Remplacez le code que je vous ai donné par celui ci-dessous
Sub test()
Dim plage As Range, cel As Range
Dim dlg As Integer, j As Integer
Dim i As Byte
Dim tb As ListObject
Sheets("Feuil2").Range("B2:C500").ClearContents
Set tb = Sheets("Feuil1").ListObjects("Tableau1")
Set plage = tb.ListColumns(2).DataBodyRange
j = 4
For i = 3 To tb.ListColumns.Count
If WorksheetFunction.CountA(plage.Offset(, i - 2)) >= 1 Then
For Each cel In plage
With Sheets("Feuil2")
If cel.Value = .Range("A2").Value Then
dlg = .Range("B" & Rows.Count).End(xlUp).Row + 1
.Range("B" & dlg) = cel.Offset(0, i - 2).Value
If cel.Offset(0, i - 2).Value <> vbNullString Then .Range("C" & dlg) = cel.Offset(0, i - j).Value
Next cel
j = j + 1
