Si cela peux vous aider voici les 2 codes qui fonctionnent séparément pour bloquer les cellules après modification et avoir une sélection multiple sur une liste déroulante.
Dim cell As Range
If Intersect(Target, Range("test1")) Is Nothing Then Exit Sub
Me.Unprotect 1234
For Each cell In Target
If Not cell.MergeCells Then
cell.Locked = True
cell.MergeArea.Locked = True ' Verrouille la zone de cellules fusionnées
Next cell
Me.Protect 1234
Dim oldValue As String
Dim newValue As String
On Error GoTo Exitsub
If Not Intersect(Target, Range("E10,E12,E14,E16,E18,E20,E22,E24,E26,C10,C12,C14,C16,C18,C20,C22,C24,C26,B10,B12,B14,B16,B18,B20,B22,B24,B26,M10,M12,M14,M16,M18,M20,M22,M24,M26,N10,N12,N14,N16,N18,N20,N22,N24,N26,P10,P12,P14,P16,P18,P20,P22,P24,P26")) Is Nothing Then
If Target.SpecialCells(xlCellTypeAllValidation) Is Nothing Then
GoTo Exitsub
Else: If Target.Value = "" Then GoTo Exitsub Else
newValue = Target.Value
Application.Undo
oldValue = Target.Value
If oldValue = "" Then
Target.Value = newValue
If InStr(1, oldValue, newValue & ", ") > 0 Then
Target.Value = Replace(oldValue, newValue & ", ", "")
ElseIf InStr(1, oldValue, ", " & newValue) > 0 Then
Target.Value = Replace(oldValue, ", " & newValue, "")
ElseIf InStr(1, oldValue, newValue) = 0 Then
Target.Value = oldValue & ", " & newValue
Exitsub:
