Filtre sur valeur
il y a très longtemps que je n'ai pas pratiquer VBA.
J'ai ce code :
    ' Filtre du plus petit au plus grand n° de collecte
    Selection.AutoFilter
    ActiveWorkbook.Worksheets("ExportParkfolioTransactions_Oul").AutoFilter.Sort.SortFields.Clear
    ActiveWorkbook.Worksheets("ExportParkfolioTransactions_Oul").AutoFilter.Sort. _
    SortFields.Add2 Key:=Range("A1:A32260"), SortOn:=xlSortOnValues, Order:= _
    xlAscending, DataOption:=xlSortNormal
    With ActiveWorkbook.Worksheets("ExportParkfolioTransactions_Oul").AutoFilter.Sort
        .Header = xlYes
        .MatchCase = False
        .Orientation = xlTopToBottom
        .SortMethod = xlPinYin
        .Apply
    Selection.AutoFilter ' Ouvre le filtre
    Dim st1#, st2#, st3#, st4#, st5#, st6#, st7#, st8#, st9#, st10#, st11#, st12#, st13#, st14#, st15#, st16#, st17#, st18#, st19#, st20#
    Dim st21#, st22#, st23#, st24#, st25#, st26#, st27#, st28#, st29#, st30#, st31#, st32#, st33#, st34#, st35#, st36#, st37#, st38#, st39#, st40#
    Dim st41#, st42#, st43#, st44#, st45#, st46#, st47#, st48#, st49#, st50#, st51#, st52#, st53#, st54#, st55#, st56#, st57#, st58#, st59#, st60#
    Dim st61#, st62#, st63#, st64#, st65#, st66#, st67#, st68#, st69#, st70#, st71#, st72#, st73#
    'numCollecte = Range("A2").Value
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2534"
        Columns("B:B").Select
        st1# = Application.Subtotal(9, Selection)
        MsgBox st1#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2535"
        st2# = Application.Subtotal(9, Selection)
        MsgBox st2#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2536"
        st3# = Application.Subtotal(9, Selection)
        MsgBox st3#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2537"
        st4# = Application.Subtotal(9, Selection)
        MsgBox st4#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2538"
        st5# = Application.Subtotal(9, Selection)
        MsgBox st5#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2539"
        st6# = Application.Subtotal(9, Selection)
        MsgBox st6#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2540"
        st7# = Application.Subtotal(9, Selection)
        MsgBox st7#
        ActiveSheet.Range("$A$1").AutoFilter Field:=1, Criteria1:="2541"
        st8# = Application.Subtotal(9, Selection)
        MsgBox st8#
    Selection.AutoFilter ' Ferme le filtre
cela concerne la partie du bas ou j'ai créer toutes ces variables : st1# st2# etc...qui me permettent de récupérer les valeurs lorsque je procèdes à un filtre sur chaque valeur de ma 1ère colonne ex : "2534" je récupère mon sous total, "2535" je récupère mon sous total , etc. etc...
Comment je pourrais faire pour ne pas taper 73 fois au total toutes ces lignes ?
        MsgBox st8#
sachant que je dois aller de 2534 à 2607.
Tu devrais joindre ton fichier, au besoin anonymisé....
Bye !
J'ai bossé dur et j'ai trouvé cela :
Dim sousTotal#
    Dim numCollecte%
    Dim maCellule As Range
    numCollecte = Range("D2").Value
        For i = numCollecte To 2743
                ActiveSheet.Range("$D$1").AutoFilter Field:=4, Criteria1:=i
                Columns("E:E").Select
                sousTotal = Application.Subtotal(9, Selection)
                Select Case numCollecte
                    Case Is = 2534
                    Set maCellule = ThisWorkbook.Sheets("Feuil1").Range("D29")
                    maCellule.Value = sousTotal
                    Case Is = 2535
                    Set maCellule = ThisWorkbook.Sheets("Feuil1").Range("D30")
                    Case Is = 2536
                    Set maCellule = ThisWorkbook.Sheets("Feuil1").Range("D31")
                End Select
                'MsgBox sousTotal
            If (sousTotal < 1) Then
            Exit For
la boucle fonctionne bien, sauf que maintenant c'est avec "Select Case Is" que je bloque.
Je veux que lorsque ma boucle trouve par exemple la valeur : 2534, que cela me copie la valeur de la variable "sousTotal" dans la cellule "D29". et ainsi de suite....
Alors, quand je lance le prog ca va jusqu'au bout, mais rien n'est copié dans cette cellule "D29" ??
bon j'ai trouvé ca :
Dim sousTotal#
    Dim numCollecte%
                'MsgBox i
                souTsotal = Application.Subtotal(9, Selection)
                    Sheets("Feuil1").Range("A1").Value = i
                    Sheets("Feuil1").Range("B1").Value = souTsotal
               MsgBox sousTotal
                Exit For
Mes variables i et sousTotal sont bien copié dans A1 et B1 respectivement.
Mais je voudrais que cela continue en copiant les nouvelles variables i et sousTotal dans A2 et B2, A3 et B3, etc etc...
Il faut que je fasse une boucle for mais comment ?
bonjour quattro1
comme ceci ?
Sub test()
     Dim sousTotal#
     Dim numCollecte%
     Sheets("Feuil1").Range("A1").Resize(, 2).EntireColumn.ClearContents     'vider ces 2 colonnes
     With ActiveSheet
          numCollecte = .Range("D2").Value
               'MsgBox i
               souTsotal = Application.Subtotal(9, .Columns("E"))
               Sheets("Feuil1").Range("A" & i - numCollecte + 1).Resize(, 2).Value = Array(i, souTsotal)
               If (sousTotal < 1) Then Exit For
merci, très bien.
maintenant je m'aperçois que j'ai plusieurs plage de la variable "numCollecte" à vérifier et non pas :
mes plages s'organisent comme ca :
"numCollecte" allant de : 2534 à 2572.
"numCollecte" allant de : 2707 à 2720.
"numCollecte" allant de : 2722 à 2726.
"numCollecte" allant de : 2728 à 2739.
"numCollecte" allant de : 2741 à 2743.
Car sinon je suis obligé de passer par des valeurs de "numCollecte" qui ne m'intéresse pas du tout, et alourdie du coup ma boucle FOR.
Faut il faire le code avec un FOR comme auparavant ? ou bien passé par autre chose ?
j'ai trouvé cela :
Dim sousTotal#
     Dim numCollecte%
     With ActiveSheet
            If (i >= 2534 And i <= 2572) Or (i >= 2707 And i <= 2720) _
            Or (i >= 2722 And i <= 2726) Or (i >= 2728 And i <= 2739) _
            Or (i >= 2741 And i <= 2743) Then
              'MsgBox i
              sousTotal = Application.Subtotal(9, .Columns("E"))
              Sheets("Feuil1").Range("A" & i - numCollecte + 1).Resize(, 2).Value = Array(i, sousTotal)
              If (sousTotal < 0) Then Exit For
en insérant la condition IF cela fonctionne, sauf que, je me retrouve avec des lignes vide entre chaque paliers, donc du vide....
comment les supprimer ?
re,
     Dim sousTotal#
     Dim numCollecte%
     With ActiveSheet
               Select Case i
                    Case 2534 To 2572, 2707 To 2720, 2722 To 2726, 2728 To 2739, 2741 To 2743
                         Sheets("Feuil1").Range("A" & Rows.Count).End(xlUp).Offset(1).Resize(, 2).Value = Array(i, sousTotal)
               End Select
Rechercher des sujets similaires à "filtre valeur"
