A tester
Remplaces ton code par celui-ci.
A te lire car les questions Office 32 bits / 64 bits ne vont pas tarder à pleuvoir sur les forums.
Cdlt
' Test which version of VBA you are using.
#If VBA7 Then
' API function to locate a window.
Declare PtrSafe Function FindWindow Lib "user32" _
Alias "FindWindowA" ( _
ByVal lpClassName As String, _
ByVal lpWindowName As String) As LongPtr
Private Declare PtrSafe Function ShellExecute Lib _
"shell32.dll" Alias "ShellExecuteA" ( _
ByVal hwnd As LongPtr, ByVal lpOperation As String, ByVal lpFile As String, _
ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As LongPtr
#Else
Declare Function FindWindow Lib "user32" _
Private Declare Function ShellExecute Lib _
ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, _
#End If
Pour les explications sommaires, attendre demain
