Remplir plusieurs feuilles avec un userform
Je souhaiterais pouvoir remplir deux feuilles avec un seul userform.
Les données d'un textbox doivent être rentré dans 2 tableau différents.
Voici mon code pour que les données soient ajoutées au tableau 1 :
Dim L As Integer
If MsgBox("Confirmez-vous l’insertion ?", vbYesNo, "Confirmation d’insertion") = vbYes Then
L = Sheets("Habilitation Agent").Range("a65536").End(xlUp).Row + 1
Sheets("Habilitation Agent").Range("A" & L).Value = ComboBox1
Sheets("Habilitation Agent").Range("B" & L).Value = TextBox2
Sheets("Habilitation Agent").Range("C" & L).Value = TextBox3
Sheets("Habilitation Agent").Range("I" & L).Value = TextBox4
Sheets("Habilitation Agent").Range("O" & L).Value = TextBox5
Sheets("Habilitation Agent").Range("BK" & L).Value = TextBox6
Sheets("Habilitation Agent").Range("U" & L).Value = TextBox7
Sheets("Habilitation Agent").Range("AA" & L).Value = TextBox8
Sheets("Habilitation Agent").Range("AG" & L).Value = TextBox9
Sheets("Habilitation Agent").Range("F" & L).Value = TextBox10
Sheets("Habilitation Agent").Range("L" & L).Value = TextBox11
Sheets("Habilitation Agent").Range("R" & L).Value = TextBox12
Sheets("Habilitation Agent").Range("BN" & L).Value = TextBox13
Sheets("Habilitation Agent").Range("X" & L).Value = TextBox14
Sheets("Habilitation Agent").Range("AD" & L).Value = TextBox15
Sheets("Habilitation Agent").Range("AJ" & L).Value = TextBox16
Sheets("Habilitation Agent").Range("E" & L).Value = TextBox24
Sheets("Habilitation Agent").Range("K" & L).Value = TextBox25
Sheets("Habilitation Agent").Range("Q" & L).Value = TextBox26
Sheets("Habilitation Agent").Range("BM" & L).Value = TextBox27
Sheets("Habilitation Agent").Range("W" & L).Value = TextBox28
Sheets("Habilitation Agent").Range("AC" & L).Value = TextBox29
Sheets("Habilitation Agent").Range("AI" & L).Value = TextBox30
Sheets("Habilitation Agent").Range("AM" & L).Value = TextBox32
Sheets("Habilitation Agent").Range("AP" & L).Value = TextBox33
Sheets("Habilitation Agent").Range("AO" & L).Value = TextBox34
Sheets("Habilitation Agent").Range("AS" & L).Value = TextBox36
Sheets("Habilitation Agent").Range("AV" & L).Value = TextBox37
Sheets("Habilitation Agent").Range("AU" & L).Value = TextBox38
Sheets("Habilitation Agent").Range("AY" & L).Value = TextBox41
Sheets("Habilitation Agent").Range("BB" & L).Value = TextBox42
Sheets("Habilitation Agent").Range("BA" & L).Value = TextBox43
Sheets("Habilitation Agent").Range("BE" & L).Value = TextBox44
Sheets("Habilitation Agent").Range("BH" & L).Value = TextBox45
Sheets("Habilitation Agent").Range("BG" & L).Value = TextBox46
Sheets("Habilitation Agent").Range("BW" & L).Value = TextBox49
Sheets("Habilitation Agent").Range("BZ" & L).Value = TextBox50
Sheets("Habilitation Agent").Range("BY" & L).Value = TextBox51
Sheets("Habilitation Agent").Range("CC" & L).Value = TextBox52
Sheets("Habilitation Agent").Range("CF" & L).Value = TextBox53
Sheets("Habilitation Agent").Range("CE" & L).Value = TextBox54
Sheets("Habilitation Agent").Range("CI" & L).Value = TextBox57
Sheets("Habilitation Agent").Range("CL" & L).Value = TextBox58
Sheets("Habilitation Agent").Range("CK" & L).Value = TextBox59
Sheets("Habilitation Agent").Range("BQ" & L).Value = TextBox60
Sheets("Habilitation Agent").Range("BT" & L).Value = TextBox61
Sheets("Habilitation Agent").Range("BS" & L).Value = TextBox62
Sheets("Habilitation Agent").Range("CO" & L).Value = TextBox64
Sheets("Habilitation Agent").Range("CR" & L).Value = TextBox65
Sheets("Habilitation Agent").Range("CQ" & L).Value = TextBox66
End SubJ'ai essayé avec ce code pour remplir les deux tableaux, mais le problème c'est que les données sont rentrés au même numéro de ligne et non à la fin de chaque tableau ...
