VBA Excel import appointment des calendriers partagés outlook
J'essaye en vain de trouver une solution pour importer les items de plusieurs calendrier partagés simultanément.
Je parviens à le faire pour un calendriers partagé à l'aide de la macro ci-dessous.
Y-a-t-il une solution pour boucler sur les calendriers partagés définis ?
Merci pour votre aide.
Public Sub ListAppointments()
On Error GoTo ErrHand:
    'This is an enumeration value in context of getDefaultSharedFolder
    Const olFolderCalendar As Byte = 9
    Dim OLApp       As Object: Set OLApp = CreateObject("Outlook.Application")
    Dim olNS        As Object: Set olNS = OLApp.GetNamespace("MAPI")
    Dim olFolder    As Object
    Dim olFolder2    As Object
    Dim olApt       As Object
    Dim objOwner    As Object: Set objOwner = olNS.CreateRecipient("paul.durand@dom.fr")
    Dim objOwner2   As Object: Set objOwner2 = olNS.CreateRecipient("pierre.dupont@dom.fr")
    Dim NextRow     As Long
    Dim ws          As Worksheet: Set ws = ThisWorkbook.Sheets("calend")
    Dim FromDate As Date
    Dim ToDate As Date
    FromDate = InputBox("Enter the start date (format: dd/mm/yyyy)")
   ToDate = InputBox("Enter the end date(format: dd/mm/yyyy)")
    objOwner.Resolve
    objOwner2.Resolve
    If (objOwner.Resolved And objOwner2.Resolve) Then
        Set olFolder = olNS.GetSharedDefaultFolder(objOwner, olFolderCalendar)
        Set olFolder2 = olNS.GetSharedDefaultFolder(objOwner2, olFolderCalendar)
        'Set olFolder = olNS.GetSharedDefaultFolder(9)
    Worksheets("calend").Cells.ClearContents
    ws.Range("A1:E1").Value2 = Array("Subject", "Start", "End", "Location", "Name")
    'Ensure there at least 1 item to continue
    Debug.Print olFolder.Items.Count
    Debug.Print objOwner.Name
    Debug.Print objOwner2.Name
    If (olFolder.Items.Count = 0 And olFolder2.Items.Count = 0) Then Exit Sub
    'Create an array large enough to hold all records
    Dim myArr() As Variant: ReDim myArr(0 To 4, 0 To olFolder.Items.Count - 1)
    'Add the records to an array
    'Add this error skip, as I found some of my calendar items don't have all properties e.g. a start time
    On Error Resume Next
    For Each olApt In olFolder.Items
    If (olApt.Subject <> "?PRESENT" And olApt.Subject <> "PRESENT") Then
    If (olApt.Start >= FromDate And olApt.Start <= ToDate) Then
        myArr(0, NextRow) = olApt.Subject
        myArr(1, NextRow) = olApt.Start
        myArr(2, NextRow) = olApt.End
        myArr(3, NextRow) = olApt.Location
        myArr(4, NextRow) = objOwner.Name
        NextRow = NextRow + 1
    Next olApt
     Set olApt = Nothing
        Set olFolder = Nothing
        Set olNS = Nothing
        Set OLApp = Nothing
    On Error GoTo 0
    'Write all records to a worksheet from an array, this is much faster
    ws.Range("A2:E" & NextRow + 1).Value = WorksheetFunction.Transpose(myArr)
    'AutoFit
    ws.Columns.AutoFit
cleanExit:
    Exit Sub
ErrHand:
    'Add error handler
    Resume cleanExit
après plusieurs recherches, je ne trouve pas de solution.
Quelqu’un a-t-il déjà effectué ce type de macro.
ci-dessous proposition de code :
    Const olExchange As Byte = 0
    Dim compte As Object, récipient As Object
    Dim calendriers_partagés As Object, calendrier_partagé As Object
    Dim filtre As String
    Dim rdvts_trouvés As Object, olApt As Object
    Dim NextRow As Long
    Dim ToDate As Date
    Dim myArr()
    FromDate = CDate(InputBox("Enter the start date (format: dd/mm/yyyy)"))
    ToDate = CDate(InputBox("Enter the end date(format: dd/mm/yyyy)"))
    For Each compte In OLApp.Session.Accounts
        If compte.AccountType = olExchange Then
            Set récipient = OLApp.Session.CreateRecipient(compte.DisplayName)
            Set calendriers_partagés = OLApp.Session.GetSharedDefaultFolder(récipient, olFolderCalendar)
            If Not calendriers_partagés Is Nothing Then GoSub Stockage_rdvts
    Next compte
    If UBound(myArr) > -1 Then ws.Range("A2").Resize(UBound(myArr)+1, 5).Value = Application.Index(myArr, 0, 0) _
    Else MsgBox "no appointment found"
    'AutoFit
    ws.Columns.AutoFit
    Set OLApp = Nothing
    On Error GoTo 0
cleanExit:
    Exit Sub
Stockage_rdvts:
    For Each calendrier_partagé In calendriers_partagés.Folders
        'filtrage des rdvs correspondant à la fourchette de dates
        filtre = "[Start] > '" & FromDate & "'" & "And" & "[Start] < '" & ToDate + 1 & "'"
        Set rdvts_trouvés = calendrier_partagé.Items.Restrict(filtre)
        rdvts_trouvés.Sort "[Start]"
        'analyse des rdvts trouvés
        For Each olApt In rdvts_trouvés
                ReDim Preserve myArr(NextRow)
                myArr(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, calendrier_partagé.Name)
        Next olApt
    Next calendrier_partagé
    Return
ErrHand:
    'Add error handler
    Resume cleanExit
Je viens de mettre en place votre macro et je vous remercie.
Par contre, seul mon adresse email ressort dans la variable récipient.
De plus les rendez-vous de mon compte ne s'affiche pas dans la feuille calend
Je vous remercie pour votre aide.
C'est logique car c'est a priori le seul compte Microsoft Exchange dont vous disposez dans Outlook
Sauf erreur, votre demande ne concernait que les calendriers partagés et non le calendrier associé à votre compte Microsoft Exchange. Reprécisez votre demande.
J'ai accès en lecture avec tous les détails aux calendriers de mes collègues.
Ces calendriers se trouvent dans le dossiers Calendriers partagés de mon clients outlook.
Je parviens bien à faire la requête des rendez-vous individuellement, avec la macro ci-dessous
Par contre je souhaiterais les requêter ensemble pour récupérer les rendez-vous de tous par une seule action.
    Dim olApt       As Object
    Dim NextRow     As Long
    Dim ToDate As Date
    objOwner.Resolve
    objOwner2.Resolve
    Next olApt
     Set olApt = Nothing
        Set olNS = Nothing
        Set OLApp = Nothing
    On Error GoTo 0
    'AutoFit
    ws.Columns.AutoFit
cleanExit:
    Exit Sub
ErrHand:
    'Add error handler
    Resume cleanExit
ci-joint code listant vos calendriers partagés ainsi que le vôtre
    'Constantes Outlook
    Const olAppointmentItem = 1
    'Variables Outlook
    Dim compte As Object, récipient As Object, dossier As Object
    Dim calendriers_partagés As Object, calendrier As Object
    Dim filtre As String, ref_calendrier As String
    Dim NextRow As Long
    Dim FromDate As Date, ToDate As Date
    Dim myArr()
            'stockage rdvs du compte microsoft Exchange
            For Each dossier In OLApp.Session.Folders(compte.DisplayName).Folders
                If dossier.DefaultItemType = olAppointmentItem Then
                    Set calendrier = dossier
                    Exit For
            Next dossier
            'stockage rdvs des calendriers partagés avec le compte microsoft Exchange
            For Each calendrier In calendriers_partagés.Folders
            Next calendrier
    Next compte
    'remplissage de la feuille à partir des rdvs stockés
    If UBound(myArr) > -1 Then ws.Range("A2").Resize(UBound(myArr) + 1, 5).Value = Application.Index(myArr, 0, 0) _
    'AutoFit
    ws.Columns.AutoFit
    Set OLApp = Nothing
    On Error GoTo 0
cleanExit:
    Exit Sub
Stockage_rdvts:
    Set rdvts_trouvés = calendrier.Items.Restrict(filtre)
            ref_calendrier = calendrier.Parent.Name & "-" & calendrier.Name
            myArr(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, ref_calendrier)
    Next olApt
    Return
ErrHand:
    'Add error handler
    MsgBox "Erreur traitement " & Err.Description
    Resume cleanExit
Merci pour votre réponse.
