Please I am having problem with userform to activate a sheet then searching with two criteria that is by year and month to populate other fields and then update.Kindly assist me. Iam new to vba. Thank you
I made some fixes to your code to make it work, but it's not optimal. I would reduce the number of fields, make use of combobox instead of textbox, ...
It is not working as expected so I want to change it to the combobox. Am asking to clarify if its only the search textbox to be changed to combobox or any other one. Thank you
That when you activate the active sheet and populate the fileds and save it. Then you should be able to edit the submitted data by activating the active sheet and search using year and month criteria to populate the other fields. Edit and hit the update button.
