Somme si ens en VBA
on peut bloquer les calculs le temps que toutes les formules soient écrites puis lancer le calcul à la fin, mais au final je pense que se sera pareil.
ajout de:
Application.Calculation = xlCalculationManualet de:
Application.Calculation = xlCalculationAutomaticle code:
If Target.Column < 9 Then
On Error GoTo Sortie
DerLig = Sheets("Forecasts").Range("A" & Rows.Count).End(xlUp).Row
For i = 11 To DerLig
Select Case Cells(i, "H")
Case Is = "LY Invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$2;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!$F:$F;""Fd de rayon"")"
Case Is = "LY Promo invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$2;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!F:F;""Commande Promotionnelle"")"
Case Is = "LY Total Invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$2;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ")"
Case Is = "Invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$4;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!$F:$F;""Fd de rayon"")"
Case Is = "Promo invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$4;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!F:F;""Commande Promotionnelle"")"
Case Is = "Total Invoiced"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$4;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ")"
End Select
Range("BQ11:BQ" & DerLig).FormulaR1C1 = "=SUM(RC[-60]:RC[-49])"
Range("BR11:BR" & DerLig).FormulaR1C1 = "=SUM(RC[-61]:RC[-53])"
Range("BS11:BS" & DerLig).FormulaR1C1 = "=SUM(RC[-53]:RC[-51])"
Range("BT11:BT" & DerLig).FormulaR1C1 = "=SUM(RC[-51]:RC[-40])"
Range("BU11:BU" & DerLig).FormulaR1C1 = "=SUM(RC[-52]:RC[-44])"
Range("BV11:BV" & DerLig).FormulaR1C1 = "=SUM(RC[-44]:RC[-42])"
Range("BW11:BW" & DerLig).FormulaR1C1 = "=SUM(RC[-42]:RC[-31])"
Range("BX11:BX" & DerLig).FormulaR1C1 = "=SUM(RC[-43]:RC[-35])"
Range("BY11:BY" & DerLig).FormulaR1C1 = "=SUM(RC[-35]:RC[-33])"
Range("BZ11:BZ" & DerLig).FormulaR1C1 = "=SUM(RC[-33]:RC[-22])"
Range("CA11:CA" & DerLig).FormulaR1C1 = "=SUM(RC[-34]:RC[-26])"
Range("CB11:CB" & DerLig).FormulaR1C1 = "=SUM(RC[-26]:RC[-24])"
Range("CC11:CC" & DerLig).FormulaR1C1 = "=SUM(RC[-24]:RC[-13])"
Range("CD11:CD" & DerLig).FormulaR1C1 = "=SUM(RC[-25]:RC[-17])"
Range("CE11:CE" & DerLig).FormulaR1C1 = "=SUM(RC[-17]:RC[-15])"
'Range("I11:CE" & DerLig).Value = Range("I11:CE" & DerLig).Value 'Enlevez l'apostrophe devant la ligne de code pour ne conserver que les valeurs tout en écrasant les formules
Sortie:
End SubMais le problème ne vient que de là, je viens de voir que les colonnes A,C,D,E,F sont remplies de formules avec des "INDEX " et c'est celles-là qu'il faut aussi intégrer dans le code. Il n'y a que vous qui puissiez le faire puisqu'elles font références à vos dossiers. Utilisez l'enregistreur de macro pour chaque formule, placez-vous sur la ligne 5 et sur chaque colonne comportant une formule et validez chaque formule dans la "barre de formule" ensuite, récupérez ces lignes de codes et modifiez-les pour les coller dans le précédent code avant la ligne "Application.Calculation = xlCalculationAutomatic " sous cette forme:
Exemple pour la colonne A: Range("A5:A" & DerLig)=et la formule récupérée avec l'enregistreur
Faire la même chose pour les autres colonnes.
Cdlt
je me permets de vous solliciter à nouveau afin de savoir si possible désactiver le copier coller à partir de la colonne BQ car il y a des erreurs sur les et à chaque fois ça recolle en dure sur la base des erreurs.
En gros ne laisser la macro pour les somme.si.en que jusque au dernier mois soit Décembre 2023 soit la colonne BP
Quelle serait la manip dans le code pour rajouter une colonne après BP?
