Bonjour.
Dans ce code, arrivé à la ligne "Settings.ListBox_hist.Selected(i) = True" l'évènement ListBox.Change se déclenche malgrès le EnableEvents = False ...
Sub Initialize_settings()
For Each cel In Sheets("Main").Range("E9:E" & Sheets("Main").Range("G" & Sheets("Main").Rows.Count).End(xlUp).Row)
If cel = True Then
For i = 0 To Settings.ListBox_hist.ListCount - 1
If Settings.ListBox_hist.Column(2, i) = cel.Offset(0, 2) Then Settings.ListBox_hist.Selected(i) = True
Next cel
Private Sub ListBox_hist_Change()
For Each cel In Sheets("Main").Range("G9:G" & Sheets("Main").Range("G" & Sheets("Main").Rows.Count).End(xlUp).Row)
For i = 0 To Me.ListBox_hist.ListCount - 1
If Me.ListBox_hist.Selected(i) = True And Me.ListBox_hist.Column(2, i) = cel Then
If cel.Offset(0, -2) <> True Then
cel.Offset(0, -2) = True
GoTo Fin
If cel.Offset(0, -2) <> False And Me.ListBox_hist.Selected(i) = False And Me.ListBox_hist.Column(2, i) = cel Then
cel.Offset(0, -2) = False
GoTo Fin
Next cel
Fin:
Call Generate_Active_Filter
Pourquoi ? Comme résoudre ce problème ? J'avoue que je suis un peu perdu je n'ai jamais eu ce cas de figure
D'avance merci.. A+
