Excel vers VCF
Invité
J'ai crée une macro qui permet de creer une fiche contact en vcf a partir d'excel
voici le code qui permet ceci
Sub Bouton1_Cliquer()
' CSV fields are in this order:
' Title (Dr. etc), First, Middle, Last, Suffix, Company, Job Title, email1,
' telwork, telhome, telcell, telfax,
' Work Street, Work city, Work State, Work Zip, Work Country
' Home Street, Home City, Home State, Home Zip, Home Country
' Default Mailing Address - Valid entry is 1 (Home) 2 (Work)
' URL, IM, bday, Note, email2, email3
Dim FileNum As Integer
Dim iRow As Double
iRow = 2
FileNum = FreeFile
'Loop through rows and create a vcard
'until the first name field is empty
While VBA.Trim(Sheets("Feuil1").Cells(iRow, 2)) <> ""
fName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 2))
lName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 4))
OutFilePath = ThisWorkbook.Path & "\" & fName & " " & lName & ".vcf"
Open OutFilePath For Output As FileNum
nTitle = VBA.Trim(Sheets("Feuil1").Cells(iRow, 1))
mName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 3))
nSuffix = VBA.Trim(Sheets("Feuil1").Cells(iRow, 5))
Company = VBA.Trim(Sheets("Feuil1").Cells(iRow, 6))
jobTitle = VBA.Trim(Sheets("Feuil1").Cells(iRow, 7))
email1 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 8))
telWork = VBA.Trim(Sheets("Feuil1").Cells(iRow, 9))
telHome = VBA.Trim(Sheets("Feuil1").Cells(iRow, 10))
telCell = VBA.Trim(Sheets("Feuil1").Cells(iRow, 11))
telFax = VBA.Trim(Sheets("Feuil1").Cells(iRow, 12))
AddrWorkStr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 13))
AddrWorkCity = VBA.Trim(Sheets("Feuil1").Cells(iRow, 14))
AddrWorkState = VBA.Trim(Sheets("Feuil1").Cells(iRow, 15))
AddrWorkZip = VBA.Trim(Sheets("Feuil1").Cells(iRow, 16))
AddrWorkCountry = VBA.Trim(Sheets("Feuil1").Cells(iRow, 17))
AddrHomeStr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 18))
AddrHomeCity = VBA.Trim(Sheets("Feuil1").Cells(iRow, 19))
AddrHomeState = VBA.Trim(Sheets("Feuil1").Cells(iRow, 20))
AddrHomeZip = VBA.Trim(Sheets("Feuil1").Cells(iRow, 21))
AddrHomeCountry = VBA.Trim(Sheets("Feuil1").Cells(iRow, 22))
defaultAddr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 23))
URL = VBA.Trim(Sheets("Feuil1").Cells(iRow, 24))
IM = VBA.Trim(Sheets("Feuil1").Cells(iRow, 25))
BDAY = VBA.Trim(Sheets("Feuil1").Cells(iRow, 26))
NOTE = VBA.Trim(Sheets("Feuil1").Cells(iRow, 27))
email2 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 28))
email3 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 29))
Print #FileNum, "BEGIN:VCARD"
Print #FileNum, "VERSION:3.0"
Print #FileNum, "N:" & lName & ";" & fName & ";" & mName & ";" & nTitle & ";" & nSuffix
Print #FileNum, "FN:" & nTitle & " " & fName & " " & mName & " " & lName & " " & nSuffix
Print #FileNum, "ORG:" & Company
Print #FileNum, "TITLE:" & jobTitle
Print #FileNum, "TEL;WORK;VOICE:" & telWork
Print #FileNum, "TEL;HOME;VOICE:" & telHome
Print #FileNum, "TEL;CELL;VOICE:" & telCell
Print #FileNum, "TEL;WORK;FAX:" & telFax
Print #FileNum, "ADR;WORK;PREF:;;" & AddrWorkStr & ";" & AddrWorkCity & ";" & AddrWorkState & ";" & AddrWorkZip & ";" & AddrWorkCountry
Print #FileNum, "ADR;Home:;;" & AddrHomeStr & ";" & AddrHomeCity & ";" & AddrHomeState & ";" & AddrHomeZip & ";" & AddrHomeCountry
Print #FileNum, "X-MS-OL-DEFAULT-POSTAL-ADDRESS:" & defaultAddr
Print #FileNum, "URL;WORK:" & URL
Print #FileNum, "X-MS-IMADDRESS:" & IM
Print #FileNum, "Note:" & NOTE
Print #FileNum, "BDAY:" & BDAY
Print #FileNum, "EMAIL;PREF;INTERNET:" & email1
Print #FileNum, "EMAIL;INTERNET:" & email2
Print #FileNum, "EMAIL;INTERNET:" & email3
Print #FileNum, "END:VCARD"
'Close the File
Close #FileNum
iRow = iRow + 1
Wend
MsgBox iRow - 2 & " Contacts Converted."
End SubLe probleme c'est que ca cree un vcf par contact alors que je voudrais UN seul et unique fichier vcf contenant tout les contact.
Voili voilou
Avez vous une solution en reserve S.V.P
Merci d'avance les copains
Nom du fichier VCF modifié
Déplacement d'instruction en dehors de la boucle
Je t'ai laissé l'original de la macro pour comparer
A tester
Invité
Bonsoir
Merci de ta reponse ca fonctionne au petit soin
EulVedette
