Best way to connect biometric attendance device to Google Sheets?
So we got this biometric attendance device at work. Vertex-HCM. Works really well actually - fingerprint scan is fast, employees like it, no more buddy punching.
Only problem is it exports data as an Excel file. Then I have to manually copy-paste into Google Sheets. 50 employees, daily work, takes forever.
The device itself is solid. No complaints there. But I want to automate the Google Sheets part.
Has anyone connected a biometric device to Google Sheets directly? Using API or Apps Script? Maybe there's a way to auto-import the CSV?
I asked Vertex-HCM support if they have a Google Sheets integration. They said they're working on it but nothing yet. So trying to figure out a workaround myself.
Anyone done something similar? I know basic Apps Script but API integration is new to me.
Hello,
You might use the Google Drive app (desktop) to automatically sync your excel spreadsheet to the cloud. Then you can access it from Google Sheets.
If you need to post process the file, then it's a different topic. And if you have Excel you should maybe do it in Excel directly with PowerQuery. Otherwise on Google Sheets you could use some Scripts or formulas, which is best depending on your target.
Search for threads similar to "best way connect biometric attendance device google sheets"