Dim L As Integer
L = Sheets("Année").Range("a65536").End(xlUp).Row + 1
Sheets(«Année»).Range("A" & L).Value = ComboBox1
Sheets(«Année»).Range("B" & L).Value = TextBox2
Sheets(«Année»).Range("C" & L).Value = TextBox3
Sheets(«Année»).Range("C" & L).Value = TextBox4
Sheets(«Année»).Range("C" & L).Value = TextBox5
Sheets(«Année»).Range("C" & L).Value = TextBox6
Sheets(«Année»).Range("C" & L).Value = TextBox7
Sheets(«Année»).Range("C" & L).Value = TextBox8
Sheets(«Année»).Range("C" & L).Value = TextBox9
Sheets(«Année»).Range("F" & L).Value = TextBox10
Sheets(«Année»).Range("F" & L).Value = TextBox11
Sheets(«Année»).Range("F" & L).Value = TextBox12
Sheets(«Année»).Range("F" & L).Value = TextBox13
Sheets(«Année»).Range("F" & L).Value = TextBox14
Sheets(«Année»).Range("F" & L).Value = TextBox15
Sheets(«Année»).Range("F" & L).Value = TextBox16
Sheets(«Année»).Range("G" & L).Value = TextBox17
Sheets(«Année»).Range("G" & L).Value = TextBox18
Sheets(«Année»).Range("G" & L).Value = TextBox19
Sheets(«Année»).Range("G" & L).Value = TextBox20
Sheets(«Année»).Range("G" & L).Value = TextBox21
Sheets(«Année»).Range("G" & L).Value = TextBox22
Sheets(«Année»).Range("G" & L).Value = TextBox23
Sheets(«Année»).Range("E" & L).Value = TextBox24
Sheets(«Année»).Range("E" & L).Value = TextBox25
Sheets(«Année»).Range("E" & L).Value = TextBox26
Sheets(«Année»).Range("E" & L).Value = TextBox27
Sheets(«Année»).Range("E" & L).Value = TextBox28
Sheets(«Année»).Range("E" & L).Value = TextBox29
Sheets(«Année»).Range("E" & L).Value = TextBox30
Sheets(«Année»).Range("G" & L).Value = TextBox31
Sheets(«Année»).Range("C" & L).Value = TextBox32
Sheets(«Année»).Range("F" & L).Value = TextBox33
Sheets(«Année»).Range("E" & L).Value = TextBox34
Sheets(«Année»).Range("G" & L).Value = TextBox35
Sheets(«Année»).Range("C" & L).Value = TextBox36
Sheets(«Année»).Range("F" & L).Value = TextBox37
Sheets(«Année»).Range("E" & L).Value = TextBox38
Sheets(«Année»).Range("G" & L).Value = TextBox39
Sheets(«Année»).Range("G" & L).Value = TextBox40
Sheets(«Année»).Range("C" & L).Value = TextBox41
Sheets(«Année»).Range("F" & L).Value = TextBox42
Sheets(«Année»).Range("E" & L).Value = TextBox43
Sheets(«Année»).Range("C" & L).Value = TextBox44
Sheets(«Année»).Range("F" & L).Value = TextBox45
Sheets(«Année»).Range("E" & L).Value = TextBox46
Sheets(«Année»).Range("G" & L).Value = TextBox47
Sheets(«Année»).Range("G" & L).Value = TextBox48
Sheets(«Année»).Range("C" & L).Value = TextBox49
Sheets(«Année»).Range("F" & L).Value = TextBox50
Sheets(«Année»).Range("E" & L).Value = TextBox51
Sheets(«Année»).Range("C" & L).Value = TextBox52
Sheets(«Année»).Range("F" & L).Value = TextBox53
Sheets(«Année»).Range("E" & L).Value = TextBox54
Sheets(«Année»).Range("G" & L).Value = TextBox55
Sheets(«Année»).Range("G" & L).Value = TextBox56
Sheets(«Année»).Range("C" & L).Value = TextBox57
Sheets(«Année»).Range("F" & L).Value = TextBox58
Sheets(«Année»).Range("E" & L).Value = TextBox59
Sheets(«Année»).Range("C" & L).Value = TextBox60
Sheets(«Année»).Range("F" & L).Value = TextBox61
Sheets(«Année»).Range("E" & L).Value = TextBox62
Sheets(«Année»).Range("G" & L).Value = TextBox63
Sheets(«Année»).Range("C" & L).Value = TextBox64
Sheets(«Année»).Range("F" & L).Value = TextBox65
Sheets(«Année»).Range("E" & L).Value = TextBox66
End SubEst ce que quelqu'un peut m'aider ?
