Excel VBA search with two criteria and then upadte on a multiple sheets
Please I am having problem with userform to activate a sheet then searching with two criteria that is by year and month to populate other fields and then update.Kindly assist me. Iam new to vba. Thank you
Have attached the file
60insu-statements.xlsm (116.02 KB)
Hello Vickwa,
I made some fixes to your code to make it work, but it's not optimal. I would reduce the number of fields, make use of combobox instead of textbox, ...
89insu-statements.xlsm (116.02 KB)
Thank you. Please if I get you clear, you are suggesting that, the search textbox should be changed to combobox.
Kindly help me with the fixes and where to reduce the number of fields.
Thank you
Hello,
First of all, is this working as expected?
Take my suggestion for what it is "I would do it differently", but if you are happy with how it works, there is no need to change.
It is not working as expected so I want to change it to the combobox. Am asking to clarify if its only the search textbox to be changed to combobox or any other one. Thank you
hi,
How do you expect it to work?
That when you activate the active sheet and populate the fileds and save it. Then you should be able to edit the submitted data by activating the active sheet and search using year and month criteria to populate the other fields. Edit and hit the update button.
Thank you
hi,
code fixed for the update.
55insu-statements.xlsm (110.02 KB)
Thank you so much.
That has solved my problems.
Search for threads similar to "vba search two criteria then upadte multiple sheets"
