Bug inexplicable
h
Tous le code fonction
et sur un autre useform quand je delete pas de soucis avec la cb
mais dans celui ci ca me met une erreur
Private Sub Lblfond_Click()
CBCompany.RowSource = "Comp!ListComp"
LblError = " Veuillez remplir tout les champs "
CbCompR.RowSource = "Comp!Listcomp"
Private Sub Button_cancel_Click()
Unload Me
Private Sub CbClear_Click()
Txt_Nom.Value = ""
Txt_Prenom.Value = ""
CBCompany = ""
TxtNameOTher.Value = ""
TXT_NID = ""
Me.Txt_Nom.SetFocus
Private Sub BtWorker_Click()
Dim a As Range
Set a = Comp.Range("ListComp").Find(CBCompany.Value)
If Len(Me.CBCompany) = 0 Then
Me.LblError = "Choice Company"
Me.CBCompany.SetFocus
ElseIf Len(Me.Txt_Nom) = 0 Then
Me.LblError = "Enter a last name"
Me.Txt_Nom.SetFocus
ElseIf Len(Me.Txt_Prenom) = 0 Then
Me.LblError = "Enter a Name"
Me.Txt_Prenom.SetFocus
ElseIf Len(Me.TXT_NID) = 0 Then
Me.LblError = "Enter ID number"
Sheets("Comp").Activate
Select Case a
Case "ATALIAN"
Range("B10").Select
Case "VEOLIA"
Range("H10").Select
Case "BRUNONIELS"
Range("N10").Select
Case "SIPWELL"
Range("T10").Select
Case "OTHERS"
Range("Z10").Select
End Select
Selection.End(xlDown).Select
Selection.Offset(1, 0).Select
ActiveCell = ActiveCell.Offset(-1, 0).Value + 1
ActiveCell.Offset(0, 1).Value = Txt_Nom & " " & Txt_Prenom
ActiveCell.Offset(0, 2).Value = Txt_Nom
ActiveCell.Offset(0, 3).Value = Txt_Prenom
ActiveCell.Offset(0, 4).Value = TXT_NID
If CBCompany = "OTHERS" Then
ActiveCell.Offset(0, 5).Value = TxtNameOTher
Range("AG10").Select
ActiveCell.Offset(0, 2).Value = TXT_NID
Report.Activate
Unload Me
Private Sub CbCompR_Change()
affichage_NameIn
Private Sub affichage_NameIn()
Dim Mc As Range
Set Mc = Comp.Range("ListComp").Find(CbCompR.Value)'c'est ici que vient mettre une erreur le debugger
If Not Mc Is Nothing Then CbWorkerR.RowSource = "Comp!" & Mc.Offset(0, 1).Value
Private Sub BtnClose_Click()
Unload Me
Private Sub btnClear_Click()
CbCompR = ""
CbWorkerR = ""
Private Sub BtnDel_Click()
If Len(CbCompR.Value) = 0 Then
Me.LblError1 = "Select Company"
Me.CbCompR.SetFocus
ElseIf Len(CbWorkerR.Value) = 0 Then
Me.LblError1 = "Select Worker"
Me.CbWorkerR.SetFocus
Dim Valid As Byte
Valid = MsgBox("Are you sure to delete this Worker " & CbWorkerR.Value & " ?", vbCritical + vbYesNo, "Verification")
If (Valid = 7) Then
CbCompR = ""
CbWorkerR = ""
Exit Sub
Dim a As Range
Set a = Comp.Range("ListComp").Find(CbCompR.Value)
Dim Lig As Integer
Lig = Selection.Row
Select Case a
Case "ATALIAN"
Range("ListAtalian").Find(CbWorkerR.Value).Select
Lig = Selection.Row
Selection.ListObject.ListRows(Lig - 10).Delete
Case "VEOLIA"
Range("ListVeolia").Find(CbWorkerR.Value).Select
Lig = Selection.Row
Case "BRUNONIELS"
Range("ListBrunoniels").Find(CbWorkerR.Value).Select
Lig = Selection.Row
Case "SIPWELL"
Range("ListSipwell").Find(CbWorkerR.Value).Select
Lig = Selection.Row
Case "OTHERS"
Range("ListOthers").Find(CbWorkerR.Value).Select
Lig = Selection.Row
End Select
End SubPLS help je suis perdu j'ai beau essaie de mettre un unload apres le delete que ca sois dans le case ou dans le if rien n'y fait le formulaire ne se ferme pas donc pas moyen de refresh non plus la combobox
hummm ?!
Comme ça je ne voit pas... Qui d'autre ?
@ bientôt
LouReeD
h
c'est bien ca le problème
Comme qui dirait : Le fichier KI VA BI1 ?
@ bientôt
LouReeD
h
j'ai trouver en fait il suffisait de trouver ou Clear la combobox avant de delete sinon apparemment ca faisait erreur de chargement
Select Case a
Case "ATALIAN"
CbCompR.Value = ""
Lig = Selection.Row
If MsgBox("The worker as delete", vbOKOnly, "Confirm") = vbOK Then Unload Me
Case "VEOLIA"
CbCompR.Value = ""
Lig = Selection.Row
Case "BRUNONIELS"
CbCompR.Value = ""
Lig = Selection.Row
Case "SIPWELL"
CbCompR.Value = ""
Lig = Selection.Row
Case "OTHERS"
CbCompR.Value = ""
Lig = Selection.Row
End SelectBonsoir,
merci pour ce retour, et désolé pour le retard du mien !
@ bientôt
LouReeD
