Macro
Bonjour, voila j'ai fait cette macro :
Sub Macro1()
' Macro1 Macro
' Macro enregistrée le 28/07/2008 par Thomas
With ActiveSheet.QueryTables.Add(Connection:= _
"TEXT;C:\Documents and Settings\utilisateur\Bureau\24 07
08\air\fente15um\206-995\2bar\C1tir200000.txt" _
, Destination:=Range("A1"))
.Name = "C1tir200000"
.FieldNames = True
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.TextFilePromptOnRefresh = False
.TextFilePlatform = 850
.TextFileStartRow = 1
.TextFileParseType = xlDelimited
.TextFileTextQualifier = xlTextQualifierDoubleQuote
.TextFileConsecutiveDelimiter = False
.TextFileTabDelimiter = False
.TextFileSemicolonDelimiter = False
.TextFileCommaDelimiter = True
.TextFileSpaceDelimiter = False
.TextFileColumnDataTypes = Array(1, 1, 1, 1)
.TextFileDecimalSeparator = "."
.TextFileTrailingMinusNumbers = True
.Refresh BackgroundQuery:=False
Columns("A:B").Select
Charts.Add
ActiveChart.ChartType = xlXYScatterSmoothNoMarkers
ActiveChart.SetSourceData Source:=Sheets("Feuil1").Range("A1:B10007"), _
PlotBy:=xlColumns
ActiveChart.Location Where:=xlLocationAsObject, Name:="Feuil1"
With ActiveChart
.HasTitle = True
.ChartTitle.Characters.Text = "16679 1 TrigTime 24/07/2008 11:47 Ampl"
.Axes(xlCategory, xlPrimary).HasTitle = True
.Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "Temps (s)"
.Axes(xlValue, xlPrimary).HasTitle = True
.Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "Tension (V)"
ActiveSheet.Shapes("Graphique 1").IncrementLeft -63.75
ActiveSheet.Shapes("Graphique 1").IncrementTop -48#
ActiveChart.PlotArea.Select
With Selection.Border
.ColorIndex = 16
.Weight = xlThin
.LineStyle = xlContinuous
With Selection.Interior
.ColorIndex = 2
.PatternColorIndex = 1
.Pattern = xlSolid
ActiveChart.ChartTitle.Select
Selection.Left = 49
Selection.Top = 4
ActiveChart.Legend.Select
Selection.Left = 293
Selection.Top = 6
ActiveChart.Axes(xlValue).MajorGridlines.Select
ActiveChart.ChartArea.Select
Selection.Width = 423
ActiveSheet.Shapes("Graphique 1").ScaleWidth 1.6, msoFalse, _
msoScaleFromTopLeft
ActiveSheet.Shapes("Graphique 1").ScaleHeight 1.6, msoFalse, _
msoScaleFromTopLeft
Windows("Classeur2").ScrollColumn = 4
Windows("Classeur2").ScrollColumn = 3
Windows("Classeur2").ScrollColumn = 1
ActiveWorkbook.SaveAs Filename:= _
"C:\Documents and Settings\utilisateur\Bureau\24 07
08\air\fente15um\206-995\2bar\tir2.xls" _
, FileFormat:=xlNormal, Password:="", WriteResPassword:="", _
ReadOnlyRecommended:=False, CreateBackup:=False
ActiveSheet.ChartObjects("Graphique 1").Activate
Je voudrais que la macro me demande au début de choisir moi même le fichier, ainsi qu'à la fin pour l'enregistrement.
(Pour l'enregistrement : soit un choix, soit dans le même dossier que celui d'ouverture en renommant le fichier en tirX.xls si le fichier ouvert au début était C1tirX00000.txt , X étant un chiffre)
Est ce que vous pourriez m'aider svp?
