Excel vers VCF
J'ai crée une macro qui permet de creer une fiche contact en vcf a partir d'excel
voici le code qui permet ceci
Sub Bouton1_Cliquer()
' CSV fields are in this order:
' Title (Dr. etc), First, Middle, Last, Suffix, Company, Job Title, email1,
' telwork, telhome, telcell, telfax,
' Work Street, Work city, Work State, Work Zip, Work Country
' Home Street, Home City, Home State, Home Zip, Home Country
' Default Mailing Address - Valid entry is 1 (Home) 2 (Work)
' URL, IM, bday, Note, email2, email3
    Dim FileNum As Integer
    Dim iRow As Double
    iRow = 2
    FileNum = FreeFile
    'Loop through rows and create a vcard
    'until the first name field is empty
    While VBA.Trim(Sheets("Feuil1").Cells(iRow, 2)) <> ""
     fName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 2))
     lName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 4))
    OutFilePath = ThisWorkbook.Path & "\" & fName & " " & lName & ".vcf"
    Open OutFilePath For Output As FileNum
 nTitle = VBA.Trim(Sheets("Feuil1").Cells(iRow, 1))
 mName = VBA.Trim(Sheets("Feuil1").Cells(iRow, 3))
 nSuffix = VBA.Trim(Sheets("Feuil1").Cells(iRow, 5))
 Company = VBA.Trim(Sheets("Feuil1").Cells(iRow, 6))
 jobTitle = VBA.Trim(Sheets("Feuil1").Cells(iRow, 7))
 email1 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 8))
 telWork = VBA.Trim(Sheets("Feuil1").Cells(iRow, 9))
 telHome = VBA.Trim(Sheets("Feuil1").Cells(iRow, 10))
 telCell = VBA.Trim(Sheets("Feuil1").Cells(iRow, 11))
 telFax = VBA.Trim(Sheets("Feuil1").Cells(iRow, 12))
 AddrWorkStr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 13))
 AddrWorkCity = VBA.Trim(Sheets("Feuil1").Cells(iRow, 14))
 AddrWorkState = VBA.Trim(Sheets("Feuil1").Cells(iRow, 15))
 AddrWorkZip = VBA.Trim(Sheets("Feuil1").Cells(iRow, 16))
 AddrWorkCountry = VBA.Trim(Sheets("Feuil1").Cells(iRow, 17))
 AddrHomeStr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 18))
 AddrHomeCity = VBA.Trim(Sheets("Feuil1").Cells(iRow, 19))
 AddrHomeState = VBA.Trim(Sheets("Feuil1").Cells(iRow, 20))
 AddrHomeZip = VBA.Trim(Sheets("Feuil1").Cells(iRow, 21))
 AddrHomeCountry = VBA.Trim(Sheets("Feuil1").Cells(iRow, 22))
 defaultAddr = VBA.Trim(Sheets("Feuil1").Cells(iRow, 23))
 URL = VBA.Trim(Sheets("Feuil1").Cells(iRow, 24))
 IM = VBA.Trim(Sheets("Feuil1").Cells(iRow, 25))
 BDAY = VBA.Trim(Sheets("Feuil1").Cells(iRow, 26))
 NOTE = VBA.Trim(Sheets("Feuil1").Cells(iRow, 27))
 email2 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 28))
 email3 = VBA.Trim(Sheets("Feuil1").Cells(iRow, 29))
        Print #FileNum, "BEGIN:VCARD"
        Print #FileNum, "VERSION:3.0"
        Print #FileNum, "N:" & lName & ";" & fName & ";" & mName & ";" & nTitle & ";" & nSuffix
        Print #FileNum, "FN:" & nTitle & " " & fName & " " & mName & " " & lName & " " & nSuffix
        Print #FileNum, "ORG:" & Company
        Print #FileNum, "TITLE:" & jobTitle
        Print #FileNum, "TEL;WORK;VOICE:" & telWork
        Print #FileNum, "TEL;HOME;VOICE:" & telHome
        Print #FileNum, "TEL;CELL;VOICE:" & telCell
        Print #FileNum, "TEL;WORK;FAX:" & telFax
        Print #FileNum, "ADR;WORK;PREF:;;" & AddrWorkStr & ";" & AddrWorkCity & ";" & AddrWorkState & ";" & AddrWorkZip & ";" & AddrWorkCountry
        Print #FileNum, "ADR;Home:;;" & AddrHomeStr & ";" & AddrHomeCity & ";" & AddrHomeState & ";" & AddrHomeZip & ";" & AddrHomeCountry
        Print #FileNum, "X-MS-OL-DEFAULT-POSTAL-ADDRESS:" & defaultAddr
        Print #FileNum, "URL;WORK:" & URL
        Print #FileNum, "X-MS-IMADDRESS:" & IM
        Print #FileNum, "Note:" & NOTE
        Print #FileNum, "BDAY:" & BDAY
        Print #FileNum, "EMAIL;PREF;INTERNET:" & email1
        Print #FileNum, "EMAIL;INTERNET:" & email2
        Print #FileNum, "EMAIL;INTERNET:" & email3
        Print #FileNum, "END:VCARD"
    'Close the File
    Close #FileNum
 iRow = iRow + 1
    Wend
    MsgBox iRow - 2 & " Contacts Converted."
Le probleme c'est que ca cree un vcf par contact alors que je voudrais UN seul et unique fichier vcf contenant tout les contact.
Voili voilou
Avez vous une solution en reserve S.V.P
Merci d'avance les copains
111fgs2.xlsm (22.87 Ko)
Nom du fichier VCF modifié
Déplacement d'instruction en dehors de la boucle
Je t'ai laissé l'original de la macro pour comparer
A tester
Bonsoir
Merci de ta reponse ca fonctionne au petit soin
EulVedette
Rechercher des sujets similaires à "vcf"
