumnWidth = 21.5
Columns("F:F").ColumnWidth = 21.5
Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats, Operation:=
xlNone , SkipBlanks:=False, Transpose:=False
ActiveWindow.SmallScroll Down:=0
Sheets("Feuil1").Select
Sheets("Feuil1").Name = "Fiche perso salarié"
ActiveWindow.SmallScroll Down:=3
ActiveSheet.Shapes.Range(Array("Button 19")).Select
Selection.Delete
ActiveSheet.Shapes.Range(Array("Button 18")).Select
Selection.Delete
ActiveSheet.Shapes.Range(Array("Button 20")).Select
Selection.Delete
ActiveWindow.SmallScroll Down:=12
Columns("G:N").Select
Range("G16").Activate
Selection.EntireColumn.Hidden = True
Windows("Administration du personnel Maj4macro.xlsm").Activate
Je ne peux pas joindre le document car c'est une document professionnel donc excusez moi par avance de demander une aide à l'aveugle
En revanche, je ferai de mon mieux pour répondre aux questions
Merci!
Sans le fichier pas évident et surtout avec le code en vrac comme ça. Remplace la ligne suivante :
Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats, Operation:=xlNone , SkipBlanks:=False, Transpose:=Falsepar :
Range("A1").PasteSpecial Paste:=xlPasteValuesAndNumberFormats, Operation:=xlNone , SkipBlanks:=False, Transpose:=FalseCar je ne vois pas une destination sélectionnée donc il manque une référence de cellule de destination.
Cellule de destination à adapter selon besoin
