VBA Excel import appointment des calendriers partagés outlook
J'essaye en vain de trouver une solution pour importer les items de plusieurs calendrier partagés simultanément.
Je parviens à le faire pour un calendriers partagé à l'aide de la macro ci-dessous.
Y-a-t-il une solution pour boucler sur les calendriers partagés définis ?
Merci pour votre aide.
Public Sub ListAppointments()
On Error GoTo ErrHand:
'This is an enumeration value in context of getDefaultSharedFolder
Const olFolderCalendar As Byte = 9
Dim OLApp As Object: Set OLApp = CreateObject("Outlook.Application")
Dim olNS As Object: Set olNS = OLApp.GetNamespace("MAPI")
Dim olFolder As Object
Dim olFolder2 As Object
Dim olApt As Object
Dim objOwner As Object: Set objOwner = olNS.CreateRecipient("paul.durand@dom.fr")
Dim objOwner2 As Object: Set objOwner2 = olNS.CreateRecipient("pierre.dupont@dom.fr")
Dim NextRow As Long
Dim ws As Worksheet: Set ws = ThisWorkbook.Sheets("calend")
Dim FromDate As Date
Dim ToDate As Date
FromDate = InputBox("Enter the start date (format: dd/mm/yyyy)")
ToDate = InputBox("Enter the end date(format: dd/mm/yyyy)")
objOwner.Resolve
objOwner2.Resolve
If (objOwner.Resolved And objOwner2.Resolve) Then
Set olFolder = olNS.GetSharedDefaultFolder(objOwner, olFolderCalendar)
Set olFolder2 = olNS.GetSharedDefaultFolder(objOwner2, olFolderCalendar)
'Set olFolder = olNS.GetSharedDefaultFolder(9)
Worksheets("calend").Cells.ClearContents
ws.Range("A1:E1").Value2 = Array("Subject", "Start", "End", "Location", "Name")
'Ensure there at least 1 item to continue
Debug.Print olFolder.Items.Count
Debug.Print objOwner.Name
Debug.Print objOwner2.Name
If (olFolder.Items.Count = 0 And olFolder2.Items.Count = 0) Then Exit Sub
'Create an array large enough to hold all records
Dim myArr() As Variant: ReDim myArr(0 To 4, 0 To olFolder.Items.Count - 1)
'Add the records to an array
'Add this error skip, as I found some of my calendar items don't have all properties e.g. a start time
On Error Resume Next
For Each olApt In olFolder.Items
If (olApt.Subject <> "?PRESENT" And olApt.Subject <> "PRESENT") Then
If (olApt.Start >= FromDate And olApt.Start <= ToDate) Then
myArr(0, NextRow) = olApt.Subject
myArr(1, NextRow) = olApt.Start
myArr(2, NextRow) = olApt.End
myArr(3, NextRow) = olApt.Location
myArr(4, NextRow) = objOwner.Name
NextRow = NextRow + 1
Next olApt
Set olApt = Nothing
Set olFolder = Nothing
Set olNS = Nothing
Set OLApp = Nothing
On Error GoTo 0
'Write all records to a worksheet from an array, this is much faster
ws.Range("A2:E" & NextRow + 1).Value = WorksheetFunction.Transpose(myArr)
'AutoFit
ws.Columns.AutoFit
cleanExit:
Exit Sub
ErrHand:
'Add error handler
Resume cleanExit
End SubBonjour,
après plusieurs recherches, je ne trouve pas de solution.
Quelqu’un a-t-il déjà effectué ce type de macro.
- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
- bénévole associations Goutte d'Or
ci-dessous proposition de code :
Const olExchange As Byte = 0
Dim compte As Object, récipient As Object
Dim calendriers_partagés As Object, calendrier_partagé As Object
Dim filtre As String
Dim rdvts_trouvés As Object, olApt As Object
Dim NextRow As Long
Dim ToDate As Date
Dim myArr()
FromDate = CDate(InputBox("Enter the start date (format: dd/mm/yyyy)"))
ToDate = CDate(InputBox("Enter the end date(format: dd/mm/yyyy)"))
For Each compte In OLApp.Session.Accounts
If compte.AccountType = olExchange Then
Set récipient = OLApp.Session.CreateRecipient(compte.DisplayName)
Set calendriers_partagés = OLApp.Session.GetSharedDefaultFolder(récipient, olFolderCalendar)
If Not calendriers_partagés Is Nothing Then GoSub Stockage_rdvts
Next compte
If UBound(myArr) > -1 Then ws.Range("A2").Resize(UBound(myArr)+1, 5).Value = Application.Index(myArr, 0, 0) _
Else MsgBox "no appointment found"
'AutoFit
ws.Columns.AutoFit
Set OLApp = Nothing
On Error GoTo 0
cleanExit:
Exit Sub
Stockage_rdvts:
For Each calendrier_partagé In calendriers_partagés.Folders
'filtrage des rdvs correspondant à la fourchette de dates
filtre = "[Start] > '" & FromDate & "'" & "And" & "[Start] < '" & ToDate + 1 & "'"
Set rdvts_trouvés = calendrier_partagé.Items.Restrict(filtre)
rdvts_trouvés.Sort "[Start]"
'analyse des rdvts trouvés
For Each olApt In rdvts_trouvés
ReDim Preserve myArr(NextRow)
myArr(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, calendrier_partagé.Name)
Next olApt
Next calendrier_partagé
Return
ErrHand:
'Add error handler
Resume cleanExit
End SubBonjour,
Je viens de mettre en place votre macro et je vous remercie.
Par contre, seul mon adresse email ressort dans la variable récipient.
De plus les rendez-vous de mon compte ne s'affiche pas dans la feuille calend
Je vous remercie pour votre aide.
- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
C'est logique car c'est a priori le seul compte Microsoft Exchange dont vous disposez dans Outlook
Sauf erreur, votre demande ne concernait que les calendriers partagés et non le calendrier associé à votre compte Microsoft Exchange. Reprécisez votre demande.
J'ai accès en lecture avec tous les détails aux calendriers de mes collègues.
Ces calendriers se trouvent dans le dossiers Calendriers partagés de mon clients outlook.
Je parviens bien à faire la requête des rendez-vous individuellement, avec la macro ci-dessous
Par contre je souhaiterais les requêter ensemble pour récupérer les rendez-vous de tous par une seule action.
Dim olApt As Object
Dim NextRow As Long
Dim ToDate As Date
objOwner.Resolve
objOwner2.Resolve
Next olApt
Set olApt = Nothing
Set olNS = Nothing
Set OLApp = Nothing
On Error GoTo 0
'AutoFit
ws.Columns.AutoFit
cleanExit:
Exit Sub
ErrHand:
'Add error handler
Resume cleanExit
End Sub- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
ci-joint code listant vos calendriers partagés ainsi que le vôtre
'Constantes Outlook
Const olAppointmentItem = 1
'Variables Outlook
Dim compte As Object, récipient As Object, dossier As Object
Dim calendriers_partagés As Object, calendrier As Object
Dim filtre As String, ref_calendrier As String
Dim NextRow As Long
Dim FromDate As Date, ToDate As Date
Dim myArr()
'stockage rdvs du compte microsoft Exchange
For Each dossier In OLApp.Session.Folders(compte.DisplayName).Folders
If dossier.DefaultItemType = olAppointmentItem Then
Set calendrier = dossier
Exit For
Next dossier
'stockage rdvs des calendriers partagés avec le compte microsoft Exchange
For Each calendrier In calendriers_partagés.Folders
Next calendrier
Next compte
'remplissage de la feuille à partir des rdvs stockés
If UBound(myArr) > -1 Then ws.Range("A2").Resize(UBound(myArr) + 1, 5).Value = Application.Index(myArr, 0, 0) _
'AutoFit
ws.Columns.AutoFit
Set OLApp = Nothing
On Error GoTo 0
cleanExit:
Exit Sub
Stockage_rdvts:
Set rdvts_trouvés = calendrier.Items.Restrict(filtre)
ref_calendrier = calendrier.Parent.Name & "-" & calendrier.Name
myArr(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, ref_calendrier)
Next olApt
Return
ErrHand:
'Add error handler
MsgBox "Erreur traitement " & Err.Description
Resume cleanExit
End SubBonsoir,
Merci pour votre réponse.
