VBA et SmartView - Fonction HsGetValue
J’ai réalisé un code qui me permet de de mettre à jour les valeurs de la fonction SmartView HsGetValue avant de rafraichir et de remplacer les formules par leurs valeurs, le code répète l’action pour toutes les colonnes qui ont été ajoutées dans la feuille, i.e. :
Declare Function HypConnect Lib "HsAddin" (ByVal vtSheetName As Variant, ByVal vtUserName As Variant, ByVal vtPassword As Variant, ByVal vtFriendlyName As Variant) As Long
Declare Function HypMenuVRefresh Lib "HsAddin.dll" () As Long
Sub SV_Retrieve()
x = HypMenuVRefresh()
Sub Retrieve_values()
Dim i, n, l As Integer
'--------------------------------STEP1: loop to set formulas-----------------------
For l = 7 To 300
If Cells(1, l) <> 0 Then
For i = 12 To 300
' Scenario
VAR1 = Cells(1, l).Address
VAR2 = Cells(2, l).Address
VAR3 = Cells(3, l).Address
VAR4 = Cells(4, l).Address
VAR5 = Cells(5, l).Address
VAR6 = Cells(6, l).Address
' currency, custom7 etc...
VAR7 = "$B$1"
VAR8 = "$B$2"
VAR9 = "$B$3"
VAR10 = "$B$4"
' Customs
CUSTOM1 = "$A" & i
CUSTOM2 = "$B" & i
CUSTOM3 = "$C" & i
CUSTOM4 = "$D" & i
CUSTOM5 = "$E" & i
CUSTOM6 = "$F" & i
If Cells(i, 6) <> 0 Then
' To set the value of customs to the corresponding line, CUSTOM5 = ICP
Cells(i, l).FormulaR1C1 = "'=HsGetValue(""Hyperion"";""Scenario#"" & " & VAR1 & " & "";Year#"" & " & VAR2 & " & "";Period#"" & " & VAR3 & _
" & "";View#"" & " & VAR4 & " & "";Entity#"" & " & VAR5 & " & "";Value#"" & " & VAR6 & " & "";Account#"" & " & CUSTOM6 & " & "";ICP#"" & " & CUSTOM5 & _
" & "";Custom1#"" & " & CUSTOM1 & " & "";Custom2#"" & " & CUSTOM2 & " & "";gaap#"" & " & CUSTOM3 & " & "";nature#"" & " & CUSTOM4 & _
" & "";Restatement#"" & " & VAR7 & " & "";Disposals#"" & " & VAR8 & " & "";Custom7#"" & " & VAR9 & " & "";Currency#"" & " & VAR10 & " & """")/1000000"
Cells(i, l).Caption = Replace(Cells(i, l), "'=HsGetValue", "=HsGetValue")
Next l
'--------------------------------STEP2: Refresh of values--------------------------------
SV_Retrieve
'--------------------------------STEP3: Replace formulas by values---------------------------
For n = 12 To 300
If Cells(n, 6) <> "" Then
Cells(n, l) = Cells(n, l).Value
Next n
'-----------------------------------END-----------------------------------On obtient donc la formule au format texte. Mon problème réside dans le fait que je n’arrive pas à remplacer l’apostrophe par rien et donc à lancer la formule, que ce soit directement dans Excel avec Ctrl + H ou en VBA avec le code suivant :
Cells(i, l).Caption = Replace(Cells(i, l), "'=HsGetValue", "=HsGetValue")Quand je lance le code de cette manière j’ai l’erreur suivante « Run-time error ‘438’ : Object doesn’t support this property or method ».
C’est un peu barbare mais c’est la seule solution que j’ai trouvé pour le moment. Est-ce que quelqu’un une idée ?
Merci d’avance à ceux qui prendront le temps de me lire
Jeremy
je viens de faire un test avec le code suivant, mais pas plus de résultat:
For l = 7 To 300
For i = 12 To 300
' Scenario
VAR1 = CStr(Cells(1, l).Address)
VAR2 = CStr(Cells(1, l).Address)
VAR3 = CStr(Cells(1, l).Address)
VAR4 = CStr(Cells(1, l).Address)
VAR5 = CStr(Cells(1, l).Address)
VAR6 = CStr(Cells(1, l).Address)
' Customs
CUSTOM1 = "$A" & i
CUSTOM2 = "$B" & i
CUSTOM3 = "$C" & i
CUSTOM4 = "$D" & i
CUSTOM5 = "$E" & i
CUSTOM6 = "$F" & i
Cells(i, l).FormulaR1C1 = "'=HsGetValue(""Hyperion"",""Scenario#"" & H$1 & "";Year#"" & H$2 & "";Period#"" & H$3 & "";View#"" & H$4 & "";Entity#"" & H$5 & "";Value#"" & H$6 & "";Account#"" & CUSTOM6 & "";ICP#"" & CUSTOM5 & "";Custom1#"" & CUSTOM1 & "";Custom2#"" & CUSTOM2 & "";gaap#"" & CUSTOM3 & "";nature#"" & CUSTOM4 & "";Restatement#"" & $B$1 & "";Disposals#"" & $B$2 & "";Custom7#"" & $B$3 & "";Currency#"" & $B$4 & """")/1000000"
' Replace values to the corresponding CUSTOM (Col) and corresponding line with CUSTOM5 = ICP and CUSTOM6 = ACCOUNT
Cells(i, l).Value = Replace(Replace(Replace(Replace(Replace(Replace(Cells(i, l).Value, "CUSTOM1", "A$" & i), "CUSTOM2", "B$" & i), "CUSTOM3", "C$" & i), "CUSTOM4", "D$" & i), "CUSTOM5", "E$" & i), "CUSTOM6", "F$" & i)
Cells(i, l).Value = Replace(Replace(Replace(Replace(Replace(Replace(Cells(i, l).Value, "CUSTOM1", VAR1), "CUSTOM2", VAR2), "CUSTOM3", VAR3), "CUSTOM4", VAR4), "CUSTOM5", VAR5), "CUSTOM6", VAR6)
Next lCette fois j'ai un Typemysmatch sur:
Cells(i, l).Value = Replace(Replace(Replace(Replace(Replace(Replace(Cells(i, l).Value, "CUSTOM1", VAR1), "CUSTOM2", VAR2), "CUSTOM3", VAR3), "CUSTOM4", VAR4), "CUSTOM5", VAR5), "CUSTOM6", VAR6)Bonjour jeremyc,
En préfixant d'un tilde ~ , cela devrait le faire
klin89
