Exécution plus rapide d'une macro
Y
J'aimerai savoir si il serait possible de rendre plus rapide l'exécution de cette macro.
Actuellement elle tourne aux alentours des 10s.
Merci d'avance.
Merci d'avance.
Sub Test()
Dim BoEcran As Boolean, bobarre As Boolean, boevent As Boolean, bosaut As Boolean
Dim icalcul As Integer
Dim Plg
Dim wb As Workbook
Dim Lg%
Dim Cel As Range
If MsgBox("Veux-tu lancer la commande?", _
vbYesNo + vbInformation, "Import - Export") = 7 Then Exit Sub
BoEcran = Application.ScreenUpdating
bobarre = Application.DisplayStatusBar
icalcul = Application.Calculation
boevent = Application.EnableEvents
bosaut = ActiveSheet.DisplayPageBreaks
Application.DisplayStatusBar = False
Application.Calculation = xlManual
ActiveSheet.DisplayPageBreaks = False
ThisWorkbook.Sheets("X").Unprotect Password:="MERCI"
ThisWorkbook.Sheets("X").Range("$A$3:$T$3").AutoFilter
Plg = ThisWorkbook.Sheets("X").Range("E4:F203")
ThisWorkbook.Sheets("X").Range("E4:F203") = Application.Trim(Plg)
Set wb = Workbooks.Open(ThisWorkbook.Path & "\R.xlsx")
wb.Sheets("A").Range("$C$1:$P$1").AutoFilter
ThisWorkbook.Sheets("X").Range("D4:L203").Copy
wb.Sheets("A").Range("D2:L201").PasteSpecial xlPasteValues
ThisWorkbook.Sheets("X").Range("N4:O203").Copy
wb.Sheets("A").Range("N2:O201").PasteSpecial xlPasteValues
ThisWorkbook.Sheets("X").Range("F4:F203").Copy
wb.Sheets("A").Range("C2:C201").PasteSpecial xlPasteValues
ThisWorkbook.Sheets("X").Range("I4:I203").Copy
wb.Sheets("A").Range("P2:P201").PasteSpecial xlPasteValues
With wb.Sheets("A")
wb.Sheets("B").Range("A:Z").ClearContents
wb.Sheets("A").Range("C1:P801").AutoFilter Field:=1, Criteria1:="<>", Operator:=xlAnd
wb.Sheets("A").Range("C2:P801").SpecialCells(xlCellTypeVisible).Copy '[D2]
wb.Sheets("B").Range("A2").PasteSpecial xlPasteValues
wb.Worksheets("B").Activate
Lg = [A65536].End(xlUp).Row
For Each Cel In wb.Sheets("B").Range("A2:A" & Lg)
Cel.Value = Cel.Value & " " & Cel.Offset(0, 5)
Next Cel
wb.Sheets("B").Range("A1") = "Fusion"
Derligne = Range("A" & Rows.Count).End(xlUp).Row
wb.Sheets("B").Sort.SortFields.Clear
wb.Sheets("B").Sort.SortFields.Add Key:=Range("N2:N" & Derligne) _
, SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With wb.Sheets("B").Sort
.SetRange Range("A2:N" & Derligne)
.Header = xlGuess
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
listenoms = "/"
i = Range("A" & Rows.Count).End(xlUp).Row
Do While i > 1
If listenoms Like "*/" & Range("A" & i) & "/*" Then
If Range("A" & i).Interior.ColorIndex <> 6 Then
Rows("" & i & ":" & i & "").Delete
listenoms = listenoms & Range("A" & i) & "/"
i = i - 1
Loop
, SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:=xlSortNormal
With Sheets("B").Sort
.Header = xlGuess
.MatchCase = False
.Apply
wb.Sheets("B").Range("B2:J201").Copy
ThisWorkbook.Sheets("X").Range("D4:L203").PasteSpecial xlPasteValues
wb.Sheets("B").Range("L2:M201").Copy
ThisWorkbook.Sheets("X").Range("N4:O203").PasteSpecial xlPasteValues
wb.Save
wb.Close
ThisWorkbook.Sheets("X").Protect Password:="MERCI"
ThisWorkbook.Sheets("X").Protect Password:="MERCI", UserinterfaceOnly:=True, AllowSorting:=True, AllowFiltering:=True
Application.ScreenUpdating = BoEcran
Application.DisplayStatusBar = bobarre
Application.Calculation = icalcul
Application.EnableEvents = boevent
ActiveSheet.DisplayPageBreaks = bosaut
End Subbonjour,
Tu peux déjà tester ça, pour le reste j'ai pas le temps pour le moment...