Je viens de tester la macro, mais à nouveau seul mon calendrier s'importe sur la feuille.
Ce que je ne m'explique pas c'est que je parviens, comme je vous l'ai dit à importer individuellement avec la dernière macro que je vous ai présentée plus haut.
Autre petit détail les dates s'inversent entre le mois et le jour.
Quand je fais un Debug, seuls s'affichent :
Attente
Boîte de réception
Boîte d'envoi
Brouillons
Calendrier
Quand je liste les calendriers partagés avec la macro ci-dessous, j'obtiens bien tous les noms des personnes qui partages leur calendrier dans Calendrier partagés
Sub ListSharedCalendars()
Dim objExpCal As Outlook.Explorer
Dim objNavMod As Outlook.CalendarModule
Dim objNavGroup As Outlook.NavigationGroup
Dim objNavFolder As Outlook.NavigationFolder
Dim objFolder As Outlook.Folder
Set objExpCal = Session.GetDefaultFolder(olFolderCalendar).GetExplorer
Set objNavMod = objExpCal.NavigationPane.Modules.GetNavigationModule(olModuleCalendar)
Set objNavGroup = objNavMod.NavigationGroups.GetDefaultNavigationGroup(olPeopleFoldersGroup)
For Each objNavFolder In objNavGroup.NavigationFolders
Debug.Print objNavFolder.DisplayName
Set objNavMod = Nothing
Set objNavGroup = Nothing
Set objNavFolder = Nothing
Set objFolder = Nothing
End Sub- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
Avec code, vous récupérez effectivement tous les calendriers présents dans Outlook.
Je pense qu'il y a ambiguïté sur le mot "calendrier partagé". Mon code correspond aux calendriers qui ont été partagés avec votre compte Microsoft présent dans Outllook. Autrement dit, une action de partage a été effectué sur les calendriers de vos personnes et envoyée à l'adresse de votre compte Microsoft.
Les calendriers de vos personnes ont dû être ajoutés différemment, sans doute via la fonction "ajouter calendrier" disponible dans Outlook.
Les personnes ont ajouté le partage de leur calendrier via la fenêtre de "propriété Calendrier" en ajoutant mon nom dans les autorisations d'accès avec une lecture.
Je viens de faire l'essai avec un partage de calendrier reçu par mail, mais la conclusion est la même, les données ne s'affichent pas.
Quelle est la procédure dont vous parlez pour le partage ?
Bonne journée
- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
Déjà nous avons une différence de version : Office 2010 pour vous, Office 2021 pour moi.
Ensuite, connectez -vous à votre compte Microsoft sur le Web et choisissez l'application calendrier. Si les calendriers des personnes ont bien été partagés avec votre compte, vous devez les voir apparaître dans le groupe "autres calendriers".
Vous y avez l'option de partager votre calendrier avec d'autres personnes. C'est la procédure que j'ai suivie et les calendriers partagés se sont retrouvés dans mon Outlook.
Tout d'abord je vous remercie.
J'ai testé votre solution sans succès.
La seul macro qui fonctionne est la macro ci-dessous, mais elle me permets seulement de requêter un calendrier partagé à la fois.
Pensez-vous qu'il est possible de créer un boucle dont les calendriers seraient alimentés par un liste ?
Merci.