Je viens de tester la macro, mais à nouveau seul mon calendrier s'importe sur la feuille.
Ce que je ne m'explique pas c'est que je parviens, comme je vous l'ai dit à importer individuellement avec la dernière macro que je vous ai présentée plus haut.
Autre petit détail les dates s'inversent entre le mois et le jour.
Quand je fais un Debug, seuls s'affichent :
Attente
Boîte de réception
Boîte d'envoi
Brouillons
Calendrier
Quand je liste les calendriers partagés avec la macro ci-dessous, j'obtiens bien tous les noms des personnes qui partages leur calendrier dans Calendrier partagés
Sub ListSharedCalendars()
    Dim objExpCal As Outlook.Explorer
    Dim objNavMod As Outlook.CalendarModule
    Dim objNavGroup As Outlook.NavigationGroup
    Dim objNavFolder As Outlook.NavigationFolder
    Dim objFolder As Outlook.Folder
    Set objExpCal = Session.GetDefaultFolder(olFolderCalendar).GetExplorer
    Set objNavMod = objExpCal.NavigationPane.Modules.GetNavigationModule(olModuleCalendar)
    Set objNavGroup = objNavMod.NavigationGroups.GetDefaultNavigationGroup(olPeopleFoldersGroup)
    For Each objNavFolder In objNavGroup.NavigationFolders
        Debug.Print objNavFolder.DisplayName
    Set objNavMod = Nothing
    Set objNavGroup = Nothing
    Set objNavFolder = Nothing
    Set objFolder = Nothing
Avec code, vous récupérez effectivement tous les calendriers présents dans Outlook.
Je pense qu'il y a ambiguïté sur le mot "calendrier partagé". Mon code correspond aux calendriers qui ont été partagés avec votre compte Microsoft présent dans Outllook. Autrement dit, une action de partage a été effectué sur les calendriers de vos personnes et envoyée à l'adresse de votre compte Microsoft.
Les calendriers de vos personnes ont dû être ajoutés différemment, sans doute via la fonction "ajouter calendrier" disponible dans Outlook.
Les personnes ont ajouté le partage de leur calendrier via la fenêtre de "propriété Calendrier" en ajoutant mon nom dans les autorisations d'accès avec une lecture.
Je viens de faire l'essai avec un partage de calendrier reçu par mail, mais la conclusion est la même, les données ne s'affichent pas.
Quelle est la procédure dont vous parlez pour le partage ?
Bonne journée
Déjà nous avons une différence de version : Office 2010 pour vous, Office 2021 pour moi.
Ensuite, connectez -vous à votre compte Microsoft sur le Web et choisissez l'application calendrier. Si les calendriers des personnes ont bien été partagés avec votre compte, vous devez les voir apparaître dans le groupe "autres calendriers".
Vous y avez l'option de partager votre calendrier avec d'autres personnes. C'est la procédure que j'ai suivie et les calendriers partagés se sont retrouvés dans mon Outlook.
Tout d'abord je vous remercie.
J'ai testé votre solution sans succès.
La seul macro qui fonctionne est la macro ci-dessous, mais elle me permets seulement de requêter un calendrier partagé à la fois.
Pensez-vous qu'il est possible de créer un boucle dont les calendriers seraient alimentés par un liste ?