Mercii
Hello.
Tu donnes le même nom de variable à 2 valeurs différentes d'affilée... tu lui dit dernière ligne du tableau 1 = L et juste après dernière ligne du tableau 2 = L donc du coup tu en perds 1 sur les 2...
Du coup il faut juste déplacer ta ligne.
Du coup pour modifier:
Dim L As Integer
End SubCa marche !!
Merci beaucoup
Par contre tu regarderas mais tu affecte plusieurs valeurs différentes à la même cellule d'affilée du coup la première est écrasée.
Sheets(«Année»).Range("C" & L).Value = TextBox4Là excel va assigner la valeur TextBox3 à la cellule C"L" et juste après la valeur TextBox4 donc du coup plus de trace de ta valeur TextBox3 dans la cellule
J'ai vu ça !
Du coup les données ne s'ajoutent pas dans le deuxième tableaux (sauf les deux premières colonnes)
En fait j'ai besoin que chaque ligne de mon userform s'ajoute dans une nouvelle ligne de mon tableau.
Voici mon fichier pour être plus claire :
https://www.cjoint.com/c/DLil2XSoUem
Quand j'ajoute des données avec l'userfom, les données sont bien ajoutées dans le premier tableau mais pas dans le second.
Ok je vois ce que tu veux. Je m'en occupe après le repas
Elles sont où dans ton userform les texbox 39 à 66??
Le code sans les textbox que je n'ai pas trouvé (Si elles sont là il suffit de les rajouter avec le même schéma
'Pour le bouton Ajouter
Dim L, i As Integer
For i = L To L + 8
Sheets("Année").Range("A" & i).Value = ComboBox1
Sheets("Année").Range("B" & i).Value = TextBox2
Sheets("Année").Range("C" & L).Value = TextBox3
Sheets("Année").Range("C" & L + 1).Value = TextBox4
Sheets("Année").Range("C" & L + 2).Value = TextBox5
Sheets("Année").Range("C" & L + 3).Value = TextBox6
Sheets("Année").Range("C" & L + 4).Value = TextBox7
Sheets("Année").Range("C" & L + 5).Value = TextBox8
Sheets("Année").Range("C" & L + 6).Value = TextBox9
Sheets("Année").Range("F" & L).Value = TextBox10
Sheets("Année").Range("F" & L + 1).Value = TextBox11
Sheets("Année").Range("F" & L + 2).Value = TextBox12
Sheets("Année").Range("F" & L + 3).Value = TextBox13
Sheets("Année").Range("F" & L + 4).Value = TextBox14
Sheets("Année").Range("F" & L + 5).Value = TextBox15
Sheets("Année").Range("F" & L + 6).Value = TextBox16
Sheets("Année").Range("G" & L).Value = TextBox17
Sheets("Année").Range("G" & L + 1).Value = TextBox18
Sheets("Année").Range("G" & L + 2).Value = TextBox19
Sheets("Année").Range("G" & L + 3).Value = TextBox20
Sheets("Année").Range("G" & L + 4).Value = TextBox21
Sheets("Année").Range("G" & L + 5).Value = TextBox22
Sheets("Année").Range("G" & L + 6).Value = TextBox23
Sheets("Année").Range("E" & L).Value = TextBox24
Sheets("Année").Range("E" & L + 1).Value = TextBox25
Sheets("Année").Range("E" & L + 2).Value = TextBox26
Sheets("Année").Range("E" & L + 3).Value = TextBox27
Sheets("Année").Range("E" & L + 4).Value = TextBox28
Sheets("Année").Range("E" & L + 5).Value = TextBox29
Sheets("Année").Range("E" & L + 6).Value = TextBox30
Sheets("Année").Range("G" & L + 7).Value = TextBox31
Sheets("Année").Range("C" & L + 7).Value = TextBox32
Sheets("Année").Range("F" & L + 7).Value = TextBox33
Sheets("Année").Range("E" & L + 7).Value = TextBox34
Sheets("Année").Range("G" & L + 8).Value = TextBox35
Sheets("Année").Range("C" & L + 8).Value = TextBox36
Sheets("Année").Range("F" & L + 8).Value = TextBox37
Sheets("Année").Range("E" & L + 8).Value = TextBox38
End SubC'est exactement ce que je voulais !
Merci beaucoup.
J'ai complété avec les textbox qui manquaient et tout fonction.