Dim olApt As Object
Dim NextRow As Long
Dim ToDate As Date
objOwner.Resolve
objOwner2.Resolve
Next olApt
Set olApt = Nothing
Set olNS = Nothing
Set OLApp = Nothing
On Error GoTo 0
'AutoFit
ws.Columns.AutoFit
cleanExit:
Exit Sub
ErrHand:
'Add error handler
Resume cleanExit
End Sub- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
ci-dessous un code qui liste les rendez-vous pour tous vos calendriers
Sub lister_rdvs()
'Constantes Outlook
Const olCalendarModule = 159
Const olFolderInbox As Byte = 6
Const olMinimized As Byte = 1
'Variables Outlook
Dim OLApp As Object, OLExp As Object
Dim module As NavigationModule
Dim module_calendrier As CalendarModule
Dim groupe_calendriers As NavigationGroup
Dim calendrier_dossier As NavigationFolder
Dim calendrier As folder
Dim NextRow As Long
Dim tb(): tb = Array("")
'// assignation application Outlook et explorateur
' si OutLook n'est pas ouvert .....................
If OLApp.Explorers.Count = 0 Then
OLApp.Session.GetDefaultFolder(olFolderInbox).Display
OLApp.ActiveExplorer.WindowState = olMinimized
Set OLExp = OLApp.ActiveExplorer
'// assignation fourchette de dates
FromDate = CDate(InputBox("Date de début (format: dd/mm/yyyy)"))
ToDate = CDate(InputBox("Date de fin(format: dd/mm/yyyy)"))
'// initialisation feuille "Calend"
With ThisWorkbook.Sheets("calend")
.Columns("B:C").NumberFormat = "m/d/yyyy"
.Range("A1:E1").Value2 = Array("Sujet", "Début", "Fin", "Emplacement", "Nom")
'// exploration des calendriers
For Each module In OLExp.NavigationPane.Modules
If module.Class = olCalendarModule Then
For Each groupe_calendriers In module.NavigationGroups
For Each calendrier_dossier In groupe_calendriers.NavigationFolders
'assignation du calendrier
Set calendrier = calendrier_dossier.folder
'stockage rdvs du calendrier
Next calendrier_dossier
Next groupe_calendriers
Exit For
Next module
'// remplissage de la feuille à partir des rdvs stockés
If UBound(tb) > -1 Then .Range("A2").Resize(UBound(tb) + 1, 5).Value = Application.Index(tb, 0, 0) _
Else MsgBox "pas de rdvts trouvés"
'// sortie procédure
Exit Sub
'// sous_procédure de stockage des rdvts dans un tableau selon filtre de dates
Stockage_rdvts:
ReDim Preserve tb(NextRow)
ref_calendrier = calendrier.Name & "-" & calendrier.store.DisplayName
tb(NextRow) = Array(olApt.Subject, olApt.Start, olApt.End, olApt.Location, ref_calendrier)
Next olApt
Return
End SubJ'ai une erreur d'indice d'exécution 9 à la ligne :
ref_calendrier = calendrier.Name & "-" & Split(calendrier.FolderPath, "\")(2)- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
Ajouter les constantes Outlook
Sub lister_rdvs()
'Constantes Outlook
'Variables Outlook
'Variables Outlook
Dim OLApp As Object, OLExp As ObjectSi ça ne marche pas, remplacer l'instruction par :
ref_calendrier = calendrier.Parent.Name & "-" & calendrier.NameA présent il semble que cela fonctionne, hormis le nom des calendriers.
J'obtiens "-calendrier" sans avoir le nom du calendrier du propriétaire du calendrier partagé.
Aussi, j'ai toujours le problème de l'inversion jour/mois dans les dates.
Merci à vous.
- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
Après l'instruction
ref_calendrier = calendrier.Parent.Name & "-" & calendrier.NameFaites un Debug
Debug.Print calendrier.FolderPathet communiquez les résultat obtenus
- Messages
- 4'199
- Excel
- 2021 FR 64 bits
- Inscrit
- 13/06/2016
- Emploi
insérer une instruction de formatage de date dans ce groupe d'instructions :