D'avance merci de votre aide.
max
Il suffit de mettre une apostrophe au début de chaque ligne de code ci-dessousi:
Range("CE11:CE" & DerLig).FormulaR1C1 = "=SUM(RC[-17]:RC[-15])"ainsi les lignes passeront en remarque (de couleur verte) et elles ne seront plus lues lors de l'exécution du code.
Cdlt
un grand merci à vous
J4AI rajouté ce bout de code afin d'avoir une nouvelle Somme.Si.Ens qui irait sourcer dans une autre feuille nommée "Data Promos":
Case Is = "VRAC PROMO"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data Promos!$F:$F;Data Promos!$A:$A;$A" & i & ";Data Promos!$B:$B;$C" & i & ";Data Promos!$K:$K;I$4;Data Promos!$J:$J;$B" & i & ";Data Promos!$I:$I;$G" & i & ";Data!$D:$D;""VRAC PROMO"")"j'ai écrit le code comme ci-dessous:
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$2;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!$F:$F;""Commande Promotionnelle"")"
Range("I" & i & ":BP" & i).FormulaLocal = "=SOMME.SI.ENS(Data!$H:$H;Data!$C:$C;$A" & i & ";Data!$D:$D;$C" & i & ";Data!$K:$K;I$4;Data!$E:$E;$B" & i & ";Data!$G:$G;$G" & i & ";Data!$F:$F;""Commande Promotionnelle"")"
End Select
'Range("BQ11:BQ" & DerLig).FormulaR1C1 = "=SUM(RC[-60]:RC[-49])"
'Range("BR11:BR" & DerLig).FormulaR1C1 = "=SUM(RC[-61]:RC[-53])"
'Range("BS11:BS" & DerLig).FormulaR1C1 = "=SUM(RC[-53]:RC[-51])"
'Range("BT11:BT" & DerLig).FormulaR1C1 = "=SUM(RC[-51]:RC[-40])"
'Range("BU11:BU" & DerLig).FormulaR1C1 = "=SUM(RC[-52]:RC[-44])"
'Range("BV11:BV" & DerLig).FormulaR1C1 = "=SUM(RC[-44]:RC[-42])"
'Range("BW11:BW" & DerLig).FormulaR1C1 = "=SUM(RC[-42]:RC[-31])"
'Range("BX11:BX" & DerLig).FormulaR1C1 = "=SUM(RC[-43]:RC[-35])"
'Range("BY11:BY" & DerLig).FormulaR1C1 = "=SUM(RC[-35]:RC[-33])"
'Range("BZ11:BZ" & DerLig).FormulaR1C1 = "=SUM(RC[-33]:RC[-22])"
'Range("CA11:CA" & DerLig).FormulaR1C1 = "=SUM(RC[-34]:RC[-26])"
'Range("CB11:CB" & DerLig).FormulaR1C1 = "=SUM(RC[-26]:RC[-24])"
'Range("CC11:CC" & DerLig).FormulaR1C1 = "=SUM(RC[-24]:RC[-13])"
'Range("CD11:CD" & DerLig).FormulaR1C1 = "=SUM(RC[-25]:RC[-17])"
'Range("CE11:CE" & DerLig).FormulaR1C1 = "=SUM(RC[-17]:RC[-15])"
Range("I11:BP" & DerLig).Value = Range("I11:BP" & DerLig).Value 'Enlevez l'apostrophe devant la ligne de code pour ne conserver que les valeurs tout en écrasant les formules
Sortie:
End SubMa question est de savoir si j'ai bien fait de mettre ce bout de code au dessous, ou s'il fallait refaire tout le code pour cette nouvelle feuille "Data Promos"
D'avance merci de votre aide!
Max
En principe, c'est bon puisque la source "Data Promos", bien que différente des autres conditions, est spécifiée, je ne peux pas le vérifier, mais de votre côté, je suppose que vous avez testé et que cela fonctionne.
Si tout marche bien, passez le sujet en "Résolu".
Cdlt
je vous mets un bout de fichier avec le code, car ça n'a pas l'aide de fonctionner.
SI vous pouviez me dire d'ou vient le problème.
Max