Sub Test()
Dim Plg, Arr, i%
Dim wb As Workbook
Dim Lg%
Dim Cel As Range
Arr = ThisWorkbook.Sheets("X").Range("D4:L203").Value
wb.Sheets("A").Range("D2:L201") = Arr
Arr = ThisWorkbook.Sheets("X").Range("N4:O203").Value
wb.Sheets("A").Range("N2:O201") = Arr
Arr = ThisWorkbook.Sheets("X").Range("F4:F203")
wb.Sheets("A").Range("C2:C201") = Arr
Arr = ThisWorkbook.Sheets("X").Range("I4:I203")
wb.Sheets("A").Range("P2:P201") = Arr
With wb.Sheets("A")
Arr = wb.Sheets("B").Range("A2:A" & Lg).Value
For i = 1 To UBound(Arr)
Arr(i, 1) = Arr(i, 1) & " " & Arr(i, 6)
wb.Sheets("B").Range("A2:A" & Lg) = Arr
.Header = xlGuess
.MatchCase = False
.Apply
listenoms = "/"
Do While i > 1
i = i - 1
Loop
.Header = xlGuess
.MatchCase = False
.Apply
Arr = wb.Sheets("B").Range("B2:J201")
ThisWorkbook.Sheets("X").Range("D4:L203") = Arr
Arr = wb.Sheets("B").Range("L2:M201")
ThisWorkbook.Sheets("X").Range("N4:O203") = Arr
wb.Save
wb.Close
End SubA+
Y
Désolé mais je t'ai vraiment fait ça entre 2 portes...
Une version un peu plus aboutie :
Sub Test()
Dim Plg, Arr, ArF, i%
Dim wb As Workbook
Dim Lg%
Dim Cel As Range
'ThisWorkbook.Sheets("X").Unprotect Password:="MERCI"
With wb.Sheets("A")
Arr = .Range("C2:P801").SpecialCells(xlCellTypeVisible).Value
wb.Sheets("B").Range("A2").Resize(UBound(Arr), UBound(Arr, 2)) = Arr
With wb.Worksheets("B")
.Activate
Lg = .[A65536].End(xlUp).Row
Arr = .Range("A2:A" & Lg).Value
ArF = .Range("F2:F" & Lg).Value
Arr(i, 1) = Arr(i, 1) & " " & ArrF(i, 1)
Derligne = .Range("A" & .Rows.Count).End(xlUp).Row
.Sort.SortFields.Add Key:=.Range("N2:N" & Derligne) _
.Header = xlGuess
.MatchCase = False
.Apply
listenoms = "/"
i = .Range("A" & .Rows.Count).End(xlUp).Row
Do While i > 1
If listenoms Like "*/" & .Range("A" & i) & "/*" Then
If .Range("A" & i).Interior.ColorIndex <> 6 Then
.Rows("" & i & ":" & i & "").Delete
listenoms = listenoms & .Range("A" & i) & "/"
i = i - 1
Loop
.Header = xlGuess
.MatchCase = False
.Apply
Arr = .Range("B2:J201")
Arr = .Range("L2:M201")
wb.Save
wb.Close
'ThisWorkbook.Sheets("X").Protect Password:="MERCI"
'ThisWorkbook.Sheets("X").Protect Password:="MERCI", UserinterfaceOnly:=True, AllowSorting:=True, AllowFiltering:=True
End SubL'avantage c'est que cette après midi je n'ai pas trop d'obligation donc je pourrai surement intervenir plus rapidement en cas de pb.
Y
Ca serait vraiment minable de ma part d'en vouloir à une personne qui me propose son aide.
Pour revenir à ton code, il fonctionne parfaitement (je pense la renommer par "nitro"
Merci beaucoup du temps consacré.
