Modification de macro pour avoir l'information depuis une cellule
J'ai une macro que j'arrive pas à modifier.
Sub Macro1()
' Macro1 Macro
    ActiveWorkbook.Queries.Add Name:="Table 0", Formula:= _
        "let" & Chr(13) & "" & Chr(10) & "    Source = Web.Page(Web.Contents(""https://www.leagueofgraphs.com/champions/builds""))," & Chr(13) & "" & Chr(10) & "    Data0 = Source{0}[Data]," & Chr(13) & "" & Chr(10) & "    #""Type modifié"" = Table.TransformColumnTypes(Data0,{{""#"", type text}, {""Name"", type text}, {""Popularity"", type text}, {""Winrate"", type text}, {""BanRate"", type text}, {""KDA"", type text}, {""Pentas/match"", type text}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & " " & _
        "   #""Type modifié"""
    ActiveWorkbook.Worksheets.Add
    With ActiveSheet.ListObjects.Add(SourceType:=0, Source:= _
        "OLEDB;Provider=Microsoft.Mashup.OleDb.1;Data Source=$Workbook$;Location=""Table 0"";Extended Properties=""""" _
        , Destination:=Range("$A$1")).QueryTable
        .CommandType = xlCmdSql
        .CommandText = Array("SELECT * FROM [Table 0]")
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .PreserveColumnInfo = True
        .ListObject.DisplayName = "Table_0"
        .Refresh BackgroundQuery:=False
     ActiveWorkbook.Queries.Add Name:="Table 0 (2)", Formula:= _
        "let" & Chr(13) & "" & Chr(10) & "    Source = Web.Page(Web.Contents(""https://www.leagueofgraphs.com/champions/probuilds""))," & Chr(13) & "" & Chr(10) & "    Data0 = Source{0}[Data]," & Chr(13) & "" & Chr(10) & "    #""Type modifié"" = Table.TransformColumnTypes(Data0,{{""Column1"", type text}, {""Column2"", type text}, {""Column3"", type text}, {""Column4"", type text}, {""Column5"", type text}, {""Column6"", type text}, {""Column7"", type text}," & _
        " {""Column8"", type text}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & "    #""Type modifié"""
        "OLEDB;Provider=Microsoft.Mashup.OleDb.1;Data Source=$Workbook$;Location=""Table 0 (2)"";Extended Properties=""""" _
        .CommandText = Array("SELECT * FROM [Table 0 (2)]")
        .RowNumbers = False
        .SaveData = True
        .RefreshPeriod = 0
        .ListObject.DisplayName = "Table_0__2"
Je souhaiterai que les lien https://www.leagueofgraphs.com/champions/builds et https://www.leagueofgraphs.com/champions/probuilds soit trouver dans l'onglet Feuil1 en A1 et A2 au lieu d'etre dans le sript de la marco.
bonjour,
voici comment il faut faire pour le premier query, à adapter pour le second.
lien1 = Chr(34) & Sheets("feuil1").Range("A2") & Chr(34)
        "let" & Chr(13) & "" & Chr(10) & "    Source = Web.Page(Web.Contents(" & lien1 & "))," & Chr(13) & "" & Chr(10) & "    Data0 = Source{0}[Data]," & Chr(13) & "" & Chr(10) & "    #""Type modifié"" = Table.TransformColumnTypes(Data0,{{""#"", type text}, {""Name"", type text}, {""Popularity"", type text}, {""Winrate"", type text}, {""BanRate"", type text}, {""KDA"", type text}, {""Pentas/match"", type text}})" & Chr(13) & "" & Chr(10) & "in" & Chr(13) & "" & Chr(10) & " " & _
Merci mais Je n'arrive pas à le faire fonctionne.
Est ce qu'il est possible de l'avoir dans un fichier ou le code entier, j'ai du mal le placer.
rebonjour,
voici le fichier avec la macro adaptée.
C'est super merci.
le petit plus que je vais devoir chercher maintement, c'est de mettre le mon des onglet directement.
Je souhaiterais que l'importation de la page https://www.leagueofgraphs.com/champions/builds que l'onglet s'appelle "builds"
et que https://www.leagueofgraphs.com/champions/probuilds l'onglet s'appelle probuilds
est ce que c'est simple à faire?
bonjour,
c'est ma dernière contribution sur ce sujet.
Rechercher des sujets similaires à "modification macro information"