Fichier texte ici si vous voulez les tabulations pour plus de lisibilité
https://www.excel-pratique.com/~files/doc/zYaPumacro.txt
essaie avec ce code (non testé)
remplace le début de ton code par ceci :
Sub Macro1()
Dim FileToOpen As Variant
      FileToOpen = Application.GetOpenFilename("Fichiers Texte (*.txt), *.txt")
      If FileToOpen = False Then Exit Sub
    With ActiveSheet.QueryTables.Add(Connection:="TEXT;" & FileToOpen, Destination:=Range("A1"))
        .FieldNames = True
        .RowNumbers = False
        .SaveData = True
        .RefreshPeriod = 0
et la fin par ceci :
LePath = ActiveWorkbook.Path & "\"
LeNom = Mid(FileToOpen, InStr(1, FileToOpen, "tir"), 4) & ".xls"
ActiveWorkbook.SaveAs Filename:=LePath & LeNom
J'ai une erreur d'execution 1004 dans le début. "Impossible de trouver le fichier texte pour l'actualisation de cette plage de données externes"
d'apres le debogueur elle arrive juste apres le refresh background query.
J'ai pas encore testé la fin
au passage que faire des
si mon classeur ne s'appelle pas classeur2 je suppose que ca fait planté non?
Re-,
comme je ne peux pas tester, pas facile
sinon, as-tu effectivement enlevé le .Name = "C1tir200000" ?
pour les Scroll, tu peux les enlever, il ne servent qu'à déplacer la barre de défilement, donc à rien...
oui j'ai enlevé le .Name
ok pour les scroll
pas grave je vaisfinir en manuel il me reste qu'une trentaines de fichiers je pense
Re-,
si cela n'est pas confidentiel, peux-tu joindre ton fichier C1tir200000.txt?
ou sinon, je peux t'envoyer mon adresse mail en messagerie privée
https://www.excel-pratique.com/~files/doc/C1tir200000.txt
je l'ai réduit normalement il fait 10 0000 lignes environ !!
Re-,
chez moi, cela fonctionne parfaitement...
Tes fichiers texte sont bien dans le même répertoire?
le code que j'utilises :
Sub Macro1()
' Macro1 Macro
' Macro enregistrée le 28/07/2008 par Thomas MARTINEAU
        .FieldNames = True
        .RowNumbers = False
        .SaveData = True
        .RefreshPeriod = 0
Charts.Add
PlotBy:=xlColumns
With ActiveChart
.HasTitle = True
.ColorIndex = 16
.Weight = xlThin
.ColorIndex = 2
.Pattern = xlSolid
Selection.Left = 49
Selection.Top = 4
Selection.Top = 6
msoScaleFromTopLeft
msoScaleFromTopLeft
non le répertoire change, mais je pensais que le repertoire allait aussi dans FileToOpen.. ce qui expliquerait tout
Re-,
même en changeant de répertoire, cela fonctionne
Par contre, l'erreur vient peut-être de ces lignes :
'ActiveSheet.Shapes("Graphique 1").IncrementLeft -63.75
'ActiveSheet.Shapes("Graphique 1").IncrementTop -48#
'ActiveSheet.Shapes("Graphique 1").ScaleWidth 1.6, msoFalse, _
msoScaleFromTopLeft
'ActiveSheet.Shapes("Graphique 1").ScaleHeight 1.6, msoFalse, _
msoScaleFromTopLeft
'ActiveSheet.ChartObjects("Graphique 1").Activate
Fais comme moi, mets un quote ( ' ) devant les lignes, pour voir
Merci bcp ca marche meme avec les graphique 1 maintenant...
ca va m'epargner pas mal de temps super..
y'a juste l'enregistrement qui se fait dans c:
alors que je le voudrais dans le même répertoire que le fichier qui a été ouvert mais en manuel ca passera
oups double post
Re-,
remplace cette ligne :
LePath = Mid(FileToOpen, 1, InStr(1, FileToOpen, "tir") - 3)
c'est énorme la mise en forme des graphs prend plus de temps que l'importation des données....
encore merci
Re-,
comme j'ai pas trouvé le smiliey de V_Elbie
Si c'est résolu, peux-tu le signaler?
pour ce faire, dans ton premier fil tu as une option, il me semble, où tu peux choisir "Résolu"
non y'a pas, mais c'est résolu j'aime terminé tous les fichiers que j'avais à faire. encore merci
Re-,
comme je n'ai pas posé de question, je ne te saurai te dire où se trouve l'option....
Mais elle existe
Si quelqu'un pouvait te l'indiquer
Rechercher des sujets similaires à "macro"