Merci.
    Dim olApt       As Object
    Dim NextRow     As Long
    Dim ToDate As Date
    objOwner.Resolve
    objOwner2.Resolve
    Next olApt
     Set olApt = Nothing
        Set olNS = Nothing
        Set OLApp = Nothing
    On Error GoTo 0
    'AutoFit
    ws.Columns.AutoFit
cleanExit:
    Exit Sub
ErrHand:
    'Add error handler
    Resume cleanExit
ci-dessous un code qui liste les rendez-vous pour tous vos calendriers
Sub lister_rdvs()
    'Constantes Outlook
    Const olCalendarModule = 159
    Const olFolderInbox As Byte = 6
    Const olMinimized As Byte = 1
    'Variables Outlook
    Dim OLApp As Object, OLExp As Object
    Dim module As NavigationModule
    Dim module_calendrier As CalendarModule
    Dim groupe_calendriers As NavigationGroup
    Dim calendrier_dossier As NavigationFolder
    Dim calendrier As folder
    Dim NextRow As Long
    Dim tb(): tb = Array("")
    '// assignation application Outlook et explorateur
    ' si OutLook n'est pas ouvert .....................
    If OLApp.Explorers.Count = 0 Then
        OLApp.Session.GetDefaultFolder(olFolderInbox).Display
        OLApp.ActiveExplorer.WindowState = olMinimized
    Set OLExp = OLApp.ActiveExplorer
    '// assignation fourchette de dates
    FromDate = CDate(InputBox("Date de début (format: dd/mm/yyyy)"))
    ToDate = CDate(InputBox("Date de fin(format: dd/mm/yyyy)"))
'// initialisation feuille "Calend"
    With ThisWorkbook.Sheets("calend")
        .Columns("B:C").NumberFormat = "m/d/yyyy"
        .Range("A1:E1").Value2 = Array("Sujet", "Début", "Fin", "Emplacement", "Nom")
    '// exploration des calendriers
    For Each module In OLExp.NavigationPane.Modules
        If module.Class = olCalendarModule Then
            For Each groupe_calendriers In module.NavigationGroups
                For Each calendrier_dossier In groupe_calendriers.NavigationFolders
                    'assignation du calendrier
                    Set calendrier = calendrier_dossier.folder
                    'stockage rdvs du calendrier
                Next calendrier_dossier
            Next groupe_calendriers
            Exit For
    Next module
    '// remplissage de la feuille à partir des rdvs stockés
        If UBound(tb) > -1 Then .Range("A2").Resize(UBound(tb) + 1, 5).Value = Application.Index(tb, 0, 0) _
        Else MsgBox "pas de rdvts trouvés"
    '// sortie procédure
    Exit Sub
'// sous_procédure de stockage des rdvts dans un tableau selon filtre de dates
Stockage_rdvts:
            ReDim Preserve tb(NextRow)
            ref_calendrier = calendrier.Name & "-" & calendrier.store.DisplayName
            tb(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, ref_calendrier)
    Next olApt
    Return
J'ai une erreur d'indice d'exécution 9 à la ligne :
ref_calendrier = calendrier.Name & "-" & Split(calendrier.FolderPath, "\")(2)
Ajouter les constantes Outlook
Sub lister_rdvs()
    'Constantes Outlook
    'Variables Outlook
    'Variables Outlook
Si ça ne marche pas, remplacer l'instruction par :
A présent il semble que cela fonctionne, hormis le nom des calendriers.
J'obtiens "-calendrier" sans avoir le nom du calendrier du propriétaire du calendrier partagé.
Aussi, j'ai toujours le problème de l'inversion jour/mois dans les dates.
Merci à vous.
Après l'instruction
Faites un Debug
Debug.Print calendrier.FolderPath
et communiquez les résultat obtenus
insérer une instruction de formatage de date dans ce groupe d'instructions :
Rechercher des sujets similaires à "vba import appointment calendriers partages outlook"
