Bonsoir Sebastioen merci pour le contact j'ai crée un userform de recherche de plusieurs colonnes et j'aimerais avoir par exemple 10% et non 0.10
je ne suis pas doué je sollicte votre aide voici les codes de mon userform: Merci de m'aider
Dim f, choix(), rng, BD(), Ncol, ColVisu()
Unload UserForm2
Sheets("Accueil").Visible = xlSheetVisible
Sheets("Accueil").Select
Set f = Sheets("Base_Donnees")
ColVisu = Array(2, 3, 8, 12, 16, 17, 18, 19) ' colonnes à visualiser
Set rng = f.Range("A2:U" & f.[a65000].End(xlUp).Row)
BD = rng.Value
Ncol = UBound(ColVisu) + 1
'-- en têtes de colonne ListBox
x = 18
Y = Me.ListBox1.Top - 12
For Each k In ColVisu
Set Lab = Me.Controls.Add("Forms.Label.1")
Lab.Caption = f.Cells(1, k)
Lab.Top = Y
Lab.Left = x
x = x + f.Columns(k).Width * 0.9
temp = temp & f.Columns(k).Width * 0.9 & ";"
temp = Left(temp, Len(temp) - 1)
Me.ListBox1.ColumnCount = UBound(ColVisu) + 1
Me.ListBox1.ColumnWidths = temp
TblTmp = rng.Value
For i = LBound(BD) To UBound(BD)
ReDim Preserve choix(1 To i)
choix(i) = choix(i) & BD(i, k) & " * "
Next k
'--- valeurs initiales dans ListBox
Dim Tbl(): ReDim Tbl(1 To UBound(BD), 1 To Ncol)
For i = 1 To UBound(BD)
c = 0
c = c + 1: Tbl(i, c) = BD(i, k)
Next k
'TriMultiCol Tbl, LBound(Tbl), UBound(Tbl), 1
Me.ListBox1.List = Tbl
Me.Label1.Caption = Me.ListBox1.ListCount & " Ligne(s)"
Private Sub TextBox1_Change()
If Me.TextBox1 <> "" Then
mots = Split(Trim(Me.TextBox1), " ")
Tbl = choix
For i = LBound(mots) To UBound(mots)
Tbl = Filter(Tbl, mots(i), True, vbTextCompare)
If UBound(Tbl) > -1 Then
Dim b(): ReDim b(1 To UBound(Tbl) + 1, 1 To Ncol)
For i = LBound(Tbl) To UBound(Tbl)
a = Split(Tbl(i), "*")
For k = 1 To Ncol: b(i + 1, k) = a(k - 1): Next k
Me.ListBox1.List = b
Me.Label1.Caption = UBound(Tbl) + 1 & " Ligne(s)"
UserForm_Initialize
