Merci des infos. Là il y a pas mal de données à traiter éventuellement. Faites ceci :
1. Dans le code Private Sub Worksheet_SelectionChange(ByVal Target As Range) qui se trouve dans les feuilles ENTREE et STOCK, ajoutez cette ligne
2. Dans le module 1, remplacez la macro Supprimer que je vous avais donnée par celle ci-dessous
'//BOUTON SUPPRIMER LIGNE DU TABLEAU SELECTIONNE
Sub supprimer_ligne()
Dim Code As String
Dim lo As ListObject, lr As ListRow, lRowInTable As Long
If Not ActiveCell.ListObject Is Nothing Then
msg = "Supprimer cette ligne " & ActiveCell.Row & "?"
Style = vbYesNo + vbCritical + vbDefaultButton2
Title = "Suppression"
Response = MsgBox(msg, Style, Title)
If Response = vbYes Then
Set lo = ActiveCell.ListObject
lRowInTable = ActiveCell.Row - lo.HeaderRowRange.Row
Code = lo.DataBodyRange.Item(lRowInTable, 7)
Set lr = lo.ListRows(lRowInTable)
lr.Range.Delete
Dim c As Range, Rng As Range
Dim firstaddress As String
Dim lig As Long
Dim Feuille
Dim i As Byte, j As Byte
Feuille = Array(Feuil3, Feuil5)
For i = 0 To UBound(Feuille)
With Feuille(i).ListObjects("TAB" & Feuille(i).Name)
Feuille(i).Unprotect PSW
Set c = .DataBodyRange.Find(Code, LookIn:=xlValues)
If Not c Is Nothing Then
firstaddress = c.Address
Do
lig = Range(c.Address).Row - 16
.ListRows(lig).Range.ClearContents
j = j + 1
Set c = .DataBodyRange.FindNext(c)
On Error Resume Next
Loop While Not c Is Nothing And c.Address <> firstaddress '--> Dan
Set Rng = .DataBodyRange.SpecialCells(xlCellTypeBlanks)
If j = 1 Then
.ListRows(lig).Range.Delete: j = 0
Else: Rng.Delete
Feuille(i).Protect PSW
