Garder une valeur entre worksheet_change et module
J'aimerai savoir pourquoi la valeur de ynoi devient vide après Call
Merci pour votre aide
Dim NOI As Range
Dim ou As Range
Dim qtedmd, qterst
Public ynoi
ynoi = Rows("1:1").Find("NOI", LookIn:=xlFormulas, LookAt:=xlWhole, MatchCase:=False).Column
qtedmd = Rows("1:1").Find("Qté dmd", LookIn:=xlFormulas, LookAt:=xlWhole, MatchCase:=False).Column
qterec = Rows("1:1").Find("Qté reçue", LookIn:=xlFormulas, LookAt:=xlWhole, MatchCase:=False).Column
qterst = Rows("1:1").Find("Qté reste", LookIn:=xlFormulas, LookAt:=xlWhole, MatchCase:=False).Column
If Target.Column = ynoi Then Call ajoutnoi
If Target.Column = qtedmd Then Cells(Target.Row, qterst).Value = Cells(Target.Row, qtedmd).Value - Cells(Target.Row, qterec).Value
If Target.Column = qterec Then Cells(Target.Row, qterst).Value = Cells(Target.Row, qtedmd).Value - Cells(Target.Row, qterec).Value
Sub ajoutnoi()
cherche = Cells(Target.Row, ynoi).Value
x = WorksheetFunction.CountIf(Worksheets("Base NOI").Range("a:a"), cherche)
If x = 1 Then
Set ou = Worksheets("Base NOI").Range("a:a").EntireColumn
Set NOI = ou.Find(cherche, ou.Range("a1"), , xlWhole, xlByRows, xlNext, False)
nomnoi = NOI.Offset(0, 1).Value
Cells(Target.Row, ynoi + 1).Value = nomnoi
Cells(Target.Row, ynoi + 2).Select
Arr = Array("\\\", "Liste NOI.xlsx", "Rapport 1")
Set c = Cells(Target.Row, ynoi + 1)
With GetObject(Arr(0) & Arr(1))
i = Application.IfError(Application.Match(cherche, .Sheets(Arr(2)).Columns(1), 0), "?")
If IsNumeric(i) Then
c.Value = .Sheets(Arr(2)).Cells(i, 2).Value
c.Resize(, 10).Value = .Sheets(Arr(2)).Cells(i, 2).Resize(, 10).Value
NomFeuille = ActiveSheet.Name
Sheets("Base NOI").Select
a = Range("A" & Rows.Count).End(xlUp).Row + 1
Cells(a, 1).Value = .Sheets(Arr(2)).Cells(i, 1).Resize(, 3).Value
Range(Cells(1, 1), Cells(a, 4)).Select
ActiveWorkbook.Worksheets("Base NOI").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Base NOI").Sort.SortFields.Add Key:=Range(Cells(2, 1), Cells(a, 1)), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("Base NOI").Sort
.SetRange Range(Cells(1, 1), Cells(a, 2))
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("A2").Select
Sheets(NomFeuille).Select
MsgBox "NOI introuvable"
.Close 0
End Subbonjour Progeric,
c'est la place de votre "Public ynoi", je suppose quand vous le déplacer vers un module normal, par exemple "module 1" ou un autre existant (et supprimer dans ce module d'une feuille) que cela fonctionnera.
autrement ajouter votre fichier
Non, cela ne fonctionne pas mieux
et donc ....
Sachez aussi que la variable Target de Private Sub Worksheet_Change(ByVal Target As Range) est une variable locale. Target n'est connue qu'au sein de la procédure Worksheet_Change.
Quand dansWorksheet_Change vous appelez ajoutnoi, la procédure ajoutnoi ne connaitra pas Target. Target sera considéré comme faisant référence à un variant non initialisée.
Il faut (d'après moi) minimiser au maximum le nombre de variables publiques.
Je préfère également utiliser "Option Explicit" en début de tout module. Cette option demande à ce que toutes les variables soient déclarées avant leur utilisation. Avec cette option, vous auriez obtenu une erreur à la compilation indiquant que Target n'est pas connu de ajoutnoi.
Pour minimiser le nombre de variables publiques, on peut définir sub ajoutnoi avec des paramètres et on appellera cette procédure avec les bons arguments. Un exemple :
- définir ajoutnoi par ajoutnoi(ByVal TargetLig, ByVal TargetCol, ByVal NoiCol)
- et depuis Worksheet_Change l'appeler avec : Call ajoutnoi(Target.Row, Target.Column, ynoi)
Ce n'est pas pour vous embêter qu'on demande un fichier représentatif et anonymisé mais pour que les réponses soient plus pertinentes.
Merci cela fonctionne très bien
